KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
  • rccrasher65
    • Mar 2014
    • 626
    All 4 measure in, and out of circuit. 0.905- 0.907K ohms.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Dunno what to say. 0.970k is a huge difference than 970M! However resistors do not go lower in resistance. Over my whole career repairing chit I came across one resistor that was basically a short, thus lowered the resistance it should have had.
      Maybe try a different DMM? Measure out of circuit of course and keep your fingers off.
      • petehall347
        • Jan 2015
        • 4451
        #83
        910 ohms Click image for larger version
Name:	Screenshot from 2025-05-18 16-36-51.png
        • petehall347
          • Jan 2015
          • 4451
          #84
          check out the colours of r69 r70 r73 and r74 they should also be 910 ohms .. white brown brown is 910 ohms .
          • rccrasher65
            • Mar 2014
            • 626
            I, don't know either, I removed all 4, checked them out of circuit. They measure between 0.905K- 0.907K. I will change batteries in DMM. Only thing that I can think is that the colors maybe faded, but you can see in the pics I posted. When I put those colors in a resistor color chart, they come up with 970M. When I see them I see, white, violet, violet, gold as the colors. The violet could be brown I don't know. The board is different than schematics too.We have more than one version. I have two different KA-701 amp with different versions of this board. They seem original, and no one to my knowledge has ever worked on this amp.These resistors are not even on the parts list. They are R7,8,9,10. How can 4 resistors shit the bed, and have the same reading in, and out of circuit. Never saw this either.
            • rccrasher65
              • Mar 2014
              • 626
              I see it on the schematic, I took a picture of the other KA -701 amp I have with the different board. I'll post it here. Tell me what colors you see. I see white brown brown. Gold. The resistor is R 7. I do believe the colors have faded on the one we are working on, and they are brown instead of violet. Check the pictures out, see what you think. Click image for larger version
              • rccrasher65
                • Mar 2014
                • 626
                Now this pic is of the amp we are working on
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  Sure enough! Looks just like you said to me too. It is a 50 year old amp after all… heat, sunshine can effect colours. In this case I would have gone after the measured value. There was obviously something wrong with the meter or the decode process. Resistors don’t short, they go higher in resistance until it opens up.
                  • rccrasher65
                    • Mar 2014
                    • 626
                    I'll check my meter as well it is very expensive, but aging. I'll replace batteries first, see if anything changes. Should I replace those resistors? I'll have to order some because, they were not on the parts list.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8352
                      nah... I wouldn't replace them. I'd replace only if these would be out of tolerance or burnt.
                      • rccrasher65
                        • Mar 2014
                        • 626
                        I checked them with another component tester, they test ok, reading of 925.1
                        • rccrasher65
                          • Mar 2014
                          • 626
                          I guess, my meter is starting to shit the bed, time for a new one, now on to the small black transistors. I'll start on the Q11 side with Q7, Q5, I f these test good I'm just going to put them back in, instead of replacing, maybe on this side I will replace , just because this is the side that started all this crap in the first place. Thanks Cap
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8352
                            Very funny. My cheap @$$ 13 year old Canadian Tire Auto Ranging DMM I had bought on sale for $20 shit the bed today. I used it in the garage only… who cares… no major loss. Would be much different if my Flukes or Agilent DMM’s takes a dump. Then the calibration certificate is another thing. Not so easy here on my bench.
                            • rccrasher65
                              • Mar 2014
                              • 626
                              Yea, I'll have to look into a new one now that I don't trust it. $150 Klein 25yrs old. Glad my flukes are ok. Retired 3 yrs ago, will not replace them now. I checked Q5, it shit the bed, so it's replaced, Now on to Q7. I had to take a break this afternoon so I'll get back to it this evening. Sorry about the music in the vid, was louder than I thought.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8352
                                For a new toy DMM with o'scope and gen, I pulled the trigger on a Owon HDS2202S. Was cheapest on Amazon!? Retired an Extech DMM for garage duty now.
                                I did a research on that FNIRSI component tester of yours, but I wasn't happy with the result. Specifically its cheating on capacitors ESR. Maybe it is a firmware issue and they fixed it by know, I don't know. The vids I seen were a quite a few months old mostly using firmware 1.0.3. and around there. How do you like it? I am using a Peak Atlas DCA Pro.
                                • petehall347
                                  • Jan 2015
                                  • 4451
                                  #96
                                  get a nice manual multimeter .non of that autoranging rubbish .
                                  • rccrasher65
                                    • Mar 2014
                                    • 626
                                    This is a new and updated one, it can also update the firmware when avaliable, no pro shit here, only a ten yr hobbiest, retired electrician, Ind, light commercial, ending in residential. Uncles were electrical engineers.It works like a dream, love it, caught alot of shit on this amp so far, just like the resistors. Good enough for me, and what I do.
                                    • rccrasher65
                                      • Mar 2014
                                      • 626
                                      I was thinking the same thing. I'll probably get another klein. This one still does good for electrical. No need to test for component level. So off it goes. I got my yrs , and Money out of it.
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8352
                                        Any auto ranging can be set to not auto range. I want it for the portable oscilloscope and DMM in one and it has dual channels. I don’t have a portable oscilloscope, but would come in very handy for my odd ball work from time to time. It’s not for my bench, it’s for being out.
                                        • rccrasher65
                                          • Mar 2014
                                          • 626
                                          Yea , all those toys are great to have, always wanted one, but most of that chit is way beyond my scope of expertise. I'm just a hobbiest, with the love for fixing shit.My problem is I have too many expensive hobbies. I got the first 4 small black transistors done 2 were smoked, would even give a reading . I'll do the other 4 tonight, after that all that's left is the diodes. They all checked out in circuit, voltage in one direction OL in the other.
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                          • DrDos
                                            Unit runs but no speaker output kenwood KR-6030
                                            by DrDos
                                            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                            09-14-2025, 09:57 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
