problem with replacing lcd screen
  • mmccomputer
    • 71
    • France
    I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
    otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
    If anyone has any information on the subject I would appreciate it​
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Share part number of original screen as well as the new screens you tried.
    • mmccomputer
      • 71
      • France
      original screen is : N140BGA-EA4
      and i tested NV140FHM-N69 , NV140WUM-N43 and moore others but not working (only backlite)
      • mmccomputer
        • 71
        • France
        I wonder if it's not the bios that blocks the display like with incompatible wifi cards and if there is a way to modify this, if anyone has already had this problem and managed to solve it
        • pc_okay
          • May 2022
          • 243
          • FRANCE
          Your screen is HD (N140BGA-EA4) and you try with 2 models FHD ! (NV140FHM-N69 , NV140WUM-N43 are Full HD 1920X1200)
          Please try with an HD screen. (1366X768)
          • mmccomputer
            • 71
            • France
            N140BGA-EA4 its a FHD 1080p TN and works perfectly but with any another FHD IPS not working, i tried with NT140WHM-N41 (1366*768) its worked, but my goal is to have a functional FHD IPS screen
            • Ady2017
              Does anyone know about 16x2 LCD screens used in alarm keypads?
              by Ady2017
              I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was...
              06-02-2025, 04:56 PM
            • ipatch
              ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
              by ipatch
              i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
              08-24-2024, 02:36 PM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • HTR-Informatique
              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
              by HTR-Informatique
              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
              I also changed the screen because the PC fell and the screen was broken.
              I changed the battery with a new and original battery.
              I also had corrosion/oxidation on the...
              02-09-2025, 06:51 AM
            • Ado02
              Lenovo Thinkpad X1 Gen 10 - Flickering Screen
              by Ado02
              We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
              The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
              12-16-2024, 02:33 PM
