Vintage GE Alarm clock/ tube radio
Re: Vintage GE Alarm clock/ tube radio
Ordered the caps (I had some other crap to get and lumped the shipping).
Question: I found a Black plastic radial Lytic (labeled .047 MFD)... Is the side with the text the + or the - ?sigpic
(Insert witty quote here)Comment
Picture?
Are you sure its not a film cap?
If it doesn't show any plus or minus, then it must either be a non-polar electrolytic, or a film capacitor.Muh-soggy-kneeComment
It was pyramid brand... I think I saw a dash on the text side but I frankly couldn't tell (it was worn off). It was mounted right by the variable capacitor (To read the printed specs, I had to desolder it).sigpic
Between the capacitor frame and chassis?
It's a paper cap. The outer foil was marked with a "-" on those. This would sometimes be used to shield a Hi-Z ckt by having the outer foil grounded or at some low impedance, and the "inner foil" was the signal or whatever.
But they were not polarized.
It might be a paper-in-oil cap, but those were/are more likely to be found in "more sophisticated"/more expensive equipment such as HiFi tone controls, etc.
-Paul"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
Be sure to replace the 75/30uF cap with caps rated to at least 105*C. Unlike a motherboard or PSU, you can use general caps here. You will have to use modern values for these:
30uF/150V = 33uF/160V
75uF/150V = 82uF/160V (you can also use 100uF/160V if you have one)
If you have access to a tube tester, give your tubes a test. the 50C5 is the most likely to have leakage. (hint: if after a total recap you get a low level hum, the 50C5 most likely has "Heater-Cathode" leakage.)
Your radio also uses the smaller IF transformers, IFs from this time frame use silver mica capacitors, and tend to suffer from a symptom called "Silver Mica Disease". Symptoms of this are loud static crashes (like lightning interference) across the dial. This is usually repairable by cutting out the silver mica wafers in the transformer, and tacking on similar valued caps under the chassis on the tx legs. (around 100pF or so)
Your radio also has what are known as "Couplates" (the multi legged brown flat components that look like caps). These actually contain a network of resistors and capacitors. These rarely ever go bad, but in the event you do get a bad one, they can be fabricated using perfboard and modern components.
Tube layout on yours is a slightly odd duck, It's an "AA5" (All American 5), but with a 12AU6 in place of the more commonly used 12BA6. First time I've seen that done, unless maybe at the time this radio was made, GE had a massive batch of 12AU6s handy? (both are essentially the same tube, usually the AU6 is found in FM service)
Good luck!
If you don't have a tube tester and the set appears dead, then you likely have a tube with a burned out heater (basically a light bulb filament that gives the tubes their glow). When I did my old radio I quickly determined that these are all in series. So when one goes, the whole thing goes dark. Since I didn't have a tube tester, I had to look at the schematic to determine which two pins were for the heater and then check each tube for open circuit. Granted there could be other issues with the tubes that are causing problems. In my case, I did find one bad one and replacing it brought the set back to life. Of course I did a full re-cap also.Comment
I haven't powered it on. I won't until I recap it, and when I do, my university lab has a few variacs that they will let me use to power it on for the first time. Until then, I have no idea what does and doesn't work.
Noted on the one cap being non-polarized. I'll replace it with one of the spare 600V mylar caps of the same value.
The lytics are IIRC 105C. I bought the same values you suggested, 33uf and 82uf.
I don't have tube tester access...
I saw the Couplate on the board... I figured it was some sort of capacitor network or the like.sigpic
Shouldn't be too hard to find a tester for a decent price, I use a Sencore TC142 "Mighty Mite" for everything. (Tests everything except the 4/5/6 pin tubes)
I'd say after the recap, give er power, there's no power transformer to risk frying in this one.
Wait till you score a 30s/40s console radio, then the "fun" really begins
Got the solder work done.
I'll power it up on monday when I have variac access.
In the mean time... the Variable Capacitor is kinda sticky. What is the safest thing to use to lubricate it? (w/o messing up the dielectric properties of it)sigpic
Noted, I may try some ATF.
Also of note: After looking at the PCB, I was able to figure out which tube pins were heater pins... and I checked for any opens... with the tubes in, there were none. Just enough reisistance to tell me its not shorted but not a lot.sigpic
lol
I always just call them film caps, to avoid looking stupid
Ratdude: A google search reveals you can use a light oil, such as sewing machine oil, in the ball bearings of the tuning capacitor. Be careful to not bend the capacitors' plates! Have a look at this
sigpic
why?
all the caps are new now.
first test with a dimbulb if it makes you feel better.double check your work and fire it up.worst case you got the 2 filter caps in backwards.
watch the 35z5/35w4 as it warms up.
if it gets suddenly bright pull the plug you have a b+ short.Comment
most common is the 12be6.
Good luck!
by shelby5041hi
ive got a modern digital clock radio approx 15yrs old
my question is how long can a clock radio or a simple radio last ss farcas operating hours?
since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
it uses very little power just a few watts i would imagine that may have something... -
by UserXPDear all,
I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
My question is, do you know of this brand of capacitors and how bad are...-
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....09-12-2024, 02:00 PM
by OmronHello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
- Tried to unplug radio and plug it back in into power,
- Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
- Tried to hold 3,6 while turning it back on and then pressing 1,2...-
- Loading...
