Dell 2408WFPb / 2408WFP - 7 seconds to black
  • HAHOMETP
    • Nov 2012
    • 155
    Re: Dell 2408WFPb / 2408WFP - 7 seconds to black
    Folks, I am happy to report that my 2408WFPb is once again alive and well.
    Turned out it had two problems at the same time.
    1. I've built a makeshift inverter tester out of a small 5w fluorescent tube and
    a couple of wires with alligator clips. All 7 inverters had fired up this tube
    successfully but in all 7 cases I would still get the dreaded 2 seconds to
    black. However while performing this test I noticed a faint arcing under one of
    the output transformers. Per Davi.p's advice above I measured the resistances of
    the secondary windings of all 14 transformers. Thirteen of them showed ~1.650k
    but one transformer showed 440k. I desoldered it from the board and looked at it
    under the microscope. A small portion (<1mm) of the solid Cu wire that makes up
    the secondary winding had burnt off the pin it was wrapped around and soldered
    to pretty much the way a glass fuse blows leaving a tiny droplet of metal on the
    wire end. I can only explain the 440k (i.e. the non-infinite resistance) of this
    broken circuit by the presence of the carbon deposit left by the evaporated Cu
    wire which provided at least some path for the multimeter current. Luckily I had
    a couple of brand new transformers on hand that I had bought from China ahead of
    time so I replaced this transformer right away.
    2. Back in June 2013 I had mentioned that one of the CCFL pins had dislodged
    itself from the socket and that I had revived the monitor by reinserting it
    back. Well, sort of. This monitor is designed in such a way that in order to
    remove the inverter board one has to first remove the upper metal chassis that
    holds the rest of the boards. This is not readily obvious because you can pivot
    the inverter board slightly upward and wiggle it out of the 14 nests holding it
    without removing the top portion of the chassis. These nests are essentially the
    opposite ends of the CCFL sockets. However if you decide to take this shortcut
    you will be putting enough prying pressure on the CCFL pins so that some of them
    might jump out of their sockets and this is exactly what had happened with my
    monitor. I have a suspicion that its previous owner did try to repair this
    monitor at some point because when I opened it up for the first time one of
    CCFLs was already disconnected from its socket.
    Back then I thought I had managed to reinsert the pin back into its socket.
    Turns out I had not. Now I know that these sockets have stiff spring loaded
    contacts and that the CCFL ends require quite a bit of pressure to click their
    pins home. Since the CCFL pin was just sitting on top of the clip the connection
    was intermittent. This explains why for a while I was able to get the monitor to
    turn on by squeezing and twisting its plastic body. Finally the arcing in the
    poor connection had caused the socket to became charred to a point that the
    inverter lost connection to this CCFL altogether.
    I took the CCFL completely out of the housing and cleaned up the charred pin
    with a blade. I also removed its socket, took it apart and gently sanded the
    metal clip with some 400 grit sandpaper. Upon reassembly the monitor fired right
    up and has been working fine ever since.
    I have documented the above in the attached .pdf file.
    One problem still remains a mystery. The big capacitor on the PSU board (C605)
    used to show 168v at standby and 292v while working. Back in June I desoldered
    it and measured its capacitance. It was 124µf, no drift.
    Now C605 shows 78v at standby and 239v when working. It's capacitance is still
    124µf, no drift.
    I touched up each and every soldered joint with my Weller pencil thinking that
    perhaps there was a cold joint somewhere. Now C605 shows 78v at standby and 241v
    when working. I have never dealt with power stages before. I wonder if there is
    a voltage divider with a drifting resistor or something like that.
      Thanks for the follow up. So what kind of 5W CFL lamp did you use? T5 type?
      https://www.badcaps.net/forum/showthread.php?t=19987
      I did not read your PDF yet.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        "Now C605 shows 78v at standby and 241v"
        It is not your meter battery low?
