Sony HCD-HX80R Amplifier Volume Control Problem
  • crackedprint
    • Sep 2022
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online searches and come up blank. Does anybody have any suggestions please?
    The CD player and FM tuner work other than the volume problem.
  • crackedprint
    • Sep 2022
    I have made some further progress with the Sony HCD-HX80R. The volume control does not work the way that I had assumed. A functional description to go with the block-diagram in the service manual would have been nice.
    In the block-diagram IC501 (BD3499FV) is labelled 'INPUT SELECTOR, ELECTRICAL VOLUME, SURROUND / TONE CONTROL'. The data sheet shows that it is capable of performing a volume control function in dB. However, it is not used to control the volume. The System Controller always sets it to either -infinity or -12dB. This is what is causing the volume to go from nothing to loud when the volume is increased from MIN to 1.
    This hi-fi unit does not have a conventional audio power-amplifier. The power amplifier is completely digital (presumably class D).
    The actual control of volume is in the digital domain, in the Stream Processor of the power amplifier. The Stream Processor is IC705 (CXD9788AR). Unfortunately I can't find a datasheet for this part. However it has a serial interface and I have had a look at it with an oscilloscope. When taken out of standby, the System Controller sends a scree of data to IC705 via its SCLATCH, SCSHIFT and SCDT, pins 23, 22 and 21. The System Controller then sends it a little burst of data about once a second. I have no idea what that is meant to do. However, when I turn the volume knob I can see additional data being sent that is associated with the knob being turned.
    I decided to stop control data to IC705 completely to see what the effect would be. There are resistors in series, so I grounded IC705 pin 22. Behavior is exactly the same with the serial communication disabled. I therefore suspect that the serial port on IC705 is faulty.
    The System Controller IC301 in on the Main Board and the Stream Processor is on the AMP Board. They are connected together by a fairly long ribbon. The AMP board connects to external speakers via long lengths of flex. My guess is that this failure is the result of a thunder storm.
    I have ordered a replacement CXD9788AR, but I am not sure how reputable the supplier is. We shall see...
    • crackedprint
      • Sep 2022
      I eventually managed to obtain a replacement CXD9788AR stream processor from Alltronic Computer Singapore. This has cured the fault. The volume control now operates correctly.
      So, in summary:
      Symptoms: The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
      Cause: Faulty CXD9788AR stream processor IC705.
      • Chungalin
        • Jul 2014
        • 429
        • Spain
        • Films, film music, computers
        Thanks for the explanation of your case and good that you found a real replacement for that Sony IC. Sony didn’t publish datasheets for their S-MASTER ICs, because they didn’t sell them to third parties.
        I’ll need to buy one CXD9788AR for a Sony HCD-MX700Ni and I’m afraid of counterfeits. Some of them are evident, but not others. In my case, OUTR1 output PWM stream is missing. OUTL1 is apparently OK, but that causes right speaker output mute.
        • Chungalin
          • Jul 2014
          • 429
          • Spain
          By the way, has anyone tested if CXD9788AR and CXD9843AR are equivalent? They have the same package and pinout, comparing from schematics.
          • Chungalin
            • Jul 2014
            • 429
            • Spain
            I did it myself, accidentally. Quick answer is YES.
            To fix the HCD-MX700Ni, instead of gambling in AliExpress pretending to purchase "original" replacements, I bought a cheap used Sony home cinema with DVD problem that I previously confirmed that it uses CXD9788AR. This way I buy 3 units of that IC (6 channels). Upon arrival, first surprise is that, instead of CXD9788AR (as stated in service manual), it has three CXD9843AR. So this is the first evidence that they’re interchangeable. I extracted one unit from the home cinema and soldered it to my board, success.
            • Coert van Dorsten
              Sansui Integrated Amplifier replacement volume control troubles
              by Coert van Dorsten
              Hi all you clever electronmic gooroos!
              I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
              10-15-2025, 02:54 PM
            • klausman
              Sony TA-F511 hifi amplifier: mysterious DC offset on speaker out after short
              by klausman
              So I was repairing/cleaning a Sony TA-F511 (service manual available on Elektrotanya, or I can attach it here). Sony had smeared gobs and gobs of heatsink compound all over the heatsink, and it had gathered a lot of dirt (and become rock hard), so I cleaned it all and replaced it with silpads. Except, like the [expletive] idiot that I am, I forgot the silpad on one of the power transistors, Q610, 2SC3907, the NPN transistor of the right channel.
              When I turned the amp on, there was that dreaded electric sparking buzzing noise and some smoke, though I was quick enough to turn it off;...
              03-12-2026, 08:37 AM
            • redwire
              Onkyo TX-SR607 replacement volume control encoder
              by redwire
              I had an Onkyo SR607 with a volume control encoder not working, turning the knob up the volume number would move around crazy and not work reliably.
              Took it out and apart and no, it's not oxide or cleaning, lube required etc.- the metal is simply worn out. It's a 30mm part with metal bushing.
              Volume control encoder Onkyo P/N 25065655W, Alps EC12E2425 is some oddball variant I could not find. I did the dig and tried replacement part Alps EC12E2420803 and it works/fits just like the original. Mouser 688-EC12E2420803 for $3.00
              09-09-2022, 08:59 PM
            • NXTPRO
              Sony Bravia KD-55X8000G stuck at Sony Logo
              by NXTPRO
              My Sony KD-55X8000G TV is stuck on the Sony logo. I tried disconnecting LVDS and turning it on again, but the TV only showed a white LED (not blinking) and nothing else. Then, I reconnected LVDS, and it still only showed a white LED with the Sony logo. It seems it's not entering update mode. When I used a USB drive and named the firmware file upgrade_loader.pkg, the TV displayed "Updating..."(Sample image attached) but after about a quarter of the process, it restarted and got stuck on the Sony logo.
              Board: 1-982-454-51
              04-03-2026, 07:28 PM
            • dimis7
              SONY KD-65X85L
              by dimis7
              I have a SONY KD-65X85L with backlight an possibly main board issues.
              Does anyone have the service manual for this set?
              Symptom was: display start with backlight on and sony logo, after few seconds sony logo disappear and TV remain dark (backlight on). Put it in stby with remote, then back on with remote and backlight not start again.
              Fiddling around with connectors etc and now the backlight never come on again. But i can see the sony logo with a flashlight.
              One time i manage to reset it and i saw the android set-up wizard (with...
              10-20-2026, 04:19 AM
