Fixing a variac with shorted windings
  • CapSnap123
    • Apr 2024
    • 17
    I have an old "Adjust-a-Volt" variac. Shortly after I bought it, it started smoking and now the windings look burned for about 2 inches around the left side. Is it possible to fix this or bypass the shorted windings? I'm not sure how to detect where the bad windings are, except by appearance.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8709
    Pictures?
    Usually smoking windings are indeed a place to look for shorts. Might be easier to clean and restuff with some epoxy or varnish so that it's not shorted anymore if the winding is still intact, winding is so tight on there that putting a jumper still requires you to cut the bad section out.
    • CapSnap123
      • Apr 2024
      • 17
      So you mean just cover the windings with, for example, polyurethane from the hardware store? Here's a photo of the windings (on the right)
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8709
        woah wtf.
        that tap is the input/hot tap, the browned out section is the "boost" section and the right is the 'buck' section?
        Usually if you have a short, two adjacent windings are shorted. This looks like you have a whole bunch of windings that are overheating? Means the boost output is shorted against something perhaps?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8351
          Umm… what did you do to this variac? Must have drawn some current all right… does the variac still work?
          • CapSnap123
            • Apr 2024
            • 17
            I have no idea what caused this. I just plugged it in one day and it started to smoke.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8351
              You got something that will measure AC current like an energy monitor? It probably doesn’t adjust the output anymore properly either? I am a bit surprised that it doesn’t blow a fuse.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8709
                make sure the output isn't shorted and you're not chasing after something that doesn't exist...
                • reessi
                  Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                  by reessi
                  Hello:
                  I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                  I started on the ACER:
                  Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                  All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                  I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                  10-29-2024, 11:31 AM
                • Yanleb
                  Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                  by Yanleb
                  Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                  I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                  D608, good
                  D618 RF101L4S, good (See warning 1 below)
                  D619 RF101L4S, good (See warning 1 below)
                  D865 RF101L4S, shorted (See warning 1 below)
                  IC464 Inverter HA MC74HC1G14, shorted...
                  03-09-2020, 12:00 AM
                • modtool
                  HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                  by modtool
                  Hi to all,
                  the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                  I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                  I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                  04-01-2025, 08:22 AM
                • BalkanBoy
                  Dead Razer Blade 14 2022, shorted CPU?
                  by BalkanBoy
                  today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                  Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                  I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                  Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                  I removed coil and injected 0.7V, it draw around...
                  09-27-2024, 12:44 PM
                • barry101
                  Apple 820-3662 VCore shorted to ground.
                  by barry101
                  Hi, Would appreciate some help.
                  I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                  Get charger light but no fan spin or chime. No liquid damage.
                  Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                  Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                  With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                  Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                  06-24-2025, 07:34 AM
