Ouch!
KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
It could be, but I think Petehall is right, I'm using stainless steel drill bits, trying to drill hardened steel, not getting anywhere in depth because of wrong bit, going to try some carbide bits. The darn set screw is only 3mm in length. When I take bit out and measure depth, I'm not even half way. I'll keep at it, till I get it off, may take awhile. I think I'm a little to far gone to try a left hand drill bit.Comment
I ordered a set of carbide bits, should be here sat. Has anyone had this much trouble with this, or is it just me. In the mean time I'll go back and double check everything, I've done so far, with the components. I'll list all the bad one's that I found. I want to recap the unit, as an ultimate goal for this amp. I've been extra careful not to enlargen the small set screw hole, while doing this, it's at an 1/8in, just a tad larger than original hole by a 1/32, wanted to make sure I got the hole grub screw out, so I can re tap. Have a great weekend guys,and thanks for hanging in there with me, much appreciated. Maybe we can get back to fixing electronics instead of farting with drilling shit out.Comment
All better now,unfortunately, we have alot of them, I call them entitled little bioches. Glad I'm retired, I couldn't, and wouldn't put up with that shit for to long.Comment
Carbide drill bits arrived, I have a mini camera that I'm going to try and get a peak under that knob, and see what's holding up the removal. Drilling blind sucks, and could cause too much damage. I'm going to see if this will help see what's going on. I'll post those bad components this evening.Comment
Well got a few more components to check, and I will be ready for a dim bulb test. Hope for no light, and good working amp. I will also list, all the damaged components I found. There wasn't as many as I thought 6 or seven, but I replaced alot, even if they were good. Caps, transistors, a few resistors, that were bad ,or burned up dark looking,but still working.Goinf to post some pics as well of the board.Comment
Here are the components that were found to be bad. First the two output transistors near Q11. The two were completely dead no readings at all when removed. Q11 was deemed to be ok, but with low readings. It was changed, as was all the rest. Q10, Q9, Q12. Q9 also tested ok ,but with low readings. Next were resistors R23, burnt black, open no reading.R1as well. R3, 21,5,19,6 were all dark and replaced. Transistor Q5 was dead as well as Q1. I replaced all 8 of them anyway. All caps were replaced, one tested bad, C 6. Those are the components that were found to be bad. I replaced all 4 output transistors to keep things even. I want to check a few more things before I use the dim bulb tester. I will post some pics of the board as well.Comment
Those are nice to do, love those multi pin Ic's, get to use hot air, and drag solder techniques. Monday I think will be the day I test the amp to see how we did. All the best on your project.Did you get that welder figured out?Comment
No... I was about to fiddle around with the programmable input and output pins, dragging them into the opposite direction on the ATMEGA and see if something changes on the blue LED or on the gas valve. I was hoping to find a problem with a pin, then backtracking the circuit. Then I was on the road and never made it back to the welder.Comment
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by jm1234Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but... -
by edugimenoHi everyone!
I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
I respected the polarity, positive to cathode of protecting diode
So provided all... -
by hartleyhare5Post body:
I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the... -
by DrDosI have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...1 Photo
- Loading...
