Klipsch ProMedia 5.1
  • USchabon
    • Jun 2016
    • 116
    I just ordered my first replacement caps and will be picking up my first soldering kit to repair some old monitors! I am kinda pumped about repairing things now, heheh, so I thought I'd go check out an old 5.1 computer setup I stashed away after it stopped working to see if there was an easy fix for it as well. It is a ProMedia Ultra 5.1, and I remember that it sounded great.
    It was years ago so I can't remember if there were any specific symptoms, but I want to say that they just stopped working.
    Here is what my very untrained eye found:
    FIRST THING I NOTICED
    I noticed there is a missing metal clip that was attached to 1 of these MOSFETS in the photo below. I found the metal heatsink in the subwoofer box, so I might be able to stick it on there with some thermal tape or something. Those three mosfets seem to be different however... The one that is missing the heatsink reads "ST 0248 MOROCCO TIP31C" and a google search lead me to THIS PAGE.
    So I guess it might have overheated and died somehow. I have a multimeter, but after watching a few youtube videos I am still not sure how to test it. Could someone explain how to do that?
    SECOND THING I NOTICED
    I looked at all the caps and one is clearly bulging. These are the biggest and seem to be 820uF 200V. The one next to it on the left doesn't seem to be bulging, but I guess might as well do both..?
    I have a multimeter, but don't know how to test CAPS. Could someone explain how to do that?
  • USchabon
    • Jun 2016
    • 116
    Re: Klipsch ProMedia 5.1
    So I just started watching videos on how to test CAPS with a multimeter, but I can't figure out whether it is ok to test while they are still attached to a board. I guess you have to unplug for sure, but will you get a good reading without removing the cap from the board?
    Because I followed this method and both of the big caps seem to give me a measurement that gradually discharges when I do this: https://www.youtube.com/watch?v=FDuN7QHn1-s
    • CapLeaker
      Leaking Member
      • 8173
      the L7805 is a 5V regulator not a mosfet. You have a higher DCV going in and it regulates it down to 5V. The regulator you picked out is fine. Is the mosfet you are talking about the one that has no heat sink on it? Is it shorted or something?
      To test electrolytic capacitors, you do that with an ESR meter. When in doubt with a measurement, test it out of circuit.
      • USchabon
        • Jun 2016
        • 116
        second: you test electrolytic capacitors with an ESR meter. When in doubt with a measurement, test it out of circuit.
        Hello Leaker! Thanks for popping in to help.
        Just before you replied I noticed that those 3 mosfets are different... oops! So I replaced the close up photo with one of the actual one that is missing the heatsink and I also edited my first post.
        It reads "ST 0248 MOROCCO TIP31C". ST seems to be the brand STMicroelectronics", not sure what 0248 means, MOROCCO might be where they make them I guess, and TIP31C seems to be the actual part. I found this http://www.mouser.com/ProductDetail/...FUKUfgodEQkJ6g
        Would you know how to test that part? If it makes a difference the multimeter I bought is this one: Craftsman 82141
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          You *cannot* test capacitors with a multimeter.
          I know some tutorials/videos on YouTube and elsewhere online show that you can... by setting your multimeter to resistance scale and seeing if you get "increasing/climbing" resistance numbers when "measuring" the caps. But that is actually not a useful test at all. When I started messing with electronics, that's how I thought you could test caps too... until I found some clearly bulged and leaking caps that passed this "test" as good and started reading more on the matter.
          As mentioned in the Gateway 24" LCD thread, you need an ESR+capacitance meter to test capacitors *more reliably*.
          Those big caps have a plastic sleeve on top. Sometimes, that plastic sleeve will warp with age and/or heat. Press firmly on the plastic sleeve of the bulged cap and see if it "gives in". If YES, then it's just the plastic sleeve that's warped and the cap may not be bulged. But if the plastic sleeve is hard, that cap is definitely bulged.
          I see those are G-Luxon brand, which is a brand not well regarded here... so yes, they could have failed.