        • HAHOMETP
          • Nov 2012
          • 155
          It is a bit low, but I don't think the values would be any different. Besides, this was measured with the old trusty $400 American made Wavetek 2030 that has been faithfully serving me for the past 20+ years. Having said that, I will double check the C605 voltage with the old (1958) analogue multimeter that I inherited from my father. I like vintage tools
          • HAHOMETP
            • Nov 2012
            • 155
            Just picked up yet another 2408WFPb with the classic 2 seconds to black. By swapping parts quickly narrowed the issue down to the bad Inverter PCB.
            All 14 transformers in the bad PCB reliably light up the test CCFL (as per the two excellent threads by budm) exactly as in the good PCB.
            All 14 transformers in the bad PCB show 5% resistance variance in the secondary winding exactly as in the good PCB.
            Sometimes on a rare occasion the bad PCB would light up the screen for a while but inevitably it would go black. Which leads me to suspect a cold solder joint or something stupid like that. I scrutinised every square centimeter of this PCB under the microscope but did not see anything.
            Any ideas where to look? The pdf file with pictures is attached.
              • 31017
              maybe a feedback problem.
              if it has feedback through resistors - check the value.
              i'v never seen an smd resistor rated for the kind of voltages they will get.
              • zombielinux
                • Nov 2014
                • 5
                Mega Necro Bump here.
                So I think I have an idea what the 2 pin connector does.
                Its a pair of op-amps that outputs a 2.4mV signal to the T-CON board. Its either an enable signal, an on signal, a status signal, who knows. Because it goes into the 60 pin TTL connector at the top, the 256 pin undocumented chip and all over that board.
                My SPICE simulations show that its 2.4mV un-connected, but 550nV when connected to the T-CON.
                Does anyone have a working monitor that they can test with? I'm working on an LED conversion for this monitor and will be replicating this circuit.
                EDIT: Here is the circuit: http://i.imgur.com/ShUmDJq.png
                • HAHOMETP
                  • Nov 2012
                  • 155
                  Had to take this monitor apart again. It has begun cutting out intermittently. Sometimes it would start up after 10-20 presses of the power button and sometimes would not start at all.
                  Originally posted by Davi.p
                  "Now C605 shows 78v at standby and 241v when on"
                  Turns out I had goofed up back then: I measured the voltage on C605 not across its leads but rather between its <+> lead and the chassis. Doh...
                  The voltage across the C605 is +160v in standby and +290v when the monitor is on. Curiously the second, working well, Dell 2408WFPb (I have three of those in the household) also shows +160v in standby and +290v when on.
                  Did some testing per this newer, rather useful thread:
                  The Pin9 (PS-ON, purple wire) on CN701 shows +3.25v after startup.
                  The L6561 (IC651) shows +14v between Pin8 (Vcc) and Pin6 (same as <-> lead of C605) in both monitors. However I still don't see the +400v on the C605. Ostensibly the PFC circuit is not working in both monitors.
                  Will be taking apart the third, also working well, Dell 2408WFPb just for the hell of it. Curious what is the voltage across the C605 in that one...
                  • jeffshead
                    • Jul 2019
                    • US
                    #29
                    Did you ever figure out what the problem was?
                    I have a similar problem with my 2408WFPb in that the monitor works properly after removing and reattaching the power cable several times. The problem reoccurs only when power is removed again.
                    I get 165/293Vdc on C605.
                    More info with pics: https://www.electronicspoint.com/for...eplace.291409/
                    • twonk9098
                      Lenovo Legion 5 high fan spin turns off after 34 seconds
                      by twonk9098
                      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                      I have tried a few new bios but exactly...
                      07-14-2024, 11:19 AM
                    • x_orange90_x
                      Vizio E55-E1 bad backlights or bad inverter?
                      by x_orange90_x
                      I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                      I don't know how exactly to test the inverter itself. Is it...
                      01-29-2025, 09:24 PM
                    • lostone
                      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                      by lostone
                      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                      05-19-2024, 11:40 AM
                    • Gentian
                      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                      by Gentian
                      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                      03-06-2023, 07:07 AM
                    • valvashon
                      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                      by valvashon
                      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                      01-04-2024, 01:44 PM
