Nakamichi Soundspace 5 - headphone works normal, both speakers volume very low at max
  • R_J
    • 9558
    Re: Nakamichi Soundspace 5 - headphone works normal, both speakers volume very low at
    Thats good to know it works like this, this is just for testing and should not be left like this. So the problem is in that mute circuit, too bad you don't have the remote to toggle the mute line. I would check all of those digital transistors in that circuit, they can be hard to test but try and compare the readings between same numbered transistors. one might show a real difference.
    • beetle1303
      • Jul 2019
      • 279
      • Singapore
      I was overjoyed, and assembled everything back and enjoy the moment for a little longer.
      I didn't mentioned it, but I did grounding at various points from pin30 CDC and output pin of Q507, Q508 and Q509. Only when output pin of Q509 is grounded then speakers sounded. So I think Q509 could be the culprit.
      I ordered online a transistor meter, now waiting for delivery. I will do some testing with this new meter to see if I can pinpoint it. Will report back later.
      • beetle1303
        • Jul 2019
        • 279
        • Singapore
        Originally posted by budm
        You will have to watch out if the PRE_Mute is no longer in the circuit, it can get loud pop on the speakers and damage the speakers.
        I was really excited to have sound!!
        I didn't notice any popping sound when switching on/off the main power supply, nor turning from/to standby/on mode, neither when switching sources between radio and CD player. But I did noticed a low pop sound when turning the volume up and down!
        Any idea when would this PRE-Mute line be turning on/off in a normal working system like this?
          You need the remote to see if you can turn Muting function on and off or not, may be it was stuck in the Mute mode when it was set by the remote Mute button. I do not see any info in the service manual for resetting the system to the default condition.
          • beetle1303
            • Jul 2019
            • 279
            • Singapore
            I'm doubtful I can get a remote control locally...
            Can you point out where is the remote control sensor input in the circuitry? Is it possible to force feed a voltage in to simulate an input from remote control?
            • R_J
              • 9558
              Can you check the voltage on CN504 pin 3 (MUTE) this plug goes to the cd mechanism, maybe the fault is from there, Page 44 (pdf,47) has a LSMUTE line that should be 5 volts. There is a mute line from U501 pin77, that turns on Q522, that turns on Q521 that supplies ZD521. That MUTE line connects to R539 on page 41 (pdf,44)
              So maybe that is where the problem is? Have you tried the CD? does it work?
              • beetle1303
                • Jul 2019
                • 279
                • Singapore
                #27
                CD (changer) works all along. Prior to grounding R570, radio and CD works in headphone mode, and after grounding, both radio and CD works with speakers volume.
                Readings at CN504 pin3 (MUTE):
                1) standby mode: 0v
                2) power-on: 0v
                3) switching/looping the audio sources:
                Radio->CD->Tape->Aux
                0v -> 5.14v -> 0v -> 0v
                *noting that switching out of CD to Tape->Aux->Radio quickly the voltage remained at 4.95v, and dropped to 0v after 15-20s
                I am not able to follow the rests of the circuitry to figure out what to measure and how to measure...
                • R_J
                  • 9558
                  When you switch from Radio to CD, the mute line at CN504 changes from o to 5v. Check the voltage on Q507 base and switch from Radio to tape, Does the voltage change? Then check the voltage on Q508 base and switch from Radio to CD.
                  If the voltage on Q507 base changes, it should also change the state of Q508 and then Q509 which should change the Premute line.
                  • beetle1303
                    • Jul 2019
                    • 279
                    • Singapore
                    #29
                    Q507 Base voltage:
                    Standby mode: 1.2v
                    Power on: 1.1v
                    Radio: 1.1v
                    CD: 4.7v
                    Tape: 0.8v
                    Aux: 0.8v
                    Another word, switching in and out of CD, voltage changes. Switching in and out of the sources, no changes.
                    Q508 Base voltage:
                    Standby mode: 11.98v
                    Either at this point, or when I turn on the system while the red probe still on pin2- the fuse Blown!
                    Based on the attached diagram, base is pin2, correct? If not, could it caused the fuse to blow?
                    *I have 1 last fuse, so I should wait before continuing on Q508 and Q509.
                    • beetle1303
                      • Jul 2019
                      • 279
                      • Singapore
                      #30
                      I replaced the fuse, and decided to check on somewhere else to see if there is a +ve input to Q508. So I traced from U502 pin8 Mute to:
                      Q504: pin1 0v, pin2 0v pin3 0v
                      Q505: pin1 11.9v, pin2 0v, pin3 0v
                      Q506: pin1 11.9v, pin2 0v, pin3 11.9v (switching from radio to CD to tape same readings)
                      Does it mean Q506 is problematic?
                      • R_J
                        • 9558
                        Q506 could be shorted, emitter to collector. With 0 volts on the base the trasistor should be open, and have no voltage on the collector.
                        I don't see how checking the voltage on Q508 base can blow the fuse
                        • beetle1303
                          • Jul 2019
                          • 279
                          • Singapore
                          #32
                          From what I googled: Q504,Q506 and Q506 are all PNP transistors, pin2(In) is base, pin1 (Grd) is emitter, pin3(Out) is collector.
                          At power-off, DMM set to 200KOhm, black lead on pin2(In), red lead on pin1 & pin3, the readings are:
                          Q504: 10.0 / 1(open?)
