LCD 2DIN CAR radio screen problem
  • domix
    • Jan 2014
    • 166
    • Slovenia
    I have this china no name car radio, touch screen 7''.
    I have no picture on it, only buttons have light, screen are black. I open it and i meassured caps so 2 of them have strange values, migth this is the problem?
    100uF-97uF
    47uF-43,7uF
    22uF-20,9uF
    22uF-21,7uF
    100uF-118,3uF
    22uF-118,5uF
    22uF-22,3uF
    1uF-1,1uF
    4,7uF-20,1uF
    Re: LCD 2DIN CAR radio screen problem
    Did you remove the caps and test them off the board? It sounds like you do not have backlights for the screen. Need good clear pictures of the screen assembly so we can see the wires of the LCD panel. From you pictures I cannot tell if it uses high voltage for the CCFL backlights or LED backlights type.
      • 31019
      it's led - i had one.
      and it's a nightmare to strip because they put glue over all the ribbon-connectors!
      • lti
        • May 2011
        • 2548
        The capacitance measurements are fine. C4 and C14 are in parallel, so you should see around 122uF. Also, C16, C17, C20, and C24 appear to be in parallel. You're measuring the combined capacitance of all those caps.
        • domix
          • Jan 2014
          • 166
          • Slovenia
          So, how to fix it? Is it lcd inverter? can i connect this lcd from car to inverter on pc lcd or laptop lcd inverter, to se if i have backlight? or it will burn lcd?
            • 31019
            it will destroy the dislpay panel if you connect it to an invertor.
            • domix
              • Jan 2014
              • 166
              • Slovenia
              Then it is best to throw it away, and buy new one ? i can connet it to the external display, but only when i turn radio on screen blinks and than is black image on ext, diplay.
                • 31019
                does the touchscreen work?
                i mean - is it *just* a backlight problem?
                • domix
                  • Jan 2014
                  • 166
                  • Slovenia
                  i dont' know for touch, it it not my radio so i dont know where to press it to something work :P
                    • 31019
                    o.k. press the eject button to make the front open and put a music cd in it.
                    if it takes it in and plays it we can assume it's working.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I don't know how is this receiver, but since the display is moving, it may be a broken ribbon cable also.
                      This is why, I don't like the 7" screen receivers or the flip out ones.
                      Did you try using a flashlight on the screen, while playing a DVD, to see if there is an image on the screen?
                      • domix
                        • Jan 2014
                        • 166
                        • Slovenia
                        with flashlight i don't see nothing on the screen, even if i put the cd in, nothing happens, only cd start to spin and that all, if i press any buttons on the screen or on remothe is only beep sound, if i pres eject or up and down than display moves down
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Check the ribbon cable for damages, between the LCD and the main unit.
                          I'm not familiar with this receiver, some pictures may help.
                            • 31019
                            i think the main system is not running or as said - a bad connection.
                            • domix
                              • Jan 2014
                              • 166
                              • Slovenia
                              it is this one
                              http://www.chinavasion.com/china/who...WIFI_GPS_DVB-T
                              i will open the main unit when i come home, and than will see. i even dnot know what to press because, i got it that dont' work.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                If he can play a DVD and buttons beep, in my opinion the system it's working.
                                Did you measure the voltage going to the LEDs?
                                • domix
                                  • Jan 2014
                                  • 166
                                  • Slovenia
                                  how can i measure that? dvd wont play, or maybe it is, but i don't know what to pres, autoplay don't work
                                  • domix
                                    • Jan 2014
                                    • 166
                                    • Slovenia
                                    now i opend main unit, is there something i must to check
                                    • domix
                                      • Jan 2014
                                      • 166
                                      • Slovenia
                                      any solutions?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I'm not here only occasionally.
                                        In the last picture there is a red and black wire with a little white connector on top of the board, that supplies the backlight power to the LEDs.
                                        See, if you are getting any voltage there. If they are LEDs, it shouldn't be high voltage there.
                                        If they are CCFL tubes, you most likely shouldn't measure that connector.
                                        I'm not familiar with these units, I have opened up only Kenwoods.
                                        • mmccomputer
                                          problem with replacing lcd screen
                                          by mmccomputer
                                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                          If anyone has any information on the subject...
                                          12-15-2024, 03:44 PM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
