Help with audio,wifi and battery issue for 3420
  • yuviuv46
    • Aug 2022
    • 11
    • India
    Dell inspiron 3420 came in for service
    When i switched from ata to ahci the bios bricked and power on no display issue was there.I successfully managed to flash bios with external programmer now the display is ok when i upgraded from 7 to windows 10 os.it gets locked automatically.When i remove the battery the issue is gone btw the battery is in pluged in not charging no wifi sound working up.I have installed all the compatible drivers still no success any help would be great!!!
  • mon2
    • 14663
    Re: Help with audio,wifi and battery issue for 3420
    Is the proper power adapter being used? Dell will use the PS_ID single wire communication to ping if the external power adapter is the proper rated adapter to power and charge the logic board.
    Any complaints from the power on cycle about the power adapter?
    • yuviuv46
      • Aug 2022
      • 11
      • India
      Yes the charger is of 65w wheareas on the system startup 90w is recommended.the charger what is being used came with the laptop itself.
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • code share
        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
        by code share
        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
        Here's what I've tried so far:
        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
        • Booted successfully on AC power only with the battery disconnected
        • Visual inspection of the battery — no swelling, burn marks, or connector damage
        • Battery
        04-21-2025, 12:50 PM
      • huzo
        HP ELITE X2 1013 G3 weird battery issue
        by huzo
        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
        01-31-2025, 12:09 AM
      • danielsak
        Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
        by danielsak
        Hello, I have issue with Dell Inspiron 3542.
        Motherboard marking:
        Code:
        PWB FX3MC REV: A00
        The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
        1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
        1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
        10-11-2024, 04:36 PM