                          Q505: 154 / 45.4
                          Q506: 79.2 / 52.8
                          When I reversed the black and red leads (red on pin2)
                          Q504: 85.7 / 91.4
                          Q505: 1(open) / 1(open)
                          Q506: 22.1 / 70.2
                          Is there anything unusual about these readings?
                            Are you checking those resistance with the AC cord removed from the outlet?
                            • beetle1303
                              • Jul 2019
                              • 279
                              • Singapore
                              #34
                              Yes, AC cord off the outlet, and power supply pack cable disconnected from the main board.
                              • beetle1303
                                • Jul 2019
                                • 279
                                • Singapore
                                #35
                                Also, some readings were instantly sat a stable reading, while others starting at lower number climbing slowly and stabilise at almost doubled the initial reading.
                                • R_J
                                  • 9558
                                  You will never find the problem doing this type of measurement. Any voltage left in the circuit from discharging caps, etc. will throw off the meters resistance readings.
                                  • beetle1303
                                    • Jul 2019
                                    • 279
                                    • Singapore
                                    #37
                                    Noted. Pardon my novice learning journey, every answered is a lesson learnt.
                                    So these readings indicate if Q506 shorted or not? If not, how do I determine if Q506 is shorted Emitter to Collector?
                                    • R_J
                                      • 9558
                                      I'm not sure what you are measuring here:
                                      what does this mean????
                                      1(open)? Are you saying it reads 1 Ω and YOU believe the reading is OPEN?
                                      What is the reading on YOUR meter when set to ohms when the leads are not touching? This is OPEN
                                      When the leads are shorted, What is the reading on the meter? this is a SHORT.
                                      Don't use 200k range to check for shorts etc. in that range a wet noodle will check shorted.
                                      Put your meter in diode test or the lowest range (200Ω), Check between emitter and collector of each transistor. If it is reading 1Ω, the transistor is shorted.
                                      These are digital transistors (they have built in biasing resistors) so the will not check the same as normal transistors.
                                      These have 10k resistors in the base so the will likely check open when testing.
                                      • beetle1303
                                        • Jul 2019
                                        • 279
                                        • Singapore
                                        #39
                                        My DMM - set to Resistance Mode, leads not touching shows 1, touching shows 0.
                                        Reading on Q505: 1(open) / 1(open) means when the red lead is off, it shows 1, touching pin1 & 3 both remained 1 (nothing happened).
                                        Set to 200Ω, it shows 1 and doesn't change.
                                        Set to 2000Ω same thing.
                                        Set to 20kΩ it jump up quickly then to 1
                                        Set to 200kΩ then the numbers are readable.
                                        Yes, my DMM is a diode/continuity mode. Leads not touching shows 1, leads touching shows 002 and beeps. In this mode, all readings taken are stationary at 1, one or tow readings will flash a number then stayed at 1.
                                        So digital transistors like these should be removed from circuit in order to test correctly?
                                        • R_J
                                          • 9558
                                          These digital transistors can not be checked in or out of circuit because they have a built in resistor in the base circuit. When you check a normal transistor, you use diode test because it applies more voltage across the junction so you can measure the voltage across the junction. in most cases .6xx volts. (similar to measuring a diode)
                                          But because of the 10k resistor in the base you can't measure the forward voltage drop of the junction. the transistor will check like it is open.
                                          The only real test you can do would be the resistance from emitter to collector and wheather it is a short or open. but you need to use the 200Ω range or use the diode test.
                                          I had no idea the 1 you refered to was open circuit, what is the difference between 1 and 1? 1 being open and 1Ω being short?
                                          This is why voltage checks work better. Take Q504 for example. this is a digital switch. the base controls weather the switch is on or off
                                          with 0 volts on the base, the switch is OPEN
                                          with about 2~5 volts on the base the switch is CLOSED
                                          When the there is 2~5 volts on the base and the switch is closed, the collector is shorted/connected to the emitter and in this case ground.
                                          • karthur
                                            Vizio D65x-G4 Volume changes on its own
                                            by karthur
                                            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                            06-05-2025, 08:13 AM
                                          • MasterCap
                                            AVR-2802 no audio, chip questions
                                            by MasterCap
                                            I do some hobby repairs mainly of my own junk, and I don't know much programming level repair/mods.
                                            I got the AVR-2802 over the weekend, sold as working of course, and it worked for 1 night, using EXT. IN 5.1CH jacks, then after power down, the audio never came back. I've reset it, and get nothing on EXT IN or PHONO, despite having everything set right, hooked up right. I can hear lots of relays work tho.
                                            I just want it for 5.1CH analog inputs , for PC surround sound. I'm not worried about the video or most of the digital stuff for now.
                                            So far I've traced...
                                            01-15-2024, 10:52 PM
                                          • crackedprint
                                            Sony HCD-HX80R Amplifier Volume Control Problem
                                            by crackedprint
                                            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                            I have tried a Cold Reset as per the service manual.
                                            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                            I have looked all the way through the service manual and tried many online...
                                            01-21-2025, 12:18 PM
                                          • CapLeaker
                                            Dell ATX PSU won’t start, but forcing it works fine?
                                            by CapLeaker
                                            Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                            Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                            10-28-2024, 06:59 PM
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            🛠 Original Issue
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
