Genius SP-HF1250X - 2.0 speakers
  • bocca
    • Mar 2012
    • 107
    • Serbia
    Re: Genius SP-HF1250X - 2.0 speakers
    I do have visual access, but my speakers are at my home, and I'm at work, so I'll do all that when I'm back home!
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Ok!
      Muh-soggy-knee
      • 999999999
        • Sep 2006
        • 774
        Measure the voltage at the V+/V- pins and ground for the LM4558 as Ben7 suggested. If it is not so high as to damage the opamp, then replace the two large caps right after the diodes. If it is too high and damaged the opamp, replace that too.
        • bocca
          • Mar 2012
          • 107
          • Serbia
          Hi ben7.
          OK, i plugged it in again, and watched the speaker cone. It doesn't suck in, nor does it push out. It starts vibrating immideately, first small vibrations, for a second, and then with, i guess, full power.
          Measured what you told me. Upper black contact measures 0.48, and lower is at zero. Multimeteris set to 20V
          edit: that was with the speakers turned off. When I turned them on, voltage on the upper is about 9.27 (it's variable, but around that value), and on the lower is constant -0.7. Multimeter is again, on the 20V setting.
          Those black circles are legs of the two caps (100 uf, 25v).
          I am looking for the 4558 datasheet so i'll know where are v+ and v- legs. Then i'll do the reading
          • bocca
            • Mar 2012
            • 107
            • Serbia
            OK, so here's the datasheet:
            http://html.alldatasheet.com/html-pd.../1/LM4558.html
            What should I measure? And should i do it with the speakers powered on?
            • Evil Lurker
              Warranty Voider
              • Feb 2011
              • 454
              #26
              I see NP on the electrolytics... are those nonpolarized caps?
                Pin 4 is B-, pin 8 is B+ on the OP-AMP. You put the black probe of the meter to the DC ground (you can use the RCA input jack outer body for ground, the red will be used fro checking the voltage with speaker on.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Hi ben7.
                  YAY, a problem! The lower should be just about the same voltage as the upper, but negative. So the lower one should be about -9v.
                  FYI: I traced the tracks, which was very easy due to the good pictures, and those are the + and - power rails for the opamp.
                  Can you please measure the resistance of R44 (its a 470 ohm resistor)?
                  Muh-soggy-knee
                  • bocca
                    • Mar 2012
                    • 107
                    • Serbia
                    #29
                    will be done tonight people. Once again, you have big thank you for your patience!
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Any success?
                      Muh-soggy-knee
                        Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                        by momaka
                        More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                        02-15-2022, 12:43 AM
                      • Widget
                        Logitech R20 speakers - Replacing one of the speakers.
                        by Widget
                        Hi guys,
                        I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                        Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                        Printed on the back of the Logitech speaker is;
                        LOGITECH...
                        05-29-2024, 07:07 AM
                      • RetroComputingGrotto
                        Behringer MS16 Speakers - Low Volume on One Speaker
                        by RetroComputingGrotto
                        I've had a set of speakers come in with the fault of not powering on.
                        I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
                        1 random loose nut and part of a BIC Biro pen.
                        After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
                        05-20-2024, 07:29 AM
                        Acoustic Audio GX-400 speakers
                        by momaka
                        Part 1 - Acoustic Audio GX-400 build "quality"
                        Not going to lie – this will be another silly audio post/thread. If you thought the cheap Panasonic Thrusters speakers I posted about last time were bad enough, then you are about to explore some new depths in lo-fi audio here. Ladies and gentlemen, I present you the Acoustic Audio GX-400 speakers... or speaker (only pictured one for better details )
                        Before I continue any further, perhaps you might be asking why I even bother to post about such crap audio gear (let alone keep it). The answer...
                        03-07-2019, 09:04 PM
                      • piipo
                        Old Privileg 5.1 speakers remote control question
                        by piipo
                        Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                        09-18-2024, 01:55 AM