          Loose metal parts falling from the circuit board - that's not good!
          Shame on you Klipsch!!
          Anyways, all goofiness aside, you can use regular PC thermal compound to create a good thermal transfer between the heatsink and the Transistor (it's actually not a MOSFET, but more on that in a bit). Then use glue to attach the heatsink to the PCB.
          And speaking of glue... your circuit board appears to have the dreaded tan glue that likes to go conductive when it turns brown with heat and age. So try to remove as much of it as you can from any components or traces you see it on.
          Yes, TIP31C is indeed the actual part number. ST is simply one of the many companies that makes them.
          That "MOSFET" is actually BJT (Bi-polar Junction Transistor). There are two types of BJTs: NPN and PNP. Your's is NPN.
          These you *can* test with a multimeter. To do that for a *NPN* BJT:
          1) Set multimeter to Diode / Continuity test mode (the setting with the diode symbol).
          2) Put the red (+) multimeter probe on the BJT's Base pin and the black (-) multimeter probe on Emitter pin. You should get a reading of 500 to 800 mV (or 0.5 to 0.8 V.)
          3) Now move the black (-) multimeter probe to the Collector pin. You should get a reading of 500 to 800 mV (or 0.50 to 0.80 V) again.
          If you ever need to test a PNP BJT, simply reverse the multimeter probes. (That is, put red probe where you had black probe and put black probe where you had red. Readings should be the same.)
          Since you are beginning to learn how to test these, I encourage you to post your reading here so we can verify your results.
          Note that this test above is only valid for when the BJT is removed from the circuit. When testing in circuit (you CAN), note that the reading may be slightly *lower*. But in any case, you should never get a reading much higher than those listed above and if you get a short-circuit (audible beep or less than 100-ish mV / 0.10 V), then remove the BJT and test out of circuit again. Also, when out of circuit, you should *never* get any reading on your multimeter between Collector and Emitter pins, regardless of which way you have the probes.
          My uncle actually has that multimeter. I've used it quite a bit a few summers ago to repair a washing machine.
          It's basically a standard "830" design, but built a much better than the regular cheapo Chinese versions you find on eBay elsewhere online. And the probes are decent and won't fall apart on you.
          Last but not least, please post some pictures if possible. In particular, post a top- and bottom-side pictures of each board. That way, we can see what is going on in the amplifier and how components and boards are connected.
          • USchabon
            • Jun 2016
            • 116
            Clearly bulged. The one on the left feels and looks pretty flat... but I guess might as well swap both since they are not well regarded.
            Question, does changing caps change the sound at all?
            What kind of glue should I get? Glad to hear I can do that. I was thinking that once long ago I heard about glue that was meant for this sort of thing and wasn't affected by a little heat.
            Ugh... unbelievable... that stuff is all over be PCBs. Do you have any recommendations for the removal?
            1) I am not sure which is the flat side of this BJT, but I am assuming the "flat" side is supposed to be the one attached to the metal plate with a hole.
            2) I got a reading of 540
            3) I got a reading of 895
            It was still in circuit.
            Sweet, good to know!
            I will shoot better photos during the day tomorrow, but here are three that will give you a rough idea.
            • USchabon
              • Jun 2016
              • 116
              Here's a few more
                That TIP31 Transistor and the one below it with heatsink are the setup as linear regulators to supply +/- regulated Voltages for the OP-AMPS.
                Just check the DCV on all 3 pins with ref to GND on both Transistors to see what you have.
                • USchabon
                  • Jun 2016
                  • 116
                  Awesome! Thank you very much for chiming in with your knowledge Budm, now I just need someone to translate that to noobie so I know what you said and how to test that
                  Here is a close up of the one in the middle (the one below the one that is missing the heatsink)
                    Do you have digital meter?
                    BTW, the metal tab of the Transistor is internally connected to the Center pin of the transistor, that pin/tab is the Collector pin.
                    https://www.badcaps.net/forum/attach...8&d=1465771992
                    So left pin is Base, Center pin/tab is Collector, right pin is Emitter.
