Finlux LED backlight not working
  • stoian_93
    • Oct 2022
    • 13
    Hello guys!
    My Finlux TV backlight stopped working. I disassembled the TV, saw I don't have the tools to replace the backlight and assembled it again without replacing anything. So then the backlight started working again.
    A day after it is also not working.
    I decided now to remove the back cover and get the output voltage to the backlight. I placed the TV facedown and connected to the mains, so - nothing. I disconected, removed the cover and connected again to the mains and then the backlight lighted again. So strange.
    Output voltage when light is 66V.
    Board: VESTEL 17IPS62
    What could the problem be?
  • yokoono
    • Apr 2010
    • 488
    Re: Finlux LED backlight not working
    Change the LEDs and stop wasting time. 2x 11 leds x 3v = 66V. The voltage is correct.
    • stoian_93
      • Oct 2022
      • 13
      They were already changed 2 times untill now.
      • zwarder
        • Oct 2013
        • 45
        Buy new led strips from aliexpress with the sreen number usually VES******
        • stoian_93
          • Oct 2022
          • 13
          Guys, the LED stops lighting, and after some time starts again.
          Last time I opened the TV again, pluged into the mains, the LED did NOT lighted and I measured 24V, going to it.
          I can not find out which element on the board is the problem.
          • nomoresonys
            • 12206
            • U.S.
            Wonder if it's a bad led driver ic on the powerboard or something, make sure it's not just a bad solder joint, see if you can get a clue from that page: https://www.google.com/search?client...ps62+schematic
            • stoian_93
              • Oct 2022
              • 13
              I'm sure it's not a bad joint. I saw some of them and made them again, so it's not. I ordered new driver and when replace it will see if it is. But there's nothing else, that seems to be defective. Thank you 'till now!
                • 21186
                Put make and model number in thread title ! ! ! https://www.badcaps.net/forum/showthread.php?t=24661
                • howardc64
                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                  by howardc64
                  TV was fixed just after removing Samsung's rear snap cover.
                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                  Maybe PSU->backlight connector didn't have a good contact?...
                  07-23-2025, 12:34 AM
                • ktmmotocross
                  Asus G513QE keyboard and backlight not working
                  by ktmmotocross
                  Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
                  i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
                  but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
                  08-08-2025, 06:29 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • knoxrebel
                  TCL 65s425 sound/video working, no backlight
                  by knoxrebel
                  Tv shows no issues other than no backlight. Picture was visible with flashlight and menu navigation possible with audible responses.
                  Polyester film Capacitor c620 27nf (on power supply board had visible brown discoloration, but is not shorted. Replaced with suitable spare and now working properly. (Apparently this is a known issue with this series.)
                  Backlights tested independently with tester and registered ~140vs on each.
                  40-L171w4-pwa1g
                  Mmkp82 1kv 273 J...
                  01-12-2025, 03:33 PM
