Logitech R20 speakers - Replacing one of the speakers.
  • Widget
    • Aug 2015
    • 74
    Hi guys,
    I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
    Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
    Printed on the back of the Logitech speaker is;
    LOGITECH
    EB-H02000040700-B
    4ohms
    2W
    831
    I ideally would like to fix the speakers. I don't like waste, especially if it can be fixed, I'd rather have them as a backup or connect to laptop, but at the same time whether they can be fixed cheap enough. I've never purchased replacement speakers before so I'm not sure what to look for. Any assistance would be super.
  • tmcw
    Stereo speakers to mono speaker
    by tmcw
    I picked up this set of powered PC speakers, no name brand, power cord to one of the speakers, and two audio cables coming out of it, one going to the other speaker, and the other to a 3.5mm jack for plugging into an audio out source.
    So, a typical cheap powered PC speakers setup.
    Now, the sound is pretty decent, I must admit, from the 4 ohm, 3W speaker, but I say "speaker", because it's just coming out of one of the speakers, and not the one with the power cord coming out of it. The other speaker is ok, it's just the electronics going to it has probably a fried...
    05-12-2021, 08:04 AM
  • RetroComputingGrotto
    Behringer MS16 Speakers - Low Volume on One Speaker
    by RetroComputingGrotto
    I've had a set of speakers come in with the fault of not powering on.
    I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
    1 random loose nut and part of a BIC Biro pen.
    After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
    05-20-2024, 07:29 AM
  • basskilla
    Logitech X-140 speakers buzzing is it normal?
    by basskilla
    Hi There!
    I bought secondhand Logitech X-140 speakers,it is old but it think the quality is all right.
    My problem it has background buzzing noise even if nothing is connected to it.
    It is not too loud,but if the room is quiet,it is noticeable.
    if I touch the metal cover,or the tone knob the noise is louder,I have the plastic cover knob,but I don't know is this noise normal or not.Sounds like a grounding issue or something like that.
    I tried to resolder the jack connection but nothing changed.
    Here is a little video about the speakers:...
    01-21-2023, 07:20 PM
  • Califauna
    Help with boom box modification
    by Califauna
    Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
    I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
    From factory the specs of the boom box are:
    -Power Input: DC 5V
    -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
    -Drivers:
    -2 x Woofer, 70mm, 10Ω, 70mm,15W
    -2 X Tweeter, 8Ω, 30mm,10W x 2
    -Frequency...
    12-04-2021, 01:53 PM
  • Dvsr
    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
    by Dvsr
    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
    After replacing the caps I started testing out the speaker. It seemed...
    09-10-2025, 10:20 AM
