TCL 65s425 sound/video working, no backlight
  • knoxrebel
    • Oct 2009
    • 168
    Tv shows no issues other than no backlight. Picture was visible with flashlight and menu navigation possible with audible responses.
    Polyester film Capacitor c620 27nf (on power supply board had visible brown discoloration, but is not shorted. Replaced with suitable spare and now working properly. (Apparently this is a known issue with this series.)
    Backlights tested independently with tester and registered ~140vs on each.
    40-L171w4-pwa1g
    Mmkp82 1kv 273 J
  • Max514
    Samsung UN55H8000 sound but no backlight no video
    by Max514
    Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
    The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
    I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
    • Unplugging the main board cable at the power supply >>> backlights came on.
    • BLU_ON signal from the
    04-14-2022, 10:34 AM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • gl4709
    Samsung un55cu7000d with backlight and sound No Video / Picture
    by gl4709
    I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
    01-23-2025, 06:21 PM
  • waybel
    LG 55LF 5800 no video,no sound or backlight
    by waybel
    Picked up this 55 inch LG 55LF5800 . It has standby light but that's it .Blinks 3 times .No picture,no sound.Could hear rattling inside.Changed all led strips as half of the reflectors were broken.Put back together still no go .Checked output from power supply to LED connector .Only getting 89 volts on each .Suppose to be 215 V and 145 V . power board number is EAX65423801 .Yes i know screws are not on power board .I just put back on for pics.
    01-10-2025, 10:04 AM
