Vintage GE Alarm clock/ tube radio
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Picked up my 1st tube radio for $5:
    It has issues... so far, I know it doesn't run. It also looks to have been in a barn or arric for some time:
    It has some nice features:
    From looking at the pcb through the vents, I saw a burnt trace and lots of bad joints... I also saw a datecode sticker that tells me it was made in the 26th week of 1956.
    Besides the series light bulb trick, are there any general pointers I should know?
    sigpic
    (Insert witty quote here)
    Re: Vintage GE Alarm clock/ tube radio
    Check ALL the paper caps for short or leakage or just replace them with orange drops cap, if the coupling cap between stage has leakage, it will cause the tube to be bias on badly, you may see the output plate of the final audio output stage turns red hot.
    I would use the Variac or lamp to slowly bring up the B+ to reform the DC filter caps but should check for shorts first, also check to see if it has any cap connected between the chassis to either wire of the power cord, be careful and replace that cap with X/Y type using polarized cord, if you touch the chassis and your body is grounded, you may get nasty shock!
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Same as budm said;
      Also, it is common for old resistors to change value without ANY physical signs (I.E. black marks, discoloring, crumbling) of being bad.
      Muh-soggy-knee
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I'm not swapping the cord since the stock cord is in great shape and I don't want to kill it's antique value.
        By orange drop caps what do you mean? I'm new Vacuum tube style electronics and I may need the "noob treatment" at first here.
        sigpic
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          These
          Muh-soggy-knee
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Ah, mylar film caps. I'm used to them being a dark red...
            sigpic
              And at least do the AC leakage current check for safety in case something inside has insulation breakdown.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                the 2 most important are the across the line/line to chassis.the old paper caps will be quite leaky and may go bang.
                and as mentioned the coupling cap to the 50c5/50l6 grid.
                all paper caps and lytics get replaced here.
                shorted lytics will kill the 35w4/35z5 heater.
                if the telechron motor is stuck/noisy i have a procedure to save it too.
                if this thing has black caps with resistor color code stripes they are bad too.called black beauties we call em black leakies.audiophools want them so dont toss.
                you may be able to fund the parts for the restoration by ebaying them!
                this is a fine first radio restoration.easy to do and not much to lose if you goof.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  dont forget these are "hot chassis"
                  one side of the ac line is chassis ground.
                  depending on how its plugged in it could be the hot rather than neutral.touch it and a grounded object and ZAP!!
                  • twbranch
                    Mad Nerd
                    • Oct 2012
                    • 153
                    as a tech with experience working on tubed electronics always use a variac to power it up slowly. It could be in perfect condition and the sudden burst of electricity could cause a ton of issues with old equipment. I have two scopes that are tube and they always connected to variac.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      What if I don't have a variac?
                      sigpic
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Make a ghetto variac! with switches, and lightbulbs, to increase the maximum power flow bit by bit. By switching on and off different bulbs (sometimes in combinations together) you can make a basic variac.
                        A real variac uses a transformer though. But its the same principle, the graphite brush on the variac goes from winding to winding on the variac when you turn the knob. A variac is basically a variable autotransformer.
                        Muh-soggy-knee
                        • gilly1984
                          • 751
                          Can a simple variac be made using a dimmer switch for a light?
                          http://www.google.co.uk/products/cat...ed=0CE8Q8wIwAg
                          Could use a DMM to write down the voltages on the faceplate?
                          Obviously just to be used on low wattage electricals.
                          Just a thought.
                          Do NOT touch heatsinks when testing for voltages as they may be LIVE!
                          • twbranch
                            Mad Nerd
                            • Oct 2012
                            • 153
                            All a variac is is two transformers back to back. Probably find plans online to build one. Google it. I would but I am at work and shouldn't be here anyway!
                              VARIAC is just a TOROID Auto transformer with movable contact so you can adjust the output depends on where the tap is. I used it everyday.
                              http://www.nmr.mgh.harvard.edu/~reese/VariacPage/
                              • twbranch
                                Mad Nerd
                                • Oct 2012
                                • 153
                                Nice link. More than I will ever need to know!
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Just a thought.
                                  I looked it up, they produce sawtooth waves, not sine waves. Not good
                                  Looks like I may have to wait on the project until I can get a used one cheap or the like. I don't think my college has one I have access to.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    I opened the beast... and here's some pics:
                                    I had already pulled the tubes, whose postions were included on a paper guide inside the unit:
                                    It's pretty nasty inside:
                                    As shown, there are black beauties inside... I didn't find any paper caps or obvious lytics... maybe I am missing something here.
                                    Another black beauty:
                                    When I opened it, the antenna mount was busted:
                                    I think I can use a 1/2" black plastic cable clamp/mount to replace that...
                                    I also restrung the tuner pulley system... the existing string was loose; I added a few knots to get it back to the correct length. However, the varicap is hardish to turn... any way to lube one of those without messing up it's cap range?
                                    It looks like I need to order some mylar caps... how does one translate the color codes on the black beauties (as in where does the range start)?
                                    I also built a series lightbulb rig... it has an on-off switch for the output and a switch to switch it between series light bulb and full 120V.
                                    sigpic
                                      Boy, those are the same set of tubes I used to build my first electronics project when I was 14 years old. I had to save a lot of money to come up with all the parts. Built on a wooden chassis that is lined with aluminum foil.
                                      • delaware74b
                                        • Apr 2009
                                        • 628
                                        RD - the electrolytic cap is the large round bare metal can, seen from your first and third photos in post #18.
                                        It looks like a combo 75 and 30uF cap.
                                        Stupidity should be a crime, especially for drivers. I have NO patience for them.
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
                                          HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 02:00 PM
                                        • Omron
                                          Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                          by Omron
                                          Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                          My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                          - Tried to unplug radio and plug it back in into power,
                                          - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                          - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                          05-23-2024, 01:27 PM
