Crown Amp DC300A - One channel distirted, other good.
  • redwire
    • Dec 2010
    • 3912
    Re: Crown Amp DC300A - One channel distirted, other good.
    Crown DC300A Series II schematic, service manual. It looks like yours?
    Overall- there's no electrolytics in the signal path, only two in the protection circuit 25uF 15V NP (per ch) and one for 5V DC offset power for both channels C6 100uF, which I would check.
    For a quick check if things are reasonable, I would look at +/-10VDC power for the op-amps, check the idling bias current 0.34V across 5.6R driver stage and the op-amp should have around 1.35V at its output.
    It's strange to have no bias current trimpot but input offset and output offset trimpots. I think transistors were hand selected and it's a tight design.
    This means changing transistors could give bias current (heat) too high or an offset problem. For now, I would just take some voltage measurements to see what is off center.
    • budwich
      • Jul 2015
      • 3097
      Thanks. I haven't completed all the checks yet... doing baby steps. I confirmed that the startup noise is only on channel one.... two is quiet. The +/- 10v powering are both there and 10.05 +/-. I am trying not to let the thing run too long at any instance so that the noise remains in place to help with tracking things done as opposed to waiting for it to return after it has dissipated (I don't know what timeframe that occurs at... although left overnight, its there). It certainly appears to be some form of weaken capacitor.
      I did a quick check of the dc value at the speaker output (no input / 0 gain setting). Channel one (start up noise) has .015v while the other is 0v. There appears (confirms) to be some small dc value showing up at the output.
      I have yet to pull the capacitors to check their values.
      Maybe as suggested earlier, I will do a heat check on the capacitors first to see if that helps first with start up and go from there.
      • budwich
        • Jul 2015
        • 3097
        ok... I heated up the c108/c109 (they are close together so they can't really be heated individually). The good news is that the channel noise is gone at the start up so it is likely that these have lost there value when cold. I will pull them to confirm and locate a replacement source. Related to that is there anything special about these other than be "NP" electrolytics 25/15's ? Thanks again for the hints. I can feel joy returning... :-)
        first glance... it seems like a replacement for 25/15 NP might be hard to readily find... :-(
        • budwich
          • Jul 2015
          • 3097
          I manage to mangle one of the capacitors trying to get them off the board, one lead pulled away. :-( so now I need to track down some equivalent substitute for a 25uf15v NP electrolytic. Suggestions for alternate values. 33uf 25v polarized?
          • petehall347
            • Jan 2015
            • 4440
            #105
            you could use 22uf 25v NP
            • budwich
              • Jul 2015
              • 3097
              OK... will give those a try. They seem more available (at least off shore). I guess with normal tolerances, they should be with range of the originals. Thanks.
              • petehall347
                • Jan 2015
                • 4440
                #107
                where is it placed in the circuit ?
                • budwich
                  • Jul 2015
                  • 3097
                  as redwire pointed out, the two are in the "associated" feedback circuit... not directly in its path but the supporting circuitry / drive.
                  • budwich
                    • Jul 2015
                    • 3097
                    So the "slow boat" finally came in and I got some 22uf 25v bipolar caps in... not sure of the difference between NP and BP. Hopefully, it won't impact the sound / design. I only replaced the two associated with the noisy channel 1. I now have "clean" sound again on both channels, at sound levels and at idle (quiet, no sound input). I will let it run for a while to see if anything tips over with run time.
                    Thanks again for the help, hints, and guidance on this. It is much appreciated and has helped improve my troubleshooting and outcomes along the way.
                    • budwich
                      • Jul 2015
                      • 3097
                      :-( not quite there yet. On a cold morning start up, just powering up the amp, channel one has a significant buzz (again). Was surprising since the initial startup from the other day did not exhibit such a sound. Of course, there was some soldering involved which might have changed something in terms of temperature. Need to do some checks again to see what's different. Previously, I did some prechecks of voltages for the 10v, +/-60v along with output voltage at the opamp (looking for any DC disparity).
                      checking the voltage on the opamp output shows a significant dc voltage (2+ volts) on both channels. I was wrong with my initial hearing of buzz as it is actually on both channels (speakers are too close together).
                      • budwich
                        • Jul 2015
                        • 3097
                        Playing with the gain controls, with no inputs connected, the buzz increases (on either channel) as the gain is increased but does drop off as you move towards max gain. The DC voltage on the output of the opamp increases but then drops off in step accordingly. At this point, the buzz does not seem to dissipate with time (ie. as run warmup happens).
