KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
  • rccrasher65
    • Mar 2014
    • 626
    d9 d10 is it ? remove one and use resistor and 2x 9v batteries and volt meter .
    Not exactly sure, just looking at parts list. Never did what you are suggesting. Will need additional instructions. Thanks. I found all parts that were originals, except zener diode.
    • rccrasher65
      • Mar 2014
      • 626
      These XZxxx zeners are a bit weird numbered. For example a XZ051 equals a 5.1V zener. It is NOT a 51V zener.
      So what you are looking at is a XZ100 zener. That makes it a 10V. Check it out like petehall347 said above.
      I did order about 8- 10v zeners, I thought it was a 10v, but wasn't sure.
      • rccrasher65
        • Mar 2014
        • 626
        Yes, D9-10
        • rccrasher65
          • Mar 2014
          • 626
          Also looking for equivalent to WZ-300, WZ-240, these are zeners, and Diode 1N60. Any suggestions. Trying to find replacements for the plate resistors as well, they are 33ohm, 10% 3W resistors.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8331
            Geez... all that is broken? Can't be.
            The 1N60 is a germanium diode. It is still available for sale for example futurelec.com. Also 1N34A, BAT41,1N60P etc.
            WZ series zener diodes are 0.5 Watt type. Again a WZ240 = 24V. WZ300 = 30V.
            As for the plate resistors... I dunno. Are they bad?
            • rccrasher65
              • Mar 2014
              • 626
              No, not all are bad, but I have two of these amps, mine, and my dad's which we are currently working on.I plan on doing a complete overhaul on both eventually so I'm locating parts for both.My philosophy is If I'm pulling it out to check it, it's getting replaced good or bad. I only work on my stuff, and the parts are not that crazy expensive. Except those output Trans I blew. I do believe some parts are coming today. Thanks again for all your help on this project.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8331
                I get the germanium diodes… they can break by just using too much heat. The resistors, I’d leave alone unless they are burnt, open, or out of tolerance. Definitely change all the caps then.
                • rccrasher65
                  • Mar 2014
                  • 626
                  Most of them resistors are dark, I will check each piece, as I go along,I do have enough to replace all components on the the board though. I'm going to replace everything on that side by Trans.Q11 the problem in the first place, before I caused the rest of the damage with my slip.
                  • rccrasher65
                    • Mar 2014
                    • 626
                    Well parts came in and, most of the resistors have to be returned, so It will be another week at least before I can get started. I do have the big output transistors so I'm going to start there, then the smaller Trans. Caps will follow. At that point I should have the resistors. I will change everything around Q11, because of the short I caused. I,'LL post pics of each step. Thanks guys, and have a great weekend.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8331
                      Maybe take on high resolution picture from the boards each from top, it’s kind of hard to follow a board in sections.
                      • rccrasher65
                        • Mar 2014
                        • 626
                        Ok will get that this weekend, and post.Have a great weekend sir.
                        • rccrasher65
                          • Mar 2014
                          • 626
                          Starting on Tuesday replacing, some components. I will start with Q11, and do those 4 transistors, then the caps, followed by the 4 big output transistors. I'll post some pics as I go along.
                          • rccrasher65
                            • Mar 2014
                            • 626
                            Started today with some component replacement.I decided to start with the hardest first, those output transistors, 5 1/2hrs for 2. What a PITA, those were, who ever designed this needs a good ass kicking, but they got done with a lot of words not permitted here. Once they are done, tomorrow, I will post some pics. Then onto Q11, Q10, Q9 ect. Caps will follow. Thanks for your patience guys, will keep you posted. Thanks again.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8331
                              Ha! You not the only one that can swear like @#$&! There are MUCH worse things than an amp! But this is just about a daily thing these days.
                              • rccrasher65
                                • Mar 2014
                                • 626
                                I agree, they are all done and soldered in. I'm going to post some pics, and move on to Q11, Q10, ect. The two output transistors near Q11, were definately blown. The other two tested ok, but all 4 were replaced.
                                • rccrasher65
                                  • Mar 2014
                                  • 626
                                  Here are some pics, they are all over the place in phone instead of one folder, still learning this pic attachment crap. I'll get better as we go along.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8331
                                    You are right and change always that transistor pair if you can. Getting along nicely now!
                                    • rccrasher65
                                      • Mar 2014
                                      • 626
                                      Just a quick check of resistors in area of Q11, Q9 found res.23 smoked, open, res1 smoked, open.most other look good so far,and testing fine, but will double check them all. My new resistors are same value as on parts list, but are considerably smaller in physical size, will this be a problem.
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8331
                                        you mean R11 and R23. These should have the same wattage rating (size) than the old ones. I think they should be a standard 1/4w resistor. R11 should be a 3.5kohm and R23 should be 82ohm.
                                        If you put a smaller wattage rated resistor in, it may not be able to handle the current and go "poof" or overheat.
                                        • rccrasher65
                                          • Mar 2014
                                          • 626
                                          No,you didn't understand me when I said smaller size, The values are all the same, Meaning, res 23 is 82 ohm. 5% 1/4 W. .My new resistor has same exact value, but is physically smaller in size. I just noticed that there are 2 versions of this amp.we are working on the X09-1320-10 A/2, J25-1616-12 A/2, .My other KA-701 has the X09-1320-10 A/2, J25-1056-02 A/2..There is no R11 on the board we are working on, it's even marked on board R1, same with parts list for power amp. There is no R11, just R-1-4, R-5,6. R-19-22 a d so on.
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                          • DrDos
                                            Unit runs but no speaker output kenwood KR-6030
                                            by DrDos
                                            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                            09-14-2025, 09:57 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
