More Lo-Fi speakers and another DIY surround repair.
The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
My brother in-law said the speakers worked but were making rattling noises. So he ended up connecting the system to their living room TV's sound bar (plus, my sister didn't like how much space the speakers would have taken anyways.) Thus, the speakers were put in storage, as my brother in-law thought it would be shame to throw them away… but really couldn't give them away in their current condition either. And he knew he probably wouldn't ever get to use them too. So he asked me if I wanted them.
I don't really need any more speakers, but I really dislike broken stuff – especially when it's something fairly easy to fix. Based on his description of the problem, I pretty much knew I'd be dealing with speakers with rotten foam surrounds. The question was whether they would be worthy of a proper surround replacement job, or if I should just McGyver them like the Boston Acoustics HD8 speaker. So I decided to look at their build quality first and then decide on that.
And here it goes, first let's see the speakers on the outside.
The boxes were in excellent condition and the speakers themselves look very presentable.
Next, a shot of the label, which shows they were Made in Belgium!
Even the power rating seems sensible at 40 Watts (RMS?) and 70 Watts P Max (which I can only assume is a PMPO rating.) The woofers are 8”, so that's probably not terribly over-rated as I've heard (pun intended) some component system speakers can be.
OK, let's get the front cover off!
Surprise, surprise! – Rotten foam surround on the woofer.
But hey, apart from that, everything else looks and works great. The soft dome tweeter actually appears to be of decent quality, so these might even sound OK in the midrange and treble frequencies. Beware, though! There is a “Frequency Curve” diagram on the front – often a hint that one would be dealing with cheap(er)/budget/Lo-Fi speakers.
OK, let's take out the woofer and have a closer look.
… Ah, but wait, I need to heat up the soldering iron first, because… soldered connections.
I guess ain't nobody got time for crimp terminals here. But that's OK, I don't mind soldered wires.
Also, take note of the blue Philips axial capacitor. This isn't actually a filter for the woofer, but rather for the soft dome tweeter. My assumption here is this was easier to get the crossover for the tweeter wired.
Alright, now the woofer is out.
I cleaned the rotten foam right away, because it's really annoying when it falls on the ground and gets smudged – rather hard to clean up afterwards.
And yeah, that's a pretty tiny-looking magnet once again.
I forgot to put a ruler next to it to show the size, but it was about the same diameter as the magnet on the Boston HD8… except, note that this magnet is “shorter” as well. On top of that, the rear plate on the magnet isn't “bumped” either, so speaker will have very shallow cone travel distance (low X-max.) And finally, the voice coil diameter is only 0.75” (19 mm) rather than 1” (25 mm) like on the HD8. Given all of this, I suppose even 40 Watts RMS might be too much for these speakers to handle. On the plus side though, the cone is made of thin and light, but fairly rigid paper. And the magnet gap seemed very tight, because I could easily jam the voice coil just by barely touching the speaker cone anywhere. My guess was, these would be pretty high efficiency speakers and probably sound reasonably OK. However, they also didn't seem too worthy of a proper repair, given what they are or the fact that probably no one would use them. And to be honest, I don't think replacement surrounds would have arrived in time to get the repair done. So, time to revisit my DIY paper surround methods again.
The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)My brother in-law said the speakers worked but were making rattling noises. So he ended up connecting the system to their living room TV's sound bar (plus, my sister didn't like how much space the speakers would have taken anyways.) Thus, the speakers were put in storage, as my brother in-law thought it would be shame to throw them away… but really couldn't give them away in their current condition either. And he knew he probably wouldn't ever get to use them too. So he asked me if I wanted them.
But hey, apart from that, everything else looks and works great. The soft dome tweeter actually appears to be of decent quality, so these might even sound OK in the midrange and treble frequencies. Beware, though! There is a “Frequency Curve” diagram on the front – often a hint that one would be dealing with cheap(er)/budget/Lo-Fi speakers.OK, let's take out the woofer and have a closer look.
)... and I decided to glue it on the underside this time, like the original surrounds.
“Why throw them away?”, I asked. My uncle said he knew a place that sells them and they were cheap – like about $2 each. He didn't want them cluttering his bench, so wanted to get rid of them.
These Philips speakers are still pretty mediocre in terms of overall sound… but at least on more typical modern-day music with an extended bass range, they may not embarrass themselves as much anymore.
