Crown Amp DC300A - One channel distirted, other good.
  • petehall347
    • Jan 2015
    • 4440
    Re: Crown Amp DC300A - One channel distirted, other good.
    it wouldn't harm to check all those cement emitter resistors are good
    • budwich
      • Jul 2015
      • 3097
      I checked them all... they were within the value and "accuracy" of my meter... .3 ohms (value .33).
      • budwich
        • Jul 2015
        • 3097
        you should use a blocking capacitor on the positive probe to measure AC .also if you use an audio tracer such as headphones . 0.1uf or thereabouts if i remember right
        I was thinking of trying a fm wireless headphone... using the input to the base as the "probe"... which is a phone plug / rca plug and then wireless out to the headphones.
        I am thinking that the issue might be the high DC levels around in places... so the capacitor is probably a good idea.
        • petehall347
          • Jan 2015
          • 4440
          I am thinking that issue might be the high DC levels around in places... so the capacitor is probably a good idea.
          always a good idea to use low value blocking capacitor .
          • petehall347
            • Jan 2015
            • 4440
            in my experience any amp left in a working state then doesn't work properly is either corrosion or dampness got into the board or resistors . corroded connections being the main thing .
            • budwich
              • Jul 2015
              • 3097
              I agree. I have been measuring components at the component wires. I should probably do some more check at the board layer / junctions just in case it is a poor solder joint as opposed to a faulty component.
              This unit is over 40 years old so capacitors of their time might have an issue (drying out or otherwise) which to me is a "distortion maker".
              • Agent24
                I see dead caps
                • Oct 2007
                • 5071
                • New Zealand
                #27
                I have to investigate the meter but I am sure that I have used it to check the incoming AC frequency on a few house circuits...
                Some probably can, I know mine doesn't.
                -David VanHorn
                • budwich
                  • Jul 2015
                  • 3097
                  I think the problem with the meter use was what point I was probing. I don't really know where to look for signals.... at the base inputs to the transistors, at the emitters, other places? In the case of the "first attempt", I put the positive (red lead) on the base of the output transistor "group" that is associated with the positive rail. Nothing really got measured there but the meter did try to do some counting as but basically sat at 0. The next attempt was at the base lead of the transistor group of the negative rail. It is quite likely that this caused a current flow into the based from the chassis ground (black lead) towards the red lead. I suspect the meter doesn't expect to see "reverse flows" and has limited / no "blocks" to prevent it... maybe.
                  Anyway, I will do some more thinking / looking / checking before blindly going forward probing things.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5071
                    • New Zealand
                    #29
                    First place I'd be checking is the output pin of that dual opamp, IC1.
                    Looks like pins 1 and 13 are the outputs. Not sure which channel is which. They seem labeled 1&2 not L&R.
                    Hard to read the text though. Can you take a better photo at all, or do a scan?
                    -David VanHorn
                    • budwich
                      • Jul 2015
                      • 3097
                      I guess I did some damage somewhere with my "unknowing probing". Replaced the speaker line fuse. This was on the good side of the amp. At the time, I was checking to see what I would see on the good side with the 1khz input signal.
                      Anyway, after replacing the fuse, turned on the amp at low volume, then tried to listen to the test cd again. The amp ran for about 30 seconds, noticed no sound coming from the good side. At this time, the amp shut down because it had blown the main line fuse (10 amp)... oh oh. So it appears I made my problem worse with some sort of short somewhere but not an immediate short as it did power up for a bit as opposed to an instant fuse blow.
                      • budwich
                        • Jul 2015
                        • 3097
                        not sure if this helps as my scanner is pretty old. The circuit diagram is a "fold out" so it takes two pages to get the whole schematic in. Note the page separation and even though it looks like it aligns, it is an overlapped view and not "thru flow" from one page to the next.
                        • andy1
                          • Apr 2019
                          • 9
                          If you say that you may have further damaged by blowing the working channel, do a no load check. By that I mean disconnect the speakers, replace the blown fuses with the correctly rated fuses, switch on the amp and see if you get any DC voltage on the speaker terminals of that channel. If there is DC present (I think it will be!) it means that you have blown output transistors. You could also have the driver transistors blown as well.
                          You could always check each transistor out of circuit. If you find even 1 of them blown, replace the whole lot. These direct coupled stages will damage everything if one gets blown.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5071
                            • New Zealand
                            #33
                            Thanks, that is a lot better than before, but can you try at a higher resolution? 300 dpi? Some of the component values are still hard to read, unfortunately.
