KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
What about cutting the old cap at the very bottom off and use it as an “adapter” and solder the new cap on to that? Looks silly but it works. On old ham radio restorations, forks gut the old cap and put a new cap inside in order to keep that vintage look. I think the diameter between new and old is the same, but the length is different. So you got 3 choices.
That's great news, mine is definitely a lot smaller, but well covers our needs. We are excited to have our on line soon, inspection is next. Now back to the amp. I'm running into problems, first was the wires, now it's the caps leads length, and width. I need a cap with 10mm lead length, and also that same 10mm lead spacing. I Don't want to cut the board slots to make thes caps fit. They have the 10mm length, but only 5 mm spacing. What would you do. I'm thinking about just putting the old caps back in. I'll post a pic of the two caps. See what you think.
A: put the old caps in and wait for them to fail
B: put the cap in I showed you
C: cut the bottom off the old cap and use it as an adapter for the new one you got.Comment
I was thinking about trimming the leads on the inside, taking about 1.5mm off each blade. That would give me the 10mm I need for the spacing. Those blades are about 4mm wide each. Leaving a good 2mm for each side. More than a regular snap in lead thickness, which is about 1.5 mm per lead. Could that be a possibility?
Yea, the ones you found are perfect, but a little pricy. $30.00 each. That's a little more than I want to spend now, but an excellent choice. I can't under stand why there are not more out there. MOUSER only had the ones I have. Who knows. I'm going to cut those blades to fit the slots in the board. I cut the leads, successfully.Attached Filesif you find these attachements useful please consider making a small donation to the site
Well I did not finish the cap install, got a little busy with life,and now vacation time is coming up in a few days, so I'll get back at it when we get home from our trip. I only have the other two caps,and relay to do. Then it's time For the big show. See ya in a few. ThanksComment
Well back from vacation, had a little scare with my eye's. I thought I tore my retina, thank God I didn't. Vision is all ok. I have what they call floaters, crossing my vision path. It's a pain in the ass. But should get better with time they say. I have those two caps to put in, and I'll test the amp at that point. Thanks for your patience guys.Hope you're all have a great summer so far.Comment
No eye drops. He said that they will eventually fall out of my vision path, they are on the side, so I really don't notice much. Did they eventually go away with the people you know. They are extremely annoying though. I'M not to strain my eyes for a few weeks so, I'll get back to the amp soon. Just have those two caps to put in. Then test time. We need some rain over here, if ya got any extra send it my way.Comment
Just having a shitty time with everything g right now, must have caught covid from my eye Dr. Tested pos. 2X. It's really a pain in arse. Fever, head ache, chills, body ache, sore throat, now a dry cough. WTF
think i had same ..14 years old jura single malt seems to have sorted it for me . just gargle then swallow as often as needed , glad i never tried that experimental mnra or whatever it is . i prefer to see a genuine risk sheet first .Comment
No clot shot for me either, shot of jack seemed to help with my sleep. Been good for a few days now, still tired, want to get back to amp in a week or so. Not much to do but those main filter caps, then test!Comment
Well life sort of got in the way of this amp project, I have two main filter caps to install. I will then test with dim bulb tester to see what I got. I think all will be well, and we should have a perfect working amp. Fingers crossed.Comment
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by jm1234Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but... -
by edugimenoHi everyone!
I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
I respected the polarity, positive to cathode of protecting diode
So provided all... -
by DrDosI have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...1 Photo
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... - Loading...
