Dell 2709w No power
  • ytsoc
    • May 2014
    • 67
    • romania
    #41
    Re: Dell 2709w No power
    Back with good news.
    Thanks to Neil who sent me his board so i can copy that eeprom, i got my monitor up and running again.
    Bonus i managed to fix his board too by reflowing the same bga chip.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #42
      A question to you that have this monitor, heatsink (HS1) to the right of the bulk filter capacitor in the picture below does it become really hot?
      Mine emits a crazy amount of heat, so far I've only looked at this monitor briefly.
      The cap has 378VDC across it's legs with 230VAC on the incoming
      There is no voltage at all on the 24v output connector.
        As you notice, they put the thermal transfer pads (4) to transfer the heat to the chassis, they do run hot. Did you check the temperature to see how hot it is?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          #44
          It was too hot to touch, I will get a temperature probe & check how quickly it's heating up.
          Does anyone have a schematic for this PSU?
          I will compare all voltages with the first post in this thread, a little later when my brain starts working (It's 30°C outside now )
          • jetadm123
            • 2169
            #45
            Did you check fuse F701 next to the wiring harness? I believe that's the fuse for the 24V output.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              #46
              No I did not, just did a real quick check before going to a lake for a swim
              Will check later tonight, thanks for pointing it out!
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #47
                Ok, had some time to look into this monitors PSU now.
                It takes ca 2min for HS1 to go from 35°C to 75°C (logic board & backlight disconnected)
                The fuse F701 checked out fine.
                C606=10.4v
                C611=10.8v
                C622=33v (slowly builds from ca 32.5v > 34v under 1 min)
                VCC on IC651=10.7V (ST: L6561 PFC Controller)
                VCC on IC601=10.8V (On Semiconductor: 1203P60 PWM Controller)
                I have labeled the pins on transformer T601 in the attached picture.
                Between 1>5 & 3>4 I see 0.5Ω
                Between 1>3 & 4>5 I see 320Ω
                Between 1>3 & 4>5 I also see 375V
                On the other side of the transformer there is 0v between all legs & resistance is 0.4Ω
                So the problem is probably in the transformer (1J.20319.001) or the rectifiers D701 or D703 (VF20200C) that follow.
                It's time for bed now though, so will have to desolder them tomorrow to look further.
                Last edited by Per Hansson; 07-30-2014, 06:32 AM. Reason: Edited pinout for transformer on picture to match PCB & attached datasheets.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #48
                  Any voltage on the caps C711to C715 - the ones in a row along the edge
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #49
                    No the entire output is dead...
                    Took another picture of the board and played a bit in Photoshop:
                      • 31294
                      what's the part number on ic651?
                      and can you check the value of the 4 blue resistors to it's left.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #51
                        IC651 is a ST L6561 PFC Controller, I attached it's datasheet in a post above now.
                        The four resistors R657, R658, R660 & R661 all measure within 1% of 1MΩ out of circuit.
                        Their color codes are Brown, Black, Black, Yellow, Brown which = 1MΩ
                        I desoldered the 2x VF20200C rectifiers D701 & D703
                        Resistance was still 0.4Ω between the output legs of the transformer.
                        So I desoldered the secondary side of the transformer, resistance on it was the same.
                        Resistance on the now empty traces on the PCB changed from 0.4Ω to infinite resistance.
                        When I applied power there was no change:
                        The HS1 heatsink still heated up the same way and there was no power on the output of the transformers legs. (which now where in the air).
                        I take it the transformer is bad?
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #52
                          I dont think these type of transformers show a resistance on the secondary windings
                          until they are working at which point you cant measure them im sure budm has mentioned this a few times I will try and find it. (in case i just made it up )
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #53
                            It was here I last read it
                            https://www.badcaps.net/forum/showpo...36&postcount=3
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #54
                              Hmm ok but even if the low ohm reading is ok (keep in mind 0.4Ω with my fluke is pretty much a dead short)
                              How can there not be voltage present on the secondary, I mean there is high voltage on the primary, surely there must then be voltage on the secondary winding?
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #55
                                What voltage is there on the Vcc pin on the 1203P60
                                May be around 5-12v but careful high voltage area
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  #56
                                  Selldoor:
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #57
                                    OK think that is too low- so next test the voltage on the start up cap perhaps 47uf 50v
                                    C606?? haha - just seen it 10.4v
                                    Also too low - suggest change this cap
                                    NOTE to SELF - Read the thread properly !!!
                                    • jetadm123
                                      • 2169
                                      #58
                                      There appears to be several revisions of this same power supply used in the large screen Dells. All made by the same company and all pretty lousy! If you do a search on this website for a Dell 2408WFp, there should be a schematic. The design is slightly different, but it's baseline enough to help aid in your troubleshooting.
                                      1) the 1203p60 needs at least 12.8v to turn on correctly. It could still be the 47uf startup cap. Do you have a spare to substitute? Also, check the zener diode across that 47uf cap.
                                      2) Check Q601 for shorts.
                                      3) If you suspect the transformer, did you check the Vcc of the P1203d60 after you unsoldered the secondary? It should rise if there was a short.
                                        Did you check the Source to Drain of that MOSFET on the HS1 to see if it show low resistance?
                                        BTW the T601, pin 3 and 4 is the primary winding, pin 1 and 5 is the AUX winding.
                                        • Per Hansson
                                          • Jul 2005
                                          • 5895
                                          • Sweden
                                          #60
                                          Replaced the two caps, their capacitance tested good, ESR read 0.7
                                          Only 0.1v difference with the new caps installed with regards to measured voltages previously:
                                          C606=10.4v
                                          C611=10.9v
                                          VCC on IC601=10.9V
                                          • k4wers
                                            Dell 2709w
                                            by k4wers
                                            hi, i need cap values for the main board of this monitor.
                                            ¿does anyone have this model?
                                            i just received this board to be repaired but there are missing caps and idk the values.
                                            i'd be a good help to get them...
                                            10-28-2023, 04:55 AM
                                          • eidam655
                                            Dell 2709W
                                            by eidam655
                                            I have a used Dell 2709Wb on my desk that works... Sometimes. There's two symptoms which I'm hoping have a common cause.
                                            Issue #1 is that occasionally, when being turned off for a while, the monitor does not turn on. The power button does not react (nothing lights up), replugging the power cable does nothing. After being unplugged for a few hours, the first insertion still does nothing, but plugging it in the socket again but reversed brings it to life.
                                            Issue #2 is that when working occasionally after an hour or two the screen switches...
                                            02-25-2022, 03:18 PM
                                          • Francesc V.
                                            Technics SA-AX530 in protected mode. Overload message
                                            by Francesc V.
                                            I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                                            I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                                            I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                                            (Pin 13 goes through...
                                            11-18-2024, 12:39 AM
                                          • seppde
                                            Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                            by seppde
                                            I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                            ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                            The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                            In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                            02-09-2024, 05:19 AM
                                          • panoss
                                            Samsung LS19A100, slowed down, colors changed, lines not very crisp
                                            by panoss
                                            In the above mentioned monitor, I removed the plug a few times and this resulted no power.
                                            I opened it, soldered the dc jack and worked again.
                                            But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
                                            I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
                                            IC600 (D9329)
                                            pin 1 (BST) 9.6V
                                            pin 2 (VIN) 13.5V
                                            pin 3 (SW(Switching output)) 4.8V
                                            pin 7 (EN)
                                            pin 8 (SS) 2.6V
                                            IC601...
                                            10-13-2024, 10:21 AM
