KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
  • rccrasher65
    • Mar 2014
    • 622
    Check this out on Digikey:
    56-MAL205018103E3-ND
    Ok, thanks
    • CapLeaker
      Leaking Member
      • 8184
      Originally posted by rccrasher65
      That's great news, mine is definitely a lot smaller, but well covers our needs. We are excited to have our on line soon, inspection is next. Now back to the amp. I'm running into problems, first was the wires, now it's the caps leads length, and width. I need a cap with 10mm lead length, and also that same 10mm lead spacing. I Don't want to cut the board slots to make thes caps fit. They have the 10mm length, but only 5 mm spacing. What would you do. I'm thinking about just putting the old caps back in. I'll post a pic of the two caps. See what you think.
      What about cutting the old cap at the very bottom off and use it as an “adapter” and solder the new cap on to that? Looks silly but it works. On old ham radio restorations, forks gut the old cap and put a new cap inside in order to keep that vintage look. I think the diameter between new and old is the same, but the length is different. So you got 3 choices.
      A: put the old caps in and wait for them to fail
      B: put the cap in I showed you
      C: cut the bottom off the old cap and use it as an adapter for the new one you got.
      • rccrasher65
        • Mar 2014
        • 622
        I was thinking about trimming the leads on the inside, taking about 1.5mm off each blade. That would give me the 10mm I need for the spacing. Those blades are about 4mm wide each. Leaving a good 2mm for each side. More than a regular snap in lead thickness, which is about 1.5 mm per lead. Could that be a possibility?
        • CapLeaker
          Leaking Member
          • 8184
          Never hurts to try if you are feeling up to it. You can always buy the other ones as a last resort.
          • rccrasher65
            • Mar 2014
            • 622
            Yea, the ones you found are perfect, but a little pricy. $30.00 each. That's a little more than I want to spend now, but an excellent choice. I can't under stand why there are not more out there. MOUSER only had the ones I have. Who knows. I'm going to cut those blades to fit the slots in the board. I cut the leads, successfully.
            • CapLeaker
              Leaking Member
              • 8184
              Good job!
              • rccrasher65
                • Mar 2014
                • 622
                Good job!
                • rccrasher65
                  • Mar 2014
                  • 622
                  Well I did not finish the cap install, got a little busy with life,and now vacation time is coming up in a few days, so I'll get back at it when we get home from our trip. I only have the other two caps,and relay to do. Then it's time For the big show. See ya in a few. Thanks
                  • rccrasher65
                    • Mar 2014
                    • 622
                    Well back from vacation, had a little scare with my eye's. I thought I tore my retina, thank God I didn't. Vision is all ok. I have what they call floaters, crossing my vision path. It's a pain in the ass. But should get better with time they say. I have those two caps to put in, and I'll test the amp at that point. Thanks for your patience guys.Hope you're all have a great summer so far.
                    • CapLeaker
                      Leaking Member
                      • 8184
                      Those floaters are annoying, but they should go after a while. You get some eye drops or anything?
                      • rccrasher65
                        • Mar 2014
                        • 622
                        No, my eye Dr. didn't give me anything for them? Said they will eventually fall out of my vision path. You ever have them? They definately suck, that's for sure.
                        • CapLeaker
                          Leaking Member
                          • 8184
                          No, I don’t have them, but others I know did have it. The doc gave them eye drops. Our docs are very prescription happy.
                          • rccrasher65
                            • Mar 2014
                            • 622
                            No eye drops. He said that they will eventually fall out of my vision path, they are on the side, so I really don't notice much. Did they eventually go away with the people you know. They are extremely annoying though. I'M not to strain my eyes for a few weeks so, I'll get back to the amp soon. Just have those two caps to put in. Then test time. We need some rain over here, if ya got any extra send it my way.
                            • jm1234
                              9V relay temperature 40C
                              by jm1234
                              Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                              I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                              05-09-2024, 03:03 AM
                            • edugimeno
                              Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                              by edugimeno
                              Hi everyone!
                              I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                              I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                              This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                              To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                              I respected the polarity, positive to cathode of protecting diode
                              So provided all...
                              04-18-2024, 01:15 PM
                              Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                              by sam_sam_sam
                              I was working on this CNC machine today found no keyboard functioning no control relay powering on
                              The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                              Found shorted diodes on main controller relays there are 3 of them that...
                              01-07-2023, 05:43 PM
                            • DrDos
                              Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                              by DrDos
                              Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                              08-08-2025, 03:16 AM
                            • DXseekerMO
                              Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                              by DXseekerMO
                              Hello everyone!
                              Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                              I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                              Yes
                              0%
                              1
                              All backlight strips are the same quality
                              0%
                              1
                              No
                              0%
                              0
                              12-16-2021, 03:58 PM
