100Wx5 Reciever nearly blowing out my 100W speakers?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    I have a Sony STR-DE845 that is 100w/channel and some Memorex 100w 90s speakers I can find nothing on (vintage audio forums, craigslist, like they don't exist) but they are 100w (and impedance matched). But it seems way overpowered in stereo mode. Does stereo put it at 250/250? I was playing dnla from my roku and the woofer on the left went out so far it "popped" when it came back in. I know it didn't fry it because it still sounds fine. It was turned up about a quarter way
    Not as bad when i'm running 5.1 from DTS (of course center and surround are cheapo yamaha HTIB satellites)
  • petehall347
    • Jan 2015
    • 4447
    • United Kingdom
    Re: 100Wx5 Reciever nearly blowing out my 100W speakers?
    maybe the input is too hot
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      Input was a toslink from my TV, roku stick connected to tv with HDMI
      • R_J
        • 9610
        Where is the impedence switch set 4 or 8 ohm? those memorex speaker could be rated at 100 watts peak music power
          • 31262
          aka Nintendo Watts.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Speakers overrated, input too hot, maybe the bass was turned too high. If you're using EQ you will reach maximum power and clipping distortion long before you reach full range of the volume knob.
            If you were playing bass-heavy music, this is typical behavior of ported speakers (which i'm sure they are) used without a highpass filter. They were likely designed to be used as satellite speakers, not full-range.
            A working TV? How boring!
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              It won't be surprising if you open one of those 100 Watts to find a main speaker labeled 7 Watts .. Lol . I've seen it many times .
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                You can't beat vintage for quality. I have several pair of Pioneer speakers from 1979 0r so. Woofers are 12" with cast aluminum baskets about a half inch thick. Damn things weigh about 60 lbs. each. My accountant had a pair of nineties speakers sitting outside his office. He gave them to me, They were Pioneers with 12" steel baskets on the woofers. Weighed about 10lbs. each. After about $50 for foam and capacitors for the crossovers they were good as new. Except good as new meant they sounded like crap.
                I hooked them up to one of my 85 watt Sansui's from about 1979 and I could not get them to sound good. Low volume high volume it didn't matter they just smeared the mid range. I gave them away.
                I use Pioneer speakers from the early seventies for my surround sound system. Pioneer CS-99A for the front side and rear, CS-66A for the front high, and CS-33A for the center channel with matching twin subs. I routinely feel the bass through the concrete pad and carpet on my feet. I was watching the movie "A Haunting" recently and I had the volume high enough to hear the dialogue and the noise and music shook the house.
                My advice is always to have a system for movies and a system for music. Surround sound processors can't make music sound good. If finances are tight though, you just have to do the best you can. I take a long term look at things. I'll spend all I have on speakers I know will work for the rest of my life and wait until I find the amp I want. My first good speakers I found in 1988 for $100 each. I still have them, it took me several years to find a decent amp for them. First I used them with the amp I had and that wasn't good enough. I bought a really good surround sound processor in the mid nineties and that didn't work. I bought an even better one in 2002 and it still didn't sound all that good so I went back and found the original amplifier the company put out at the time. That worked, I now have the entire top of the line system from 1976 and it sounds beautiful. I bought the old Pioneer speakers to use with the surround sound and they work great for movies, they have that vintage look and they all match since they're from the same line, just different sizes, most large with a couple small ones.
                sigpicThe Sky Is Falling
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5045
                  • US
                  I checked the impedance switch when I first hooked them up
                  they're not satellite, they're floorstanding. liquid cooled tweeter and 8" woofer
                  If anyone an find anything on these speakers, tell me because i've found nothing
                  this amp is from 2006 and it actually sounds great with 5.1 surround and music (switches to 2.0). It's actually a great rated amps for the time and cost me nothing
                  hm, I do have the bass frequencies cut kind of high, but still, having the volume less than a quarter up
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    8" is a bit weedy IMO for bass. I only have mid range and treble going to my 8" and my JBLs. Bass goes to my 10"ers.
                    Perhaps the crossover is not working as it should.
                    Until I picked up a Yamaha cheap I was running 3 amps with 3 sets of speakers.
                    Splitting the ranges to the right speakers to get better control of the sound. Now I run 2 amps powering 4 tweeters, 2 midrange and 3 subs. I have a pair of 12" subs coming too from a friend that wants them looking after.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5045
                      • US
                      actually the bass from these 8"s is amazing. Before this I cut the frequency lowest and cut them down, sounded almost like a subwoofer
                      I wish I had room for bigger speakers, like some other 90's with a 12" woofer our neighboor was throwing out. Woofer cables were reversed, but I fixed it. They're not bad but way too big for my room
                      90's brand that was apparently made by Panasonic
                        Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                        by momaka
                        More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                        02-15-2022, 12:43 AM
                        Connect pc speakers to tv without 3.5 jack
                        by nomoresonys
                        Currently trying to connect pc speakers to 2015 vizio tv, tv has no 3.5 headphone jack. Does have rca audio out, tried connecting thru a Y rca to 3.5 cable but getting odd results(probably just need a dac for decent audio, not sure?) not too educated on audio. With that hookup I'm getting 2 problems, can't get the speakers to increase in volume so it's very low even when turned up and when using both tv and pc speakers the pc speakers only put out the music part of the broadcast and not the vocals/talk of the program. Have you run into this before or know what it might be, Thanks.
                        09-19-2025, 05:17 AM
                      • Widget
                        Logitech R20 speakers - Replacing one of the speakers.
                        by Widget
                        Hi guys,
                        I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                        Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                        Printed on the back of the Logitech speaker is;
                        LOGITECH...
                        05-29-2024, 07:07 AM
                      • RetroComputingGrotto
                        Behringer MS16 Speakers - Low Volume on One Speaker
                        by RetroComputingGrotto
                        I've had a set of speakers come in with the fault of not powering on.
                        I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
                        1 random loose nut and part of a BIC Biro pen.
                        After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
                        05-20-2024, 07:29 AM
                      • piipo
                        Old Privileg 5.1 speakers remote control question
                        by piipo
                        Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                        09-18-2024, 01:55 AM
