Benq v2210 Eco - one backlight strip not working
  • martinlink
    • Mar 2012
    • 19
    • Estonia
    Hey guys and gals,
    my lovely LED monitor decided to discontinue its (until now) perfect service. Only the top half is brightly illuminated, while the bottom is about 50% dimmer, though still legible.
    I dismantled the monitor and tested the 2 LED backlight strips by connecting them to the 2 different sockets on the controller module (dunno how you call it).
    I found that both the strips work when plugged into the top socket, and neither work when plugged into the bottom socket. So it seems that the problem lies somewhere in the LED controller.
    My question is, what would be the easiest and most convenient way to test which part on the PCB is faulty? I have access to a multimeter and a soldering iron (not small enough to mess with the surface mount stuff, but good enough for some electrolytic cap removal etc.). Visually checked every part and found nothing unusual, and both the cap next to the working socket and non-working socket look identical, no bulging or cracks on top...
    Any input on how to proceed would be greatly appreciated!
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Benq v2210 Eco - one backlight strip not working
    Pictures might be useful I have no knowledge regarding led back lights so it would help me learn. There are more and more coming on here now the guarantees have run out.
    • martinlink
      • Mar 2012
      • 19
      • Estonia
      First one is a closeup of the backlight controller unit (green), second one is an overview of the whole power supply board.
      On the closeup, the part on the bottom, which connects to the bottom header (white) is faulty. The connector above that works as it should.
      I went to the local electronics shop and got a 10uF 100V cap, which is identical to the one on the small green board, and replaced it as it seemed like the most error-prone part (C522). This did not fix the issue.
      What would be the next thing to try/test?
      EDIT: Here's the service manual, page 27 and page 37 show the diagrams of the backlight controller board.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Thanks for the pictures
        Service manual - always useful - bit I dont follow is it says clearly it is a LED panel then gives CCFL operating voltage and startup voltage,
        I suppose the obvious things to check might be that you have Vin on Pin23
        of the processor (you can test on R 507 if its easier to get at.
        You could also test the Diodes D501 and D502 on the faulty side.
        Also I can see a 0 rated resistor on the good side - if you can see the one on the bad side test as you would a fuse
        • martinlink
          • Mar 2012
          • 19
          • Estonia
          I tested diodes D501 and D502, both show .301 and thus shouldbe fine.
          I tested the 0 rated resistor (was behind the C522 capacitor so can't be seen on the picture), shows 0 resistance, so should be fine.
          However, I am not sure how to test Vin. I found the pin23 on chip R502 (faulty side), and it conects to R522 (not R507, which should be on the working side?).
          What mode do I select on the multimeter, what does it test and sould the device be running while conducting this test?
          Thanks for the input so far!
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Did you test the diodes with the leads reversed as well
            You are correct R522 - scrolled too far up on the wiring diagram.
            Set meter on next scale above 50vDC and try that. Board will have to be powered for voltage test .Black lead on a ground screw probe resistor with red - may as well do both sides of the resistor.
            • martinlink
              • Mar 2012
              • 19
              • Estonia
              Testing the diodes in reverse gives no response (meter stays at 1) with both diodes.
              Just double checking, red lead on pin 23 of the IC (or one of the connections on R522), black lead can be connected to the 0 (middle) pin on the power cord connector?
              What should it show?
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Diodes are OK 1 being overscale
                I would prefer to use a ground on the board or pins3/4 on the long C513 cocnnector if you can get at them
                Cap at C524 is rated for 25v so I would expect it to be less than that.
                • martinlink
                  • Mar 2012
                  • 19
                  • Estonia
                  Tested it and it showed 17,3v on both sides of the R522 resistor.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Hmm - see page 39 backlight testing - suggests it should only be 5v!!
                    Perhaps do the same test on the good side?
                    Then continue with the other tests in that troubleshooter - not much point in my repeating them.
                    EDIT - You should also have the lamps plugged in while testing
                    • martinlink
                      • Mar 2012
                      • 19
                      • Estonia
                      Tested working side R507 to ground, also got 17,3v.
                      I read on page 37 about a 16v, which seems to be the closest to this one.
                      I'm measuring all voltages without having the backlights connected, otherwise I'd have to remove the backlights from the panel which is dangerous and difficult. Does that make a difference?
