MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
  • rounin
    • Aug 2021
    • 9
    • japan
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck β€” hoping someone here can shed some light.
    πŸ›  Original Issue
    The machine initially wouldn't negotiate 20V over USB-C β€” stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation
    β€’ UF400 (one USB-C port) works fine β€” detects a wired mouse normally.
    β€’ UF500 (the other USB-C port) only detects the mouse in one orientation.
    β€’ Power seems fine (mouse LED lights up both ways)
    β€’ A USB flash drive works in both directions, oddly enough
    πŸ” Suspected Cause: CC Line Detection
    Comparing with another known-good MacBook that uses CD3217, I found the issue seems tied to the CC1/CC2 lines, which determine plug orientation.
    On the known-good CD3217-based MacBook(not A2337):
    β€’ No device: CC lines = 0V (pulled to ground)
    β€’ Device plugged in: CC lines rise to around 1.6V via Rp pull-up
    β€’ Resistance to ground: ~7MΞ©
    β€’ Diode mode: ~0.550V
    On my faulty MacBook:
    β€’ No device: CC1/CC2 fluctuate between 1.0V–2.4V (should be 0V)
    Mouse Test:
    β€’ Normal direction:
    β€’ USBC1_CC1 β‰ˆ 1.6V, USBC1_CC2 β‰ˆ 0V
    β€’ Reversed plug:
    β€’ USBC1_CC1 β‰ˆ 0.1V, USBC2_CC2 β‰ˆ 1.6V
    ➑️ This confirms only one direction is being detected.
    πŸ”„ Parts Already Replaced (No Change):
    β€’ Both CD3217 chips ( A2338)
    β€’ CF513, CF514
    β€’ DZF676, DZF686
    Key Voltage Readings:
    Signal / Point Value
    C20 PP3V3_S2_UPC 3.3V
    C22 PP3V3_UPC1_LDO 3.3V
    E22 PP1V5_UPC1_LDO_CORE 1.5V
    L18 USBC1_3V3LDO_EN 1.79V
    RF901 0Ξ©, 1.79V
    RF112 100K, 1.79V
    CF110 3.79V
    CF115 3.28V
    RF100. 3.28V
    Possible issue:
    USBC1_3V3LDO_EN only shows 1.79V β€” not a full 3.3V.
    Could this be preventing LDO or CC detection logic from working properly?
    ❓ Looking for Advice:
    1. Should USBC1_3V3LDO_EN be a full 3.3V?
    2. Besides CD3217, are there any other components that could interfere with CC line detection or LDO enable?
    3. Has anyone seen a similar β€œone orientation only” USB-C issue β€” and what was the cause in your case?
    βΈ»
    Any tips or guidance would be greatly appreciated πŸ™
    Happy to provide schematics/snippets if needed.
    Thanks in advance!​
  • mon2
    • 14673
    No, it is ok if EN pin on the LDO @ UF115 is 1V or higher to enable this LDO.
    From the TI datasheet:
    • rounin
      • Aug 2021
      • 9
      • japan
      Click image for larger version  Name:	ven.png Views:	0 Size:	106.0 KB ID:	3618538
      Thank you for your help and guidance β€” it has really made a big difference for me.
      At this point, I can confirm that UF115 is working properly, which gives me more confidence in the direction I'm taking with the troubleshooting.
      However, I still haven't found a clear cause for the issue. To dig deeper, I just purchased an iCloud-locked A2337 board online. I'm planning to use it to compare and measure the circuitry around the CD3217, hoping to spot any abnormalities.​
      • mkdj
        MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
        by mkdj
        About me, my goal and the equipment I (don't) have:
        I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
        About my issue and my goal:
        A friend of mine has a MacBook Air M1 A2337 that does not...
        04-03-2025, 08:28 AM
      • rilley
        MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
        by rilley
        I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
        I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
        My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
        And the resistor L4004 is literally burned.
        From what I see from the schematics, it does not affect any other rails, only the connection to the display...
        07-10-2024, 01:57 AM
      • Adogabriel100
        where to get trusted CD3217. Problem with A2337 Macbook Air
        by Adogabriel100
        Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
        The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
        09-06-2024, 12:06 PM
      • Skrndelj
        Apple Macbook Air M1 A2337 Trackpad problem
        by Skrndelj
        Hello all,
        I am repairing a Macbook A2337 and i have a problem
        The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
        When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
        I inspected the whole board and everything seems fine.
        Can anyone help me as i didn't fiddle with trackpad...
        06-11-2024, 04:26 AM
      • Patrick501
        Macbook Air A2337 dead at 5V/0,00A
        by Patrick501
        Hey,
        I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
        USB Tester: 5V / 0,00A
        PPBUS_AON: 12,3 V
        PP5v_S2: 0 V no short
        PP3v3_S2_UPC: 0 V no short
        PP1v25_S2: 0 V no short
        PPDCIN_AON_CHGR_R: 5 V
        no enable signals for the S2 rails by the U8100
        both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
        PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
        PP1v5_UPC0_LDO_CORE:...
        11-29-2024, 02:47 PM
