Dell 2709w No power
Re: Dell 2709w No power
Interesting. So you have a similar problem to mine. No I2C activity suggests that the main CPU has not initialized.
I am very interested to know if your monitor will initialize by manually resetting it. See post #12. Can you earth the junction between R279 and R460? You can just use your multimeter on current with one probe on earth and briefly touch the junction with the other probe. Safest way is to use a resistor to earth just in case you accidentally earth the wrong side of R279 and short out the +24V.
Also I hope it is not inappropriate for me to say that I'm very impressed with your English. It might be better than mine and English is the only language I know!Comment
Back with some more news.
The grounding of that via didn't help(it went down to 0.4v when grounded via a 1k resistor) so i went and probed some voltages and i seem to be missing the 12v one.
It seems to be obtained with a buck converter(L4978). I measured the potential at it's eneable pin and it's basically ground and accordin to the datasheet that means it's in sleep mode.
Can you tell me if that 12v rail should be on at all times?
Also, out of the 2 heatsinked cips only the bga one gets warm, the other one is stone cold
Ps: thank you for the compliments regarding my english.Attached Filesif you find these attachements useful please consider making a small donation to the site
The 12V and one of the 5V rails ONLY come on when the monitor is powered on. The fact that you have no I2C activity means that the monitor is not in the powered on state.
I was hoping that the grounding of that point passed R279 would wake up your monitor.
For me also it is only the BGA chip that gets warm. The other chip with a heat sink is only enabled when the monitor is powered on, the 27MHz crystal beside does not oscillate until the 24V and second 5V rails are enabled.
Is the 19.6608MHz crystal near the BGA chip oscillating? I'm guessing it probably is because as you say the heat sink is warm.Comment
So your monitor has 3.2V present and you cannot get the CPU to initialize by taking the low side of R279 to ground. It is even worse than my one.
I think that both of our monitors are beyond repair. I don't like to give up but there is not much you can do with a 416 pin BGA chip.Comment
There was a dell 2709w on fleabay with a broken screen for 55 bucks. it appears to be gone now....but keep your eyes peeled for another one like it....working boards for cheap.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
I was looking into reflowing that chip also, you are brave!
You can buy the FLi30336 in single quantities from Aliexpress.
One more thing you could try:
1. Cut the orange wire that goes from the PSU to the main board. cut it in the middle and strip back some insulation.
2. Plug the monitor in to the wall outlet and wait a few seconds.
3. Now join the orange wire.
This is not the same as ground the low side of R279.Comment
Good news and bad news:
Good news is that the reflow did the trick and the monitor now sort of works.
Bad news: when connected to a pc on any imput, the picture doesn;t come on, it goes to stand-by, if i disconnect the cable(dvi vga or hdmi) it says x cable disconected and it goes to sleep.
I can get into the menus and the monitor seems to working except it doesn't display any picture from the inputs
There might be 2 things that cause this:
1 the fact that i replaced that 25lv020 meory and now i can't seem to find it anymore
2 the bga chip is toast and now is only half working
Neil, do you have any means to read that 25lv020 memory?Comment
Not really. Nothing on hand but I guess I could program a micro controller(AVR) to read it and and send the data to a PC over serial.
What would you use to read it?
For the re-flow did you remove the chip, clean up the pads and re-ball the chip or did you heat it up without removing it?Comment
there's no need for reballing(or should i say no real advantage) just apply some flux and heat it up till the solder balls melt(be aware that those el caps won't like the heat and some will explode depending on how you do the reflow) .
The problems isn't with those balls but with those within the chip, so a correct fix is to replace the chip.
I have a small programmer( called minipro) that i use to read/program chips. It's pretty cheap and surprisingly(at least for me, a novice) it supports a great number of devices ranging from al sorts of memory chips to mcu'sComment
I had a look at that programmer. Looks to be very good value. There are some on eBay for about USD$50.
I'm thinking now that I might just get a re-furbished 2709W from this eBay seller:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=321368104396
Also I might try re-flowing the BGA chip. Funny, I have been in electronics for 25 years and I've yet to buy a hot air soldering tool.Comment
I've come into possession of one of these monitors with multiple issues (vertical strips on the left hand of the screen which go away once warmed up, and recently failure to initialise).
It was pretty obvious that the previous owner (or someone) had attempted a repair but only succeeded in damaging a corner of the screen (now there are a few bright pixels where the screen is damaged - someone had inserted a screwdriver at the screen itself to pry the case open AND broken some clips at the corner). Unbelievable.
Initially on plugging the power light would flash blue and go out. I have to wait about 10 seconds between power ups to repeat the symptoms otherwise there'd be nothing happening. I could get it to eventually start after a number of rapid on-off attempts. Once warmed up it still start up ok even after power is removed and reapplied. But fails again when the monitor cools down.
So it does sounds to be a bad solder joint, possibly within the main cpu. I'll have to get the thing open later to see if applying pressure to the cpu will allow it to come on. If so then time to buy a hot air rework station!
ytsoc - where do you apply flux?
Hopefully the strips are fixable with some foam pads. The pixels are probably toast - I might apply a dab of marker ink on them - at least a 'dead' pixel is better than a bright spot.Comment
Sorry have not been on here for a while. I don't have any easy way to read the contents of the chip. Perhaps I could de-solder and post it to you?
Interesting. I too can get my one to come on by flicking the switch at the wall on and off quickly a few times.I've come into possession of one of these monitors with multiple issues (vertical strips on the left hand of the screen which go away once warmed up, and recently failure to initialise).
I'm quite sure it is a problem with the FLi30336, either the chip itself or the soldering on the BGA package.Comment
I don't know if the problem is a solder joint between the chip and the board, it could be within the chip(there are also connections inside the chip that fail due to thermal stress)
The flux is applied on the sides of the chip, once it's heated the flux will go underneath the chip and help with the reflow.
Thanks for replying neill, so you've given up on yours? how much do you want for that memory?Comment
by k4wershi, i need cap values for the main board of this monitor.
¿does anyone have this model?
i just received this board to be repaired but there are missing caps and idk the values.
i'd be a good help to get them...-
10-28-2023, 04:55 AM -
by eidam655Hi everyone,
I have a used Dell 2709Wb on my desk that works... Sometimes. There's two symptoms which I'm hoping have a common cause.
Issue #1 is that occasionally, when being turned off for a while, the monitor does not turn on. The power button does not react (nothing lights up), replugging the power cable does nothing. After being unplugged for a few hours, the first insertion still does nothing, but plugging it in the socket again but reversed brings it to life.
Issue #2 is that when working occasionally after an hour or two the screen switches...-
by Francesc V.I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
(Pin 13 goes through...-
11-18-2024, 12:39 AM -
by seppdeHello everyone,
I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...2 Photos-
by panossIn the above mentioned monitor, I removed the plug a few times and this resulted no power.
I opened it, soldered the dc jack and worked again.
But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
IC600 (D9329)
pin 1 (BST) 9.6V
pin 2 (VIN) 13.5V
pin 3 (SW(Switching output)) 4.8V
pin 7 (EN)
pin 8 (SS) 2.6V
IC601...-
- Loading...