                    • USchabon
                      • Jun 2016
                      • 116
                      Thanks! Here we go:
                      + left, - right
                      I get a reading of 595
                      +left, - center
                      I get a reading of 587
                      BTW, look at the previous post, I edited it to add a photo of the regulator you were talking about, the one that is in the middle (or below the one that is missing the heatsink)
                        Thanks! Here we go:
                        + left, - right
                        +left, - center
                        Are you using the meter setting to DCV? Black probe on the circuit Ground (metal chassis), red probe on each pin of the Transistors.
                        • USchabon
                          • Jun 2016
                          • 116
                          I set multimeter to Diode / Continuity test mode
                          Should I set it to Vcd? Which setting in particular? Mine has 200m, 2000m, 20, 200 and 600
                          Also, what do you mean when you say metal chassis?
                            We are check the DC Voltage so set the meter to read DCV in 20V range or higher.
                            The boards are mounted to the metal chassis, right? So you can use one of the board mounting screw that is screw to the chassis as the Gnd ref point for you meter's black probe, then use the red probe to check the DC Voltage of each pin of the transistors. Unit has to be powered up of course.
                            BTW, you do have tools for soldering works, right?
                            • USchabon
                              • Jun 2016
                              • 116
                              Oh, I have been doing all of this with the unit off. I went to power it on (without any speakers plugged in) and I immediately heard a weird sound... hahahah. I think this was why I stopped using them, for fear they would blow up hahaha
                              Ok, so I am assuming you guys will have something to say about this new piece of information
                              Here is a video of the sound:
                              https://vimeo.com/170714610/7904e83400
                              I do have a soldering kit on it's way
                              • rhomanski
                                nowhere man
                                • 5157
                                • U S of A
                                On the original unit, which I have, we had problems with one resister overheating and burning up. The fix was to tyrap a 12 volt fan blowing on the resistor. Can't remember which one it was now though. That was several years ago. I got mine in 2002 when it was THX certified. Another problem some have had is the "BASH" unit. You can find it on the internet. https://community.klipsch.com/index....o-media-ultra/ .
                                sigpicThe Sky Is Falling
                                • USchabon
                                  • Jun 2016
                                  • 116
                                  Interesting, because I thought the sound was coming from that area, but after you said that I took a closer look and I would say it is not the little white board... but it is hard to tell, because with this board layout the sound could bounce around a lot...
                                  Looking around I noticed quite a bit of that brown paste, which if it did turn conductive it could be connecting that cable and the cap against it.
                                  Could this be it?
                                  • USchabon
                                    • Jun 2016
                                    • 116
                                    Ok, so after reading that other thread Rhomanski posted it looks like a fan and some poor quality component replacements are called for. Thing is all of this is still a bit over my head, so I am not sure where to start.
                                    1. The soldering kit is on it's way, but I am also going to need some glue, so I need to know what type to get.
                                    2. Once I start working on this I plan to remove as much of the old brown glue in case it already turned conductive, but I want to find out if there is a recommended method for doing so... or just scrape it carefully?
                                    3. I have several fans, including an 80mm like the one on the ebay repair-kit, but I don't know what specific components need cooling (where to place the fan), and how do I power the fan from the board?
                                    4. Finally, I need to figure out what components to replace (aside from the bulging cap). These lists from the thread on the Klipsch forum must be a good starting point, but do I need to change all of these? And these two lists are different from each other.
                                    (more)
                                    Help!
                                    (please)
                                    Replace --- Replaced with
                                    R527 (4.7 ohm) --- CPF34R7000JKE14
                                    R529 (5110 ohm) --- CMF605K1100FHEK
                                    680 ohm (PCB position not labelled) --- RN70E6800FB14
                                    MR7 (100k ohm) --- CPF2100K00BEB14
                                    D5 and D6 (FR204) --- FR204-B
                                    All three 22uF (50V) capacitors --- EEU-FC1J220 (63V caps because they don't have the 50V
                                    versions. Same size as 47uF caps, fits fine though.)
