Crown Amp DC300A - One channel distirted, other good.
  • petehall347
    • Jan 2015
    • 4440
    #141
    Re: Crown Amp DC300A - One channel distirted, other good.
    c6 would affect both channels . it looks like its job is smoothing that 5v supply to the input offsets .
    it could maybe affect the biasing as well .
    • budwich
      • Jul 2015
      • 3097
      shielding the heating away from c6 and more on to the two transistors (mpsa92 - q101 / q201) cleans the signal up. Back at the start, I had found a problem with q201 whereby its was not conducting which cause channel two to have high DC. I replaced it with a mpsa93 which has a greater voltage spec and it was functional. Not sure I ever looked close at the 1khz tone other than ear listening. Later, while chasing channel one issues, changed q101 with the same mpsa93. Sometime there after, the warmup buzz started (not sure how immediate is was).
      I am pretty sure that the MPSA93 might be the issue... more with channel one than channel two so perhaps some characteristic in their makeup is important and different. I have a few others that I will check and compare parameters with the checker to see if any pops out. I guess I will drop in another. One thing, the two are in a "clip on" heat shield that isn't grounded, just plugged with legs into the board. Wondering if maybe some form of "EMI" is "coupling" into the bodies so some strange form. ???
      • budwich
        • Jul 2015
        • 3097
        I got my numbering mixed up. The original part is an mpsa93 which I have replaced with mpsa92's.
        edit... while replacing the replaced mspa92 didn't help. I, then, "adjusted" my heating technique which might not be as good as it needs to be. Anyway, cap C5 which is beside the mpsa pair seemed to be "helped" with the heating. I replaced it and things appear to be good / clean across the spectrum of test tones. I will run it a bit then let it cool off and see what the result of some "cold starts" will be. It could be a good day today. :-)
        • budwich
          • Jul 2015
          • 3097
          Unwisely, I tried a "full volume test" ( set on the pre amp). It causes the speaker line 2amp fuse to blow on channel two. :-( The channel no longer operates, channel one continued to function (is still functioning). First check, blew the .33ohm emitter resistor on the Q212 output transistor (second from the "end of series"). I have to go thru more checks to see what else is gone as I don't believe a blown emitter resistor would stop the sound out of the channel.
          It was sounding good prior to the poor judgement call.
          • petehall347
            • Jan 2015
            • 4440
            #145
            too much current flowing through the outputs will burn those resistors . and the outputs . need to do a regroup on this one as cant remember where we are up to as in like are all outputs installed or just a pair and stuff like that .
            • budwich
              • Jul 2015
              • 3097
              I have only been running with all output transistors in place. I am not sure that I understand how the outputs work to provide signal / current. For example, as a "quick calculation", the 5w .33 blew, so that it indicating more than 5w. Then, that's indicating just under 4A flowing thru that one. IF so, that doesn't seem like enough current to blow the transistor. Further, IF the totally output of the amp was possibly fused on the speaker for 100W (2A) then I am not really understanding why the higher current assuming that it stages was "reasonably balanced" which would be 16A (4 "stages" X 4). Obviously, I don't understand some "subtleties" especially around "matched outputs"... :-) Having said that, I am not sure how a "minor mismatch" could cause such a wide current range difference on each stage taking out one stage and not all the others.... especially if one stage fails, then would not the others try to make up the current demand causing them to blow also?
              • budwich
                • Jul 2015
                • 3097
                There are currently three replacement transistors (mj21194) in the channel two output stages. One on the negative leg and two on the positive leg. All three appear to be blown; one open, and two shorted. None of the original transistors appear to be impact although I haven't demounted them for complete checking. I will replace the replacements to at least see if I can get back to some semblance of good. Go from the result. I guess "amp rocket science" IS rocket science. :-)
                • petehall347
                  • Jan 2015
                  • 4440
                  #148
                  i would be testing with one pair of outputs . q210 q215 . and making sure voltage across r233 r234 is about 10 or 20mv ish .
                  you should really have all the same outputs installed so they match .
                  or you could remove all outputs and sub in 1k resistors between where base emitters connect at q210 q215 . this is to keep the feedback path intact . then check output dc offset 0V and also base voltages that should be about 600mv at idle . do not have any loads attached to speaker terminals for now .
                  • budwich
                    • Jul 2015
                    • 3097
                    I assume the "r234" was a mistype and you mean r239 (the negative leg). To do the suggested test, of only one output pair, I would pull the .33 resistor on all the others? Of course, this would be with no speaker attached.
                    As for having all the same output tr's, that would be tough at this point.
