Technics SA-AX530 in protected mode. Overload message
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
    I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
    I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
    (Pin 13 goes through a 1K resistor to PIN 4 CP902 that goes to micro controller).
    As long as everything else was measuring OK (no dc offset, no voltage on speakers), I decided to remove that 1K resistor (R663). At this point of time, amplifier was fully operational.
    Without resistor, pin 13 on IC601 was measuring -12V. On the other side of the disconnected resistor I was measuring 5V coming from CP902 (micro controller). These two voltages were stable and didn't change during time!!
    Why when connecting the resistor, voltage fluctuates from time to time between -1.2 and 5V triggering the protection? and without resistor voltages don't change and amplifier works "fine"?
    Any understandable explanation? might be IC601 slightly faulty?
    Regards,
    Francesc.
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • artvandalai
    What resistor ohm will work better to repair this waterpik?
    by artvandalai
    The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
    01-05-2025, 04:10 PM
  • chth96
    Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
    by chth96
    I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
    Since then, This AC/DC adaptor have been out of order.
    But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
    After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
    And Is there any possibility that it will suddenly explode as well as to be out...
    12-03-2023, 04:40 AM
  • badcap111
    Xiaomi mi 9T missing resistor
    by badcap111
    Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
    I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
    Is...
    08-07-2023, 10:42 AM
  • trickartt
    Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
    by trickartt
    Hello Badcaps!
    I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
    This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
    05-04-2024, 12:07 PM
