Samsung LS19A100, slowed down, colors changed, lines not very crisp
  • panoss
    • Mar 2014
    • 35
    • Greece
    In the above mentioned monitor, I removed the plug a few times and this resulted no power.
    I opened it, soldered the dc jack and worked again.
    But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
    I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
    IC600 (D9329)
    pin 1 (BST) 9.6V
    pin 2 (VIN) 13.5V
    pin 3 (SW(Switching output)) 4.8V
    pin 7 (EN)
    pin 8 (SS) 2.6V
    IC601 (SOZ A53)
    Pin 4 5V
    pin 5 (looks like 6th but it's the 5th) 3.3V
    CN400 pins 1-5 have 4.85V
    Q802 13.38V
    IC 100
    pin 8 4.84V​
    Am I ok till now???
    No, on the other board...
    It has an IC named 'IC5' marked with: 170753 tg121 ntdk
    Look at the photo.
    Didn't find anything in the service manual or in the internet, so I don't know which ic this is.
    It outputs:
    -on the coil L1, 4.8V
    -on the right end of the diode 12.56V
    Are they correct?
    What else should I check?
    Any help is welcome.
  • panoss
    • Mar 2014
    • 35
    • Greece
    Correction: it' s not 170753 BUT 17075E, so I think it's this one.
    'Boost Regulator with Integrated Charge Pumps, Switch Control, and High-Current Op Amp'​
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8344
      I read : 17075F
      and that is a boost converter. Maxim 17075
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • DrvLikHell
        Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
        by DrvLikHell
        Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
        The...
        02-05-2025, 01:44 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • visionbluedemon
        Help. Sony kd-65x85dj vertical lines
        by visionbluedemon
        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
        tried blocking LC lines too, but same results
        is it lcd panel issue or tcon board issue?...
        07-25-2025, 04:56 AM