                        It would appear to be some form of grounding issue maybe??? Looking at the schematic, there is supposed to be a 2.7 ohm resistor between the control board ground and the earth / chassis ground (although I am somewhat unclear with the ground icons in the schematic... /// versus = ). There resistor has always been hanging in "mid air". One end is connected to the common / ground areas of the board (where the signal shields all terminate) while the other end is just hanging there. Not really sure why it is like that. Is this related to the issue? Is it possible crown dropped the connection for some reason? The resistor is sitting on the backside of the printed control board, almost like an afterthought / temporary mod.
                        edit: It probably has no bearing as the amp is normally plugged into a "cheater plug" (3 to 2 prong adapter) probably to prevent any possible ground loops (and the back side of the preamp switched power only has 2 prong outputs for the same reason).
                        • budwich
                          • Jul 2015
                          • 3097
                          Went "hunting with heat" (ie. hot air station), and found the buzz on channel one (which is slightly greater than that on channel 2) was quieted by applying heat to the area of C119 (200 pf mica).
                          and Q102 (2n3859a)... not sure the hot air can be directed well enough but I suspect the cap rather than the transistor.
                          • petehall347
                            • Jan 2015
                            • 4440
                            #113
                            i say transistor . or poor solder .
                            i will look at schematic to see why the caps there .
                            edit
                            appears to be a miller cap to stop oscillation . wont harm changing it .
                            • petehall347
                              • Jan 2015
                              • 4440
                              #114
                              heat the transistor then cool it with a drop of isa on a cotton bud .
                              • budwich
                                • Jul 2015
                                • 3097
                                It appears that you are right as I focused more heat towards the transistor and it eventually quiets the channel.... :-( It would appear that the q102 (2n3859) as some form of issue. The bad news is it identified as "selected" and probably means the replacement of the other one on that channel and trying find those two in some "closeness of selection". I am not sure where I read or saw somewhere a suggestion to replace them with bc639's (which I have... not sure why but related to this repair at some time at the start). They have a slightly higher voltage rating with the same current rating. Do you think that would work or cause me more problems... oscillations, otherwise? This is way past my knowledge and experiences to date
                                • petehall347
                                  • Jan 2015
                                  • 4440
                                  #116
                                  what part number is q203 ? am wondering if they should both be changed as complementary pairs .
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    did you mean q103 (for channel one)? its a 2n4125... for the negative "leg". I never looked close enough at the circuit and figure the "select" referred to a "match" between the "top" and "bottom" of the circuit, but I see from your comment / question, that they appear to "complementary pairs" (npn, pnp). So then the question would be to select a bc639 that is similar to a replacement 2n4125? or am I totally missing the point?
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      Not sure what they mean by "select" but measuring a bc639 and a 2n4125 with a transistor checker shows an hfe for bc639 at 220 ish while the hfe for 2n4125 was 120 ish. This seems like a sizeable difference. Possibly a bc640 instead of 2n4125? The data sheet for the bc639 seems to indicate a "normal range" of hfe similar to that of the 2n4125. Perhaps a "select" is harder to accomplish with a limited count of devices if indeed, the hfe is what is being considered.
                                      • petehall347
                                        • Jan 2015
                                        • 4440
                                        #119
                                        i dont know if they are complimentary .i did a quick search for the numbers and came up with different numbers for pairing them .
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          Is there a great risk at using the higher gain (hfe) bc639 substitute... ie will it cause other components to blow and out of control oscillations or otherwise?
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • quickname
                                            Cyberpower 1500AVR UPS repair
                                            by quickname
                                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                            I decided to verify that the batteries were...
                                            11-12-2023, 09:57 AM
                                          • dicky96
                                            Hitachi V19B01922 Channel Tune problem
                                            by dicky96
                                            Hi Guys
                                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                            He also has an LG TV, so three screens in the bar
                                            I installed three Satlink ST-6503 DVB-T Modulators
                                            This model https://www.aliexpress.com/item/32916553905.html
                                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                            02-09-2023, 09:20 AM
                                          • sima112
                                            Marantz pm 6005 right channel not worknig
                                            by sima112
                                            Hi guys,
                                            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                            01-30-2023, 12:11 PM
                                          • Logistics
                                            Supermicro X10DAX and Quad Channel
                                            by Logistics
                                            So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
                                            09-10-2023, 05:12 PM
