KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8331
    I did understand exactly what you mean. A 1/4w resistor has a physical smaller size than a 1/2w resistor. There is a wattage rating. So if you put for example a 1/4w resistor in a circuit designed for a 1/2w resistor, it will run hot and blow at some point. What did you replace the original resistors with? Did you go from carbon to metal film or something? As long as the new ones are rated for a 1/4w that's all that matters. Old carbon resistors are usually brown and huge compared to their modern equivalents.
    I wasn't aware that your 2 amps actually had different version boards.
    • rccrasher65
      • Mar 2014
      • 626
      I matched all resistors, as per parts list if it's 1/4 w the new is 1/4w, no resistor is lower in wattage. I actually want to place some metal film in around those transistors. They are 1/2 w, and 1W mostly. The physical size in old resistors are a little bigger than the new resistors of the same value, that was my question, does that matter? Yes, same amp KA-701 INTEGRATED, has two different boards, I was actually surprised myself. The one we are working on has more caps (6 ). My amp has only one. Same with resistors, and Transistors. Are there a different set of schematics, I never found anything other than what we have. Will resume with component replacement. Starting with Q11, Q10, Q9, ect. Then the caps. I will then, replace those bad resistors.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8331
        Newer components are usually smaller than their old versions. Same with capacitors.
        • petehall347
          • Jan 2015
          • 4440
          #64
          i would replace all those fusible resistors with metal film .
          • rccrasher65
            • Mar 2014
            • 626
            Yes, I knew about the caps, I thought the resistors would be close to old size, but not so, as I'm seeing.
            • rccrasher65
              • Mar 2014
              • 626
              I plan on it, going to place order on Friday, will continue, with the caps and transistors. Thanks
              • rccrasher65
                • Mar 2014
                • 626
                Well didn't get much done this weekend, but ordering some new metal film resistors. Resistors should arrive on Thursday. I'm going to replace some caps, till those new parts come in. Hope all had a great Mother's day, this past weekend.
                • rccrasher65
                  • Mar 2014
                  • 626
                  Replaced the caps C-1, C-6, all 10uf 16V, replaced with 10uf 35V. C-6 was bad, tested at 4.3uf, very high ESR. The rest tested between 10uf- 14uf. On to the Q11, Q10, Q9 ect.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8331
                    Not too bad then. Could have been way worse!
                    • rccrasher65
                      • Mar 2014
                      • 626
                      Yes , I thought I would have a disaster on my hands, seems to be working out better than I thought. New metal film resistors arrive Wed, so I'll replace those around, the 4 transistors, Q11, Q10, Q9 ect. I think most of the damage was on the Q11, side. That's where I found those burnt resistors.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8331
                        Sounds promising!
                        • rccrasher65
                          • Mar 2014
                          • 626
                          Sounds promising!
                          Well some test results for Q11, hfe 60, IE 512ua, ube, 527mv. Q9, hfe. 66. IE. 627ua. Ube 520mv. Q10, hfe 102 IE. 966ua ube. 520mv. Q12. hfe. 148 Ie. 1.37ma ube. 556mv. I don't believe any are bad. Q11, Q9 seem weaker than rest. All were replaced with new originals. On to the resistors around these 4 transistors, there are 3 for each one. I found 2 bad. Some are dark, so those will be replaced also. I post results thurs. Looking good so far for damage.
                          • rccrasher65
                            • Mar 2014
                            • 626
                            I checked the data sheet for Q11, it is working , but considered bad. hfe should be a minimum of 65, so that explains why It worked when it wanted too. Q9 is also bare minimum, but works.
                            • rccrasher65
                              • Mar 2014
                              • 626
                              I changed the dark resistors around Q11, R-23 was smoked, replaced. R-3. Fell apart, but was ok, replaced. R-21. Fell apart, replaced. Q9, R-1 smoked, open. Replaced. As far as damage found.I think I have cleared all so far. Not seeing or testing any bad components. I will test each one, section by section of the board.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8331
                                I don’t think that is the case. Way too little Hfe difference. Now, there are NPN and PNP transistors that look good measure good with your DMM, but do not work correctly. Usually the hfe is then very low. Now these transistors aren’t there at all yet.
                                • rccrasher65
                                  • Mar 2014
                                  • 626
                                  They have all been replaced regardless. I'm now working my way across the board, replacing resistors that are dark, there are only about 3 that I see. They have all tested ok so far. Diodes are testing ok in circuit so far, just have the small transistors to check, I can get about 7 components in a day, before eyes get tired. Once I've gone through all the components, I think I will try a test on the Dimbulb, praying for no short.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8331
                                    Good idea.
                                    • petehall347
                                      • Jan 2015
                                      • 4440
                                      #78
                                      where are the original replacement transistors coming from ?
                                      • rccrasher65
                                        • Mar 2014
                                        • 626
                                        Mostly old stock, from reliable sources, others from Digikey , and mouser. I tested all before installing. It's hard finding original output transistors. Unit is over 50 yrs old. The originals have dried up. Found a pair of 2sc2525 in Japan. Had to choose the best replacements, I could finded. I've seen alot of your posts on other audio sites. Thanks for your input, valuable, and much appreciated.
                                        • rccrasher65
                                          • Mar 2014
                                          • 626
                                          I have 4 resistors, I can't identify, they are not on the parts list. I found on the board, R7, R10, the other 2 are under the resistor itself.I think the color bands are white, violet, violet, gold, not sure. I'll attach a photograph, see what you guys come up with. I think it's a 970 M ohm. Resistor. They are ok but look a little brittle.
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                          • DrDos
                                            Unit runs but no speaker output kenwood KR-6030
                                            by DrDos
                                            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                            09-14-2025, 09:57 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