                    I am also going to check the pre-amp (ic150) a bit to look at the signal output along its volume range (0-10).
                    • petehall347
                      • Jan 2015
                      • 4440
                      #150
                      yes the 2 emitter resistors 0.33 ohms .
                      you can leave the others there as won't be connecting to anything with outputs removed .
                      • budwich
                        • Jul 2015
                        • 3097
                        OOPS... I screwed up the transistor numbers earlier... they are mj15024 not mj21194. sorry.
                        • budwich
                          • Jul 2015
                          • 3097
                          checked out the output from the ic150 pre-amp. Didn't see anything unusual thru its volume range. At "full volume" on a 0db 1khz wave, its output was 1.8vP-P. So that's seem reasonably OK. Probably found the last of the blown components on channel two, q220 (2n4125) which is the equivalent of the channel one component that was taken out during its "not working" previously in this exercise. Still doing some resistance checks / comparison from side to side before powering back up, more for general "scope of design numbers / what's being seen" as even with the blown components, the amp powers up (no input / output). Hopefully, I will get back to some form of normal shortly.
                          • budwich
                            • Jul 2015
                            • 3097
                            :-))) operational again. Checked the bias (r132/r232). Channel two was within spec at around .314v while channel one was low at about .28v. Changed out the "selectable bias resistor"(r129) for a lower value (82ohm-> 47ohm) brought the voltage up to .32v.
                            Will let it run again for a while with my fingers crossed. :-)
                            • budwich
                              • Jul 2015
                              • 3097
                              Its been running, medium volume, for a while, 1 hour here and there at a time. One thing that I am wondering about, when measuring the "bias voltage' on r132 / r232, it is within the spec of .314 or so (no gain / input). However, when playing some input, the voltage goes up into the .44v or so area on the r132/r232 which are associated with the positive side of the outputs while on the negative side, the voltage go down to about .2v on the r139/r239. Of course, I don't know what to expect but maybe was expecting it to remain somewhat "balanced" / similar for both "legs".
                              • petehall347
                                • Jan 2015
                                • 4440
                                #155
                                bias is set at idle .hence why its called idle bias ..it will change in normal use ..its sort of like a starting point . tickover if you like .
                                lets say its set too low it will never get high enough in use and distortion will happen ..if set too high it will go over the top in use and maybe hot things up a bit .
                                it can be set more accurately with a distortion analyzer . i have never had one and never been a problem .i do have various scopes i could use to look at crossover distortion and set so its gone away but never bothered . i just go off the manual settings if available . and see how it sounds and check it isnt getting too hot .
                                • petehall347
                                  • Jan 2015
                                  • 4440
                                  #156
                                  one thing i do check is voltages across each output transistor emitter resistor to see how the current is being shared .
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    that's the strange thing. I never see any voltage across those .33 resistors on either the positive or negative legs of the outputs. It doesn't matter whether I have no input or constant 1khz input, or measuring AC or DC voltage. Perhaps a meter problem although other voltage measurements seem good / accurate.
                                    • petehall347
                                      • Jan 2015
                                      • 4440
                                      #158
                                      there should be current flowing . it will be in the low mv . could be 5mv or more likely about 10 or 20mv .
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        three decimal points shows nothing although during the initial connection of the probe, the meter shows a 10's of mv but they disappear shortly thereafter. Perhaps the meter can't see such low voltages. Having said that, in areas of the main board, it has measured 10's of mv. so I am don't know. I will let it be for now. I am getting pretty good at "cracking it open" so if need be, I will go back in at a later time... maybe. Hope to enjoy some of my JBL sovereign II again. :-)
                                        • petehall347
                                          • Jan 2015
                                          • 4440
                                          #160
                                          does the main heatsink get warm ?
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • quickname
                                            Cyberpower 1500AVR UPS repair
                                            by quickname
                                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                            I decided to verify that the batteries were...
                                            11-12-2023, 09:57 AM
                                          • dicky96
                                            Hitachi V19B01922 Channel Tune problem
                                            by dicky96
                                            Hi Guys
                                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                            He also has an LG TV, so three screens in the bar
                                            I installed three Satlink ST-6503 DVB-T Modulators
                                            This model https://www.aliexpress.com/item/32916553905.html
                                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                            02-09-2023, 09:20 AM
                                          • sima112
                                            Marantz pm 6005 right channel not worknig
                                            by sima112
                                            Hi guys,
                                            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                            01-30-2023, 12:11 PM
                                          • Logistics
                                            Supermicro X10DAX and Quad Channel
                                            by Logistics
                                            So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
                                            09-10-2023, 05:12 PM