                            -David VanHorn
                            • R_J
                              • Jun 2012
                              • 9607
                              see if this is any better
                              • budwich
                                • Jul 2015
                                • 3097
                                thanks for the assist, RJ
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  While after a "deep sigh" and more reading and "thinking", I started back on this. I was able to "isolate" the output transistors (at least the collector to emitter section) without demounting them from the board.... demounting all transistors at this stage is probably not happening as this is significant effort and an unknowing experience (meaning I don't know how to go about the desoldering of such devices). Using a "gross resistance" test of the CE, I found two 2n5631's on the channel that I "took out with my probing"... these were shorted. I found two 2n5631's on the distorted channel... these had measureable resistance in both directions as opposed to "infinite" in one. I also found one .33 emitter resistor on the "blown channel" (all others on both channels are OK still).
                                  Baby step forward... maybe... :-)
                                  • circuitmonkey
                                    • Feb 2018
                                    • 26
                                    Just a little friendly advice. Maybe consider wiring up a dim bulb to share the current when an "oops" happens. While it won't completely eliminate damage to you or the components, it will greatly reduce the risk and in many cases mitigate damage. There are plenty of good diagrams on the Google machine. It also works pretty well as a fault tester. If you apply power and the bulb(s) stay lit, you have a significant short and no further distortion testing can really be performed until the shorts are gone. Also, without having an auto transformer, this will help limit inrush current when you first power it up. It's a cheap process if you're creative. Around $10 at Home Depot.
                                    Channel distortion is usually (not always) caused by bad caps or leaky transistors in the audio signal chain. It's really difficult (by no means impossible, but a lot more guess work) to narrow down the noisy component(s) without using a scope or signal tracer. One mismatched transistor in the pre-amp section could cause audible distortion. While replacing one or two might fix the issue electrically, not matching the transistors could result in distortion. Might get lucky, though. Cold/cracked solder joints can also cause cracks and pops.
                                    Also, film caps (which are not generally marked for polarity anymore) can cause distortion if they are not oriented correctly. While they are said to be bi-polar, they have a "foil end" and that needs to point to the path of least impedance. I don't think that is your issue as it developed over time, but something to consider if/when you need to change them. Also, hard to test polarity without a scope, although I'm sure someone out there has figured out a way.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      thanks... good idea with the "limiter bulb". The rest of the "hints" are a good guide also in my "learning curve". At this point, I am truly hoping to at least bring back the "blown channel" with some luck and carry that luck (and "learning") over to the distorted channel... maybe.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        continuing to do "on board checks", I can only further do E-B junctions on the transistors (no way to easily isolate the C-B due to multiple connection points). The diode voltage test of the junctions is good on transistors that had good resistance measurements across C-E. On the short transistors on the "blown side", the voltage was low / 0. On the two transistors that "failed" the resistance C-E test on the distorted side, they had good B-E voltages.... that would appear to confirm / indicated may be why the channel works but is distorted... maybe.... leakage across the C-E junction but functioning "control".
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          Progress has been measured in "baby steps" over weeks / months.... some due to my slowness along with very slow "off shore sail boat times".... ultimately I hope I can remember how to put things back together if I ever get that far. :-)
                                          I got some MJ15024 replacements for the originals output transistors. At this point, I only replaced two on each channel that I found which "appeared" to fail C-E resistance testing when compared to others (this is with the E isolated from the board... can't isolate B and C without totally desoldering / demounting).... either shorts or leakages. I did this at this point to limit the amount of "hands / soldering damage" that my "skills" will do to this thing.... :-)
                                          Also replaced one .33 ohm resistor which was open.
                                          Built my "bulb limiter" supply to hopefully reduce the "shock" of the first "plug in"... of course, I did a bunch of checks for shorts and comparing channel 1 to 2.
                                          I plugged the amp into the bulb limiter and hit the switch. The bulb lit brightly for a second or so then basically dimmed to almost dark. The switch light remained lit so the limiter worked at limiting the current going to the amp and it would appear that I have no "immediate shorts". At this point, I am taking a deep breath, thinking on things and will go back to check for voltage at a few points to see if maybe there is enough juice going thru the limiter to get the amp "operational" at the basic electric level at this point. Hopefully, some baby steps will happen sooner as opposed to later.
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • quickname
                                            Cyberpower 1500AVR UPS repair
                                            by quickname
                                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                            I decided to verify that the batteries were...
                                            11-12-2023, 09:57 AM
                                          • dicky96
                                            Hitachi V19B01922 Channel Tune problem
                                            by dicky96
                                            Hi Guys
                                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                            He also has an LG TV, so three screens in the bar
                                            I installed three Satlink ST-6503 DVB-T Modulators
                                            This model https://www.aliexpress.com/item/32916553905.html
                                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                            02-09-2023, 09:20 AM
                                          • sima112
                                            Marantz pm 6005 right channel not worknig
                                            by sima112
                                            Hi guys,
                                            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                            01-30-2023, 12:11 PM
                                          • Logistics
                                            Supermicro X10DAX and Quad Channel
                                            by Logistics
                                            So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
                                            09-10-2023, 05:12 PM
