Audio analogue enigma preamp issue
  • perette
    • Mar 2013
    • 71
    • france
    hello everybody
    I had the chance to find at the waste an Audio Analogue Enigma (V1) dropped there by its previous owner.
    when I've started to investigate why someone get rid of a 1500$ unit I've found that the main power fuse was blown. I replaced it and miracle the monster started.
    then I've tested it and the headphone output was working correctly.
    the problem appears when I've connected speakers. the left channel is lower than the right one.
    What I've done and seen so far.
    - no bubbled/ damaged components inside
    - voltages out of the power are OK
    - by inverting the preamp to amp cable, the problem was clearly on the preamp board.
    further investigation has shown that two resistors (10 ohms) (see pictures) have heated (color code is hard to read) and the wire between them seems to be brown (sames on the other side of the board).
    I need your help to try to understand if the sound problem comes from this heating issue, the fuse problem (don't know why it was out) or any other idea. the lamp seems to be OK. I can only notice that there are two red spots inside it when it runs (normal) but one seems to be a bit less bright than the other one.
    I've taken some pictures of the all system open and the region i suspect.
    Reviving this nice piece of HIFI could be a good job. thanks for your input
    JM
    • 30979
    Re: Audio analogue enigma preamp issue
    chick if the part on the heatsink or the diode in front of it are shorted.
    • perette
      • Mar 2013
      • 71
      • france
      HI stj
      I'll test this and post you the outcome.
      thanks for this quick reply
      JM
        That is the power supply section, you need to get the P/N of those two devices close to those two resistors which are mounted on the heatsinks, it looks like they use the resistors (connected in series) to drop the Voltage from the main power supply to feed Q5? which looks like it is used as Linear regulstor, not a good way using resistors due to wasted power.
        Sine the power supply is common to both channel, I doubt that it is the cause of having low sound level in just one channel.
        So this unit has one tube for pre-amp?
        Can we also see the pictures of the whole unit, the front panel, rear panel? Your pictures are cutout.
        ' I can only notice that there are two red spots inside it when it runs (normal) but one seems to be a bit less bright than the other one.'
        I do not understand as to what you mean 'Red spots).
          • 30979
          i'm not sure it's a good idea to run a valve on it's side, from a thermal standpoint!
          • R_J
            • 9535
            I have never seen an issue with mounting valves sideways, tv mfgr. for one, did it all the time.
              Never seen any problem, seen them a lot in 1-RU equipment, just like light bulbs mounting.
                • 30979
                i would be concerned about the guts slowly dropping and potentially shorting like on the last of the narrow-neck crt's!
                • CapLeaker
                  Leaking Member
                  • 8118
                  Inject a signal into both channels, then start tracing with the oscilloscope. Compare one channel to the other one. Stage per stage.
                  • perette
                    • Mar 2013
                    • 71
                    • france
                    hello everybody
                    Thanks for your input and i'll try to do my best to provide more detaileld infos on that case.
                    for Budm : I'll take pictures of all parts more in detail (preamp board and front /back panel), this evening (I'm in France)
                    The two red spots (sorry, poor English) are the two red heat points inside the lamp (that's why you'll see a window on the front panel, to see it glowing)
                    I'll also test what STJ proposed. (surely this evening too).
                    Hi CapLeaker, I'll have to find a working oscilloscope to do some tests.
                    just forget to mention : I've tested the two resistor and they seems to be ok as the connection between them.
                    I'll keep you posted.
                    best regards
                    JM
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      Bottleheads love to watch them tubes glow.
                      sigpicThe Sky Is Falling
                        They use one Vacuum tube so they can claim warm sounding tube when the rest of the circuits are solid-state.
                          • 30979
                          put some dead / random tubes or capsules from a vending machine in an amp, hide a neon lamp under each of them,
                          then put it on ebay then!!!!
                          • perette
                            • Mar 2013
                            • 71
                            • france
                            Hello
                            So I've tested both diode and they seem to be ok.
                            I've also verify and corrected any soldering that was looking questionable especially in the lamp board.
                            If I follow your comments (not on the concept which is what it is....) if there is a output pow difference between channels it can c from the audio analogic part or the lamp itself.
                            How can I check this ?.
                            It seems that there are some voltage control points to investigate.
                            I ll keep y posted.
                            FYI, picture of the two components close to the two resistors
                            Best regards
                            Jm
                            • samson7point1@yahoo.com
                              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                              by samson7point1@yahoo.com
                              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                              The player processes the audio signal using two different reference frequencies. The "R"...
                              04-30-2024, 11:22 AM
                            • kurtspirit
                              A2141 Jack audio issue
                              by kurtspirit
                              Good morning,
                              I have a problem with a Macbook A2141 with the audio jack port. Sound only comes out from one side (left). The right one just emits a kind of crackling sound.
                              I changed the jack ports twice to be sure that it was not caused by a defective part, but the result was the same.
                              I have the impression that it could be an audio filter or component but I am unable to locate the affected part on the motherboard.
                              Have you ever encountered a similar problem and can you help me find the filters, if they exist, on the map please?
                              Thanks in advance...
                              07-25-2024, 04:11 AM
                            • yuviuv46
                              Help with audio,wifi and battery issue for 3420
                              by yuviuv46
                              Dell inspiron 3420 came in for service
                              When i switched from ata to ahci the bios bricked and power on no display issue was there.I successfully managed to flash bios with external programmer now the display is ok when i upgraded from 7 to windows 10 os.it gets locked automatically.When i remove the battery the issue is gone btw the battery is in pluged in not charging no wifi sound working up.I have installed all the compatible drivers still no success any help would be great!!!
                              10-24-2022, 04:49 AM
                            • rounin
                              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                              by rounin
                              🛠 Original Issue
                              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                              04-19-2025, 01:18 AM
                            • chth96
                              Is it possible to test small ceramic disc capacitor with analogue meter?
                              by chth96
                              I read EBOOK of Testing Electronic Component and found that
                              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                              Is it really possible to test small ceramic disc capacitor with analogue...
                              03-09-2024, 10:03 PM