                                    All three 47uF (50V) capacitors --- EEU-FC1H470
                                    Q10 (2N5551) --- 2N5551RLRAG (also has properly spaced pins, unlike the
                                    original)
                                    project manager cart
                                    daughter board
                                    R1/R4 with 71-CPF2470R00FKE14
                                    R7 with 71-CPF2-B-100K
                                    Q3 with 512-MPSA92
                                    R8 with 2f2DCT52R1001
                                    R9 with 273-205K-RC
                                    now for main board
                                    DB1 with rs606M due to 200amp max surge as opposed to 150amp of original
                                    C517/C518/C525 with 647-UKW2A470MPD
                                    C519/C520/C532 with 647-UKW2A220MED
                                    1000u 100v cap with 647-UKW2A102MHD
                                    1000u 63v (couldnt go bigger due to space) with 647-UKW1J102MHD
                                    R527 with 71-CPF3-J-4.7-E3
                                    R529 with 273-5.11K-RC
                                    (next to R529 unlabeled) with 71-RN70E6800F
                                    D5/D6 with 583-FR204-B
                                    Q510 with 863-2N5551RLRAG
                                    Q501/Q502 with 512-IRF740B
                                    D510 with 863-MUR1620CTG
                                    D504 with 863-MUR1660CTG
                                    U501 with 511-L7815CV
                                    U502 with 511-L7915CV
                                    R524 with 71-CCF02-J-47K
                                    • rhomanski
                                      nowhere man
                                      • 5157
                                      • U S of A
                                      You don't need to replace the glue, just remove it. It was put in by klipsch to keep everything in place during manufacture. Usually acetone will soften it so you can remove it easier. If you have a dental pick for removing it on wires and such a plastic scraper for on the boards.
                                      The lists you refer to are just what others used. It doesn't necessarily mean you need to replace those components. BudM will help you track down the problem you have. I was just trying to show that there are websites dedicated to this system which will give you clues as to how it operates and what components it has. Knowledge is power.
                                        Something interesting here: Look to see if those two caps are on that audio processing board (the board with the missing heatsink I think that is what they are talking about).
                                        https://community.klipsch.com/index....ol-pod-or-amp/
                                        https://www.badcaps.net/forum/attach...5&d=1465898128
                                        You should also remove all those glues and see if the traces and the components legs are eaten away or damaged by the glues.
                                        • Xan03
                                          Klipsch Promedia 2.1 rhythmic subwoofer "pulsing" during standby
                                          by Xan03
                                          I have this 2.1 Klipsch set where the subwoofer emits a constant whine in standby, in addition to a constant rhythmic pulsing/thumping. Only way to make it stop is to cut power. I think this thread mentions the same issue, though my set is not a BT one: https://community.klipsch.com/index....-bt-subwoofer/
                                          I think all this Klipsch gear is using crappy capacitors. Is it worth trying to replace the caps in the subwoofer amp to make this go away?
                                          11-17-2024, 06:54 AM
                                        • chth96
                                          How Can I test PWM DM0365R?
                                          by chth96
                                          Hello
                                          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                          06-18-2025, 04:14 PM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
                                        • chronic519
                                          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                          by chronic519
                                          Hello.
                                          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                          Found issue with a RAM block
                                          Replaced, green lines gone.
                                          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                          Used a good card to test and same results low errors 32+.
                                          I am just search for some form of command to do a full test on the GPU.
                                          I just ran the mats command with my good GPU and passed after roughly 40 min.
                                          The repaired one, ran...
                                          05-20-2025, 07:56 PM
                                        • alltvrepairs
                                          Lg TCon test pins for screen test
                                          by alltvrepairs
                                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                          Appreciate your help....
                                          06-13-2025, 06:33 AM
