KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
  • rccrasher65
    • Mar 2014
    • 626
    I think I got it see if these help I can get better now that I know what I'm doing.
    • petehall347
      • Jan 2015
      • 4440
      be very careful with those bias diodes that are screwed to the heat sink .the wires tend to break off right next to the body and are hard to find new ones and also not easy to fix .
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8331
        I see some saaad looking resistors that are crispy. Those caps near that heat sink should be changed out too...
        • petehall347
          • Jan 2015
          • 4440
          yep it needs a good old looking at and any substitute transistors carefully selecting
          • rccrasher65
            • Mar 2014
            • 626
            Can you circle what you are talking about, thanks
            • rccrasher65
              • Mar 2014
              • 626
              Can you highlight what resistors look bad, I plan on replacing, most of the components on that board anyway.
              • petehall347
                • Jan 2015
                • 4440
                #27
                these things
Name:	Screenshot from 2025-04-21 22-37-37.png
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8331
                  Here! Click image for larger version
                  • rccrasher65
                    • Mar 2014
                    • 626
                    Yea,I saw those, actually they test good, but are getting replaced anyway. Thanks. Some parts are coming on Wed, this week.
                    • rccrasher65
                      • Mar 2014
                      • 626
                      these things
                      Thanks, I thought that's what you were talking about. There will be no need to touch them at all.
                      • rccrasher65
                        • Mar 2014
                        • 626
                        some transistors are arriving today! I'm going to start with the 4 big output trans. first then Q11, Q10, ect. I'm going to place an order for some new resistors, as well as new caps.
                        • rccrasher65
                          • Mar 2014
                          • 626
                          Most of my parts will arrive on Friday, I'm going to start with Q11, 10, 9 ect first, then the smaller transistors, followed by the caps on the board. For the 4 big output Transistors ,can I use arctic silver 5 thermal compound? Also, any secrets loosening the transistor screws in a tight space. 50 yrs old original never touched.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8331
                            You may take the transistors with the heatsink out. Then change the transistors on the heatsink and put the new mounted transistors with the heat sink back in. Always mount the transistors first before soldering, otherwise you risk damage. I suggest you clean and replace all old thermal paste on everything that is mounted on a heat sink, as the original paste is 50 years old and hard as a rock. Use 99% alcohol to clean the thermal paste.
                            • petehall347
                              • Jan 2015
                              • 4440
                              #34
                              can I use arctic silver 5 thermal compound? .
                              get some proper white stuff for the job . all that arctic silver stuff is not right for amplifiers
                              • rccrasher65
                                • Mar 2014
                                • 626
                                Thanks, for the advice. So it's best to remove the whole heat sink from the unit first, then remove old transistors, replace old compound with new, and place new transistors on heat sink. I'll order some white thermal compound too.
                                • rccrasher65
                                  • Mar 2014
                                  • 626
                                  Ok, I'll give that a try, will need to order white thermal compound. THANKS
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8331
                                    You can leave the transistors on the heatsink, you just have to desolder them first from the PCB. Then pull the heat sink with the transistors attached off the board. The important thing is you mount the transistors with the thermal paste to the heatsink first. Then solder.
                                    • rccrasher65
                                      • Mar 2014
                                      • 626
                                      Sounds good, I got them, one screw head was a little jacked up, but it came out. I'm still stumped on one diode, it's the zener diode XZ-100, kenwood part number is V11-4104-10. I have found really no answere for a replacement, just guessing it could be a 10v, not really sure, hoping someone could give it a shot in finding out an equivalent. Looking foreward to my parts all arriving on friday and Mon, at the latest.
                                      • petehall347
                                        • Jan 2015
                                        • 4440
                                        #39
                                        d9 d10 is it ? remove one and use resistor and 2x 9v batteries and volt meter .
                                        • CapLeaker
                                          Leaking Member
                                          • Dec 2014
                                          • 8331
                                          These XZxxx zeners are a bit weird numbered. For example a XZ051 equals a 5.1V zener. It is NOT a 51V zener.
                                          So what you are looking at is a XZ100 zener. That makes it a 10V. Check it out like petehall347 said above.
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                          • DrDos
                                            Unit runs but no speaker output kenwood KR-6030
                                            by DrDos
                                            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                            09-14-2025, 09:57 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
