Re: Nakamichi Soundspace 5 - headphone works normal, both speakers volume very low at
Thats good to know it works like this, this is just for testing and should not be left like this. So the problem is in that mute circuit, too bad you don't have the remote to toggle the mute line. I would check all of those digital transistors in that circuit, they can be hard to test but try and compare the readings between same numbered transistors. one might show a real difference.
O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
