Dell ST2410b Backlight Shuts Off
    Re: Dell ST2410b Backlight Shuts Off
    OK, I see now, so the output side of the resistor is basically feeding shorted circuit, that is why it has 4.7V across it, Next we need to locate the component that is loading down the circuit, it can be shorted CERAMIC cap, IC, etc. Need beterr clear and close up to see what is connected to that end of the resistor.
      OK, lift one end of the jumper JW13 off the board and see what voltage you get on the filter cap C803 as circled in the picture, it should be 5VDC. Pin 11 of the PWM IC looks like the VCC pin, and that RED Glass diode may be Zener which can also be shorted out.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4319
        • Italy - Milan
        #43
        You must desolder the zener ZD803 and see if it's shorted after that.
        • uengin
          • Jan 2014
          • 32
          Ok Guys, I think you might be spot on the ball with the Zener.
          • Removed JW13 and measured the capacitor voltage: 5V more or less.
          • Just to rule it out or rule it in, I removed the zener and tested the voltage across the 10ohm resistor; it had (I think) 0.8V drop across it
          Do I have to replace the zener? Do you think it failed as a result of another failure in the circuit? How do I know the specs to replace the zener with? It was reverse biased (it seems) so the reverse bias break down voltage is important, I gather.
          What do you think?
          PS: Sorry about the photo, my camera is broken had to borrow a camera to take the below, hope that's high res. enough. I thought I'd clean the board with isopropyl but it ended up with hazes and streaks, tried to clean it to the best I could...
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4319
            • Italy - Milan
            #45
            This is the result with isopropyl?! It seems all corroded..
            For the zener you can download the inverter ic IC801 datasheet and see the Absolute maximum ratings, at the voice Vcc that is approx. the rate of the zener.
            "Do I have to replace the zener?" yes. "Do you think it failed as a result of another failure in the circuit? " I don't know but it's probably an overvoltage that shorted the zener, maybe for one of the big caps.
            • uengin
              • Jan 2014
              • 32
              The datasheet is hard to come by. I've found out its O2micro. It's an OZ9933GN. Any ideas where to find the datasheet?
              • selldoor
                Slow Learner
                • 7870
                #47
                This may help
                https://www.badcaps.net/forum/showpo...8&postcount=36
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4319
                  • Italy - Milan
                  #48
                  Put it of 7V and go for sure.. its for protection you can trash it away and test the monitor all hooked up and see if works.. then replace the zener
                  • uengin
                    • Jan 2014
                    • 32
                    Sorry, what did you mean by "Put it of 7V and go for sure.."?
                    I have removed that zener diode and hooked it all up. There's a full image on the LCD. BL_ON about 2.5V but still no light. So I disconnected the the BL_ON from the Video board and routed 3.2V from the Power line in to the BL_ON for the slim chance that it may require TTL logic levels. Still no light.
                    Should I check the waveform being fed in to the output transformers to make sure there is activity on the output stage? Do you know what the voltage levels are in to the primary of the transformers that drive the CCFLs? My ameture scope can only handle about 80V input, so I don't want to fry that.
                    • uengin
                      • Jan 2014
                      • 32
                      Originally posted by selldoor
                      That'll be very helpful, thanks. At least there's some labels to those pins.
                      • uengin
                        • Jan 2014
                        • 32
                        Ahaa! The Asus VE205 has the identical inverter and power board as the Dell. That'll be handy to know when chasing down parts, ey? Thanks again for the selldoor.
                        • uengin
                          • Jan 2014
                          • 32
                          Ok, I was impatient and tested the voltage across the primary of the CCFL transformers with a multimeter, then hooked up my scope. 0V and no activity, respectively.
                          Tested pin 11 got 5V.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4319
                            • Italy - Milan
                            #53
                            "Sorry, what did you mean by "Put it of 7V and go for sure.."?"
                            I mean put it at 7v (the zener) and you are sure.
                            You have the pinout of the inverter ic so check the waveform of the 4 outputs, pin 6,8,9,10. If you find that waveform then check those sop8 chip dual mosfets Q801 and Q802.
                            As you can see from the diagram selldoor posted each dual mosfets have pin 3 at the supply voltage (Vin) for the inverter circuit , that is the same as the voltage at the cathode of D705.
                            • uengin
                              • Jan 2014
                              • 32
                              Could you correct me if I am wrong; The inverter IC is supposed to take care of oscillating the gates on the mosfets to switch them on and off causing change in currents in the primary coil of the CCFL transformer thereby creating high voltages on the secondary of the same transformer, lighting up the CCFL's?
                              So I tested those pins, and they are all in a "high" state. About 3 volts to be exact. All pins, 6, 8, 9, and 10.
                              I wanted to make sure that the input pin PWM was indeed receiving a PWM, and it is. It seems to get about 90% high and 10% low, though I could probably take a measurement. I just wasn't sure if what i got was expected...?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4319
                                • Italy - Milan
                                #55
                                Originally posted by uengin
                                Could you correct me if I am wrong; The inverter IC is supposed to take care of oscillating the gates ....
                                You are correct
                                if those pins are not oscillating you can control that Ena (BL_on) path is not interrupted, if no i think you have to consider a new inverter ic. Bye.
                                • uengin
                                  • Jan 2014
                                  • 32
                                  Ok, I'll check if the ENA pin on the chip is high, if so, inverter IC needs replacement.
                                  I'd like to thank everyone that contributed and gave their suggestions. I think I am going to love this forum and hope I can contribute to the members here and give assistance to others as well as I get more and more experienced.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4319
                                    • Italy - Milan
                                    #57
                                    I'm not experienced, wait good ending for the greetings :-)
                                    • uengin
                                      • Jan 2014
                                      • 32
                                      Davi.p, you, budm and others who have contributed have been most helpful. Your suggestions, experience or otherwise have been an experience for me therefore I really appreciate it. Thank you all.
                                      As for the final result, I have ordered several OZ9933GN ICs (just incase the first one I put in goes bad because of another fault in the cirsuit that we have not identified yet). I am waiting for the ICs to arrive and will let you know when the replacement is done and what the results are.
                                      • uengin
                                        • Jan 2014
                                        • 32
                                        Hey people,
                                        Chips came. I got impatient with the SMD work, ran it a bit too hot... Board browned out and I heard crackling sounds while desoldering. When I replaced it with the new chip and powered it on: power LED started to blink. GRRRR.
                                        I've ran out of patience but does anyone still think it's work trying to save this board?
                                        By the way I have 4 extra OZ9933 chips. I'll sell it out for about $5 each if anybody is interested?
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4319
                                          • Italy - Milan
                                          #60
                                          Hi, i can't evaluate if there's a new damage due to bad soldering job, maybe a spotted picture of it can help. How about the chip orientation?
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • survivalbloke
                                            Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                                            by survivalbloke
                                            I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                                            Any ideas?
                                            01-08-2024, 12:12 PM
                                          • samuelphirik
                                            Dell inspiron 15 7567 sudden shuts down
                                            by samuelphirik
                                            Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
                                            During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
                                            I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
                                            Now I've noticed that laptop...
                                            07-02-2023, 05:45 AM
