Help troubleshooting an audio problem with an RCA SGT-250 CED Player
  • samson7point1@yahoo.com
    • Apr 2024
    • 5
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R" audio is modulated to 716kHz, and the "L" audio is modulated to 905kHz.
    The "R" channel is first processed by the U3601 "Audio FM Demodulator" on the PW3000S main board, and then the demodulated "R" signal is sent along with the modulated "L" signal to the PW4000 "stereo" board where the "L" signal is demodulated by the U4101 "Audio FM Demodulator" then sent to the U4601 "Audio Output" IC along with the demodulated "R" audio.
    To troublehoot:
    - I have replaced both the U3601 and the U4101 IC's with new known good parts (originally U4101 was not functioning at all).
    - I have replaced the U4301 quad op-amp
    - I have replaced the Q4301 and Q4302 transistors
    - I have tried adjusting the R4109 potentiometer (no audible change)
    - I have tried adjusting the R4303 potentiometer (no audible change)
    - I have checked the resistance and capacitance of all of the resistors and capacitors that seem to be in the audio path.
    - dismantled, cleaned and reassembled the SI Mode Switch (audio mode switch)
    Someone shared a copy of the service manual with me: https://drive.google.com/file/d/1FWt...5ePpMBX4zHe5AM
    The schematic for the PW3000S main board is on Page 54, 55 and 56 (image attached)
    The schematic for the PW4000 stereo board is on Page 48 and 49 (image attached)
    The service manual is fairly complete, and if I knew what I was doing I'm sure it would yield the clue I need. For example, I'm not sure what exactly the "SI Mode Switch" (Page 48) is actually doing when switched into "Stereo" mode, other than lighting the stereo LED indicator.
    Can someone take a look at this and hazard a guess at where I should look next to figure out why the audio volume is cut in half when the switch is in "Stereo" mode?​
    • Apr 2024
    • 5
    This is now resolved (at least mostly). Leaving this here in case anyone else finds this trying to solve the same problem.
    There's a trim pot "R4513" that's not mentioned in the electrical adjustments. It's labeled on the circuit diagram as "Decoder Adjust". It controls the level output ONLY when the switch is in the "NORM"/Stereo position despite the fact that the "decoder" IC controls the other output modes as well.
    Adjusting that I was able to match the output levels in all three modes.
    The only reason I say this is "mostly" resolved is because I'm not a fan of adjusting factory trim pots. It means that some other component has drifted over time and may only cover the symptoms rather than resolve the problem. I'm just at a loss of what component may have degraded because I've either checked or replaced nearly every component involved (including all of the electrolytic capacitors).
    • kokopelli75
      Victrola multi-player - No audio
      by kokopelli75
      Hello!
      My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...
      01-11-2025, 03:51 PM
    • nervous_capybara
      Repairing the Hitachi DA-6000 CD player
      by nervous_capybara
      Hello everyone !
      I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
      Feel free to share your experience if you ran into other issues.
      DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
      CD tray would not come out of the player
      I could hear a motor spinning inside the player but the CD tray would not come out.
      Turned out that the issue was the CD tray belt that aged poorly and began to...
      11-05-2025, 03:11 AM
    • kotel studios
      Lantec PULSE 386 subwoofer - no audio output
      by kotel studios
      Hi
      I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
      After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
      The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
      11-29-2025, 04:15 AM
    • i_am_patch
      Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
      by i_am_patch
      Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
      04-30-2024, 08:20 PM
    • silver60618
      Macbook M3 A2991 Speaker Audio Amplifier IC
      by silver60618
      Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
      I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
      09-26-2025, 12:25 PM