                      EDIT: Tested Pin24 (VREF), which should be 5v by the manual. When connecting C502 on the working side to ground, I get 5V. When I connect C527 to ground, it shows 17,3v again!! What might this mean? The IC chip IC502 is fried?
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        Perhaps without the lamps the voltages may be higher due to no load also isf there is any feedback mechanism it may think having no lights is a fault and shut down but I doubt that as it works with one string.
                        I dont know what it might mean - we are learning together I was hoping it was not the IC as I cant find one and I cant find a board either. This was as near as I got
                        - need to translate - put the link into google translate. Not that it tells us much
                        http://blog.sina.com.cn/s/blog_6a50b3930100mkgw.html
                        I am having an early night - perhaps some or our Us/Can members will comment.
                        • martinlink
                          • Mar 2012
                          • 19
                          • Estonia
                          Alright, thanks for your input so far. I'm calling it a day as well. Will check on the topic in the morning!
                            How many LED are there in each strip, from what I see in the diagram, there are 8 I-sense lines per socket, so each strip will have 8 set of LEDs.
                            • martinlink
                              • Mar 2012
                              • 19
                              • Estonia
                              I haven't disassembled the panel to access the LED strips so I don't know how many there are... Removing the metal housing around the panel involves removing the black tape that stops the light from leaking, and I don't have any to put on it after I remove it, so I really don't want to... (unless absolutely necessary).
                                Do not do that then, I am just curious since at 17V VDC, it means each string will have about 5 LEDs, 5LEDs x 8 = 40 LEDs per strip.
                                I believe this is how the circuit works (I did not look up the spec of the PWM IC yet)The VOUT is fed to the Anode of the LEDs strings (5 LED in series), the Cathode side is the return side that is connected to the Isense line (it is connected to the Drain pin of the MOSFET inside the IC and sensing resistor on the source pin then ground, there are 8 MOSFETs for 8 string). The MOSFET is driven on and off with PWM, the wider the pulse, the brighter the LED stings will be.
                                There is OVP pin which will shut down the circuit if the Vout is too high (such as over voltage from the power supply or no LEDs attach so the voltage will rise up high), you should check the OVP of the working and not working IC.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4297
                                  • Italy - Milan
                                  I think that you may have a faulty segment of led and the easiest way to determine it is to connect the central pins Vout of the 2 output led connectors and detach the working led stripe from its connec., you may do this test also by disabling the protection of the faulty stage but since i cannot find the datasheet (the one posted by budm is not d.sheet) i can suppose the pinout and function is similar to for example a OZ9910 that i have on my hd, in this case it must be grounded one pin but actually i'm not sure which, maybe CMP but don't do it's risky, less risky is put LCT to gnd but i have to verify.
                                    @davi: From post #1:
                                    "I dismantled the monitor and tested the 2 LED backlight strips by connecting them to the 2 different sockets on the controller module (dunno how you call it).
                                    I found that both the strips work when plugged into the top socket, and neither work when plugged into the bottom socket. So it seems that the problem lies somewhere in the LED controller."
                                    • martinlink
                                      • Mar 2012
                                      • 19
                                      • Estonia
                                      Yes, the LED strips are confirmed working. I am 99% sure the problem is within one/some of the surface mount components of the green board. It's just that I have no knowledge of how to identify the faulty component(s)... other than desoldering them one by one and testing them out of circuit, but that's a full week of work for me.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4297
                                        • Italy - Milan
                                        I have forgot it... from the picture i don't see the switching mosfets, there is only a place for them, i don't know how the boost converter can work without..
                                        • Gjackson
                                          Question about UE60JU6800K backlight power.
                                          by Gjackson
                                          got my hands on a Samsung UE60JU6800K, initially it apparently had a bunch of white circles on screen which I confirmed was due to loose diffusers when I opened the set up and found a mountain of them at the bottom. The person I got if from stored the TV unused for a lengthy period after this so when I got it the backlight was completely gone. I took out the strips and almost all of the LED's have a crack on the yellow phosphor form the center of the LED outward, the ones that don't have this crack seem to work still (Maybe due to humidity after a long period?). Anyways I...
                                          06-11-2024, 06:03 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • edugimeno
                                          Help findinf LED strips for TDSystems K32DLT1H
                                          by edugimeno
                                          Hi There!
                                          I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
                                          Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
                                          Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the...
                                          11-05-2022, 03:36 PM
                                        • DanPoka
                                          by DanPoka
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
