Crown Amp DC300A - One channel distirted, other good.
  • budwich
    • Jul 2015
    • 3097
    Re: Crown Amp DC300A - One channel distirted, other good.
    not that I can detect but then again, I am currently only running it into little speakers.
    • petehall347
      • Jan 2015
      • 4440
      #162
      i am wondering if the outputs are working . there should be over 600 mv at their bases and rail voltages at the collectors .
      • budwich
        • Jul 2015
        • 3097
        that's an interesting question. I am going by my scope of 1khz input 200-300mv p-p that shows up as 1-2v pp at the speaker outputs. Seems rather meek. :-) Maybe I am not recalling the numbers correctly. I will have to double check. The rail voltages are there as that is always the first thing that I check (+/- ~60).
        edit: just checked, .4v p-p input to the main board results in 8+v p-p at the speaker terminal.... so possibly with a 2v p-p input would result maybe in 40 v p-p. "lightly speaking" into possibly a 8ohm @ 1khz (speaker impedance response might be less), 200 "watts" average...maybe given the "grossness" of my "thumb calculation" (forgetting about the 1/2 factor for "AC")
        • petehall347
          • Jan 2015
          • 4440
          #164
          could be just the driver transistors powering the speakers . see if they are hot to touch
          • budwich
            • Jul 2015
            • 3097
            I "touched" them with a thermal reader... all 4 are running about 28-30C. The opamp is running about 40C. Most other components are seeing 25-27C.
            I think they are OK and just doing their normal job... hopefully.
            • petehall347
              • Jan 2015
              • 4440
              #166
              look up the specs ..they might be in tolerance running small speakers . i dont have schem open here and my pc is too busy recovering a hard drive . just browsing the net is painful slow
              • budwich
                • Jul 2015
                • 3097
                sorry, not sure that I understand. you are saying at the low power needed for the small speakers that I am running, they might be the only thing operating and that the slight temperature is just that. When the "big boys speakers" are connected, then things will fall apart. :-( I haven't found a spec for the rca 61061 yet but some one indicates that 2n3440 can be used so I will try that info. not sure what I am actually looking for.
                • petehall347
                  • Jan 2015
                  • 4440
                  #168
                  from what i find they are 1 amp or thereabouts
                  • budwich
                    • Jul 2015
                    • 3097
                    ok... so then you are saying that in a nominal 8 ohm load (speaker), with 8 volts, the system might only be needing 1 amp which could be supplied by just the pre-driver.
                    But if the outputs are not on, how is that current finding it way to thru the "non-turned on" outputs without significant distortion?
                    • petehall347
                      • Jan 2015
                      • 4440
                      #170
                      good question . i do not know the answer .all i know is some drivers are capable . i need to look at the schem again to see how the signal gets through but there are usually something like 100 ohm resistors between the drivers emitters connecting to the centre line . .
                      • budwich
                        • Jul 2015
                        • 3097
                        yes you are right. There is a "path" by the first driver thru a 180 ohm resistor to the output.... but IF that path was used as the "only source", I think that the resistor would be "cooked" as it is only a 1/4 watt resistor. I will check what kind of voltage I see going on them.
                        On the meter side of things, maybe the meter has an issue measuring voltage on very low resistance components / wiring such that the "leakage current" going into the "high impedance" measuring component (for voltage measurement) has some sort of "restriction" on how it handles it. I see a momentary voltage of a 30-40 mv flash on the screen and then it moves to zero.
                        • budwich
                          • Jul 2015
                          • 3097
                          So user error comes into play. I needed to get of "auto" mode and go to selected range. Once on a "3 decimal range", I can measure voltages across each .33 resistor. They range from 6 mv to zero although zero is probably not "true" as it flickers from 1mv (smallest measureable increment).
                          Based on your earlier comment ("there should be some small voltage ... 4mv..."), it would appear that some are seeing such a thing. IF true, it would appear that there is some differences across the outputs.
                          • budwich
                            • Jul 2015
                            • 3097
                            Couple of hours running with the "big" jbl sovereigns at moderate volume... not sure my ears or "heart" (fear of blowing things up) can take much higher. Might be psychological, but the sound seems brighter and maybe a bit clearer than in the distant past (its been a while and my ears aren't getting any younger). Hopefully, things will hold up for while so I can move onto a "lost speed revox reel to reel"... :-(.... :-)
                            Thanks for the continued guidance along the way, it has help get me headed in good directions.
                            • petehall347
                              • Jan 2015
                              • 4440
                              #174
                              main heatsink should be warm . if you set bias to spec you will just have to see how it goes .
                              • budwich
                                • Jul 2015
                                • 3097
                                In the current operating setup area, get access to things is difficult. Personally, I can't remember ever feeling heat coming out of the amp area although I can't say that I listen at extreme volume levels so I am not sure that the amp is pushed at any time. Will see how it goes. I am enjoying listening to "plain stereo" again.
                                • eccerr0r
                                  old X58 triple channel board... memtest86 memory speed?
                                  by eccerr0r
                                  Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                  Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                  Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                  06-28-2025, 09:06 AM
                                • quickname
                                  Cyberpower 1500AVR UPS repair
                                  by quickname
                                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                  I decided to verify that the batteries were...
                                  11-12-2023, 09:57 AM
                                • dicky96
                                  Hitachi V19B01922 Channel Tune problem
                                  by dicky96
                                  Hi Guys
                                  I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                  He also has an LG TV, so three screens in the bar
                                  I installed three Satlink ST-6503 DVB-T Modulators
                                  This model https://www.aliexpress.com/item/32916553905.html
                                  These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                  02-09-2023, 09:20 AM
                                • sima112
                                  Marantz pm 6005 right channel not worknig
                                  by sima112
                                  Hi guys,
                                  I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                  01-30-2023, 12:11 PM
                                • Logistics
                                  Supermicro X10DAX and Quad Channel
                                  by Logistics
                                  So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
                                  09-10-2023, 05:12 PM
