Should I power this thing up?(I HAVE NO VARIAC)
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    #41
    Re: Should I power this thing up?(I HAVE NO VARIAC)
    My Sansui power amp uses two 80v 22,000uF mounted in a metal ring. To keep the same diameter 77mm and close to the same height 100mm, I had to go up to 100v. Only two companies made them and nobody had the Panasonic. I bought Epcos from Farnell in London for $100 each. Mouser wanted $200 each for them. The new were 105mm tall and just cleared the top by a mm or two. Main thing is they work, not bad for forty year old technology.
    sigpicThe Sky Is Falling
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      so super high value caps are becoming a rarity? or no?
      Permanently Retired Systems:
      Kooky and Kool Systems
      sigpic
        • 31283
        no, but they are getting smaller.
        personally i just drill the chassis to hold a smaller mounting clamp or put a colar around the cap to bump up the diameter.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          ok
          sigpic
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            is it bad when I can drive intercom speakers that use a transformer and not have a problem?
            Also, how can I remove the non-soldered wires from the boards w/o cutting them?
            sigpic
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              hello?
              sigpic
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                #47
                Don't remove those wires at all. Just move the board as easy as you can. Look up wire wrap. You can unsolder the pin if you have too.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Originally posted by dmill89
                  It looks like when the RS-1056 was made ~1977, Fisher was owned by Sanyo, like you said it isn't "bad" but isn't anything particularly "special" either.
                  I have a 1995 and I think it's a Sanyo, too...
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    can we just get to the point of what I have most recently ASKED!?
                    sigpic
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      #50
                      That's what most people do. I try to keep them looking the same as new for the most part. I've rebuilt five examples of one amplifier already and have three more to do. Panasonic announced they were going to discontinue the cap I use. Since it has two caps for each channel, I ordered up about $300 worth of them caps while I could. Going up to 80v from 63v kept the diameter the same but the new were still about 10mm shorter than the original. It works though and they are solid black like the original elna.
                      • TechGeek
                        Computer Geek
                        • Jan 2015
                        • 2254
                        why not remove the wires from the pins? too much risk?
                        sigpic
                        • rhomanski
                          nowhere man
                          • 5157
                          • U S of A
                          #52
                          Temper temper young man. I thought I did answer. Look up wire wrap. Don't cut those wires at all. Just move the board around as easy as you can because they are solid core and will break. If you absolutely have to remove one, unsolder the pin it's attached to from the board.
                          • rhomanski
                            nowhere man
                            • 5157
                            • U S of A
                            #53
                            First problem is originality, it's hard to wire wrap if you don't know how. Takes practice just like soldering. Second is keeping track of where each wire goes. One miswire can cost you the whole project or at least a lot of trouble.
                            • TechGeek
                              Computer Geek
                              • Jan 2015
                              • 2254
                              well, what am I going to do when I have to RECAP THE FLIPPING STEREO!?!?!?!?
                              Unsolder every last pin?
                              sigpic
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                #55
                                Lose the temper before you fuck something up in a childish rage?
                                Follow the white rabbit.
                                • rhomanski
                                  nowhere man
                                  • 5157
                                  • U S of A
                                  #56
                                  It can't be that hard. Pioneer is bad with that wire wrap and I managed to get the boards lifted an inch so I could get to the bottom of the boards. It takes skill and patience but you knew that. Not everything in life is easy. Work on cars or airplanes enough and you learn that. Sometimes where you need to go is just barely big enough to get a hand into but not big enough to see in it and it's full of sharp edges so you pretty much pull out a bloody stump when your done.
                                  • rhomanski
                                    nowhere man
                                    • 5157
                                    • U S of A
                                    #57
                                    If you realize a problem is a challenge and not the end of the world you'll do fine in life. Or at least better.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #58
                                      Fucking rude
                                      • TechGeek
                                        Computer Geek
                                        • Jan 2015
                                        • 2254
                                        managed to strip a screw on the low-level tone control board... how do I get it out?
                                        sigpic
                                        • diif
                                          • Feb 2014
                                          • 6978
                                          • England
                                          #60
                                          Carefully....and as my gran used to say "good manners cost nothing"
