Re: Dim Clock LCD on Jenn-Air wall oven
I can't really tell from the pictures. But usually these things are made to snap together quickly on an assembly line. Is it possible that the tabs on both ends are what is holding the board down?
Ok - I have a Kenmore gas range with a 316080102 control board. The display has been getting progressively less bright for the last year or so. Now it's really hard to even see what temperature settings and readings are. The clock display is really dim as well. Anyhow, I removed the control board and display to see what caps I would need to order and replace, but I found another problem. The board with the caps is kind of sitting in a frame atop the display board. I would need to remove the "cap" board from the frame to gain access to the solder points of the caps. Is there a tool or a bit of "tribal knowledge" that will allow easy removal of the top board from the plastic frame without breaking anything? It really seems to be fitted quite tight into the frame.Leave a comment:
Another Jen-Air, model SVD48600, fixed thanks to the insights posted in this thread. Thanks!
Annoyingly, it developed the "constantly running broiler fan" problem at exactly the same time the clock gave up the ghost. I know I've seen others reference that problem in this thread, and I suspect that they may be related somehow. I've posted the details of my experience in the thread on that subject should anyone else be interested.Last edited by Kyrie; 02-05-2016, 06:37 PM.Leave a comment:
Thank you for your information. Picked up new Caps at radio Shack and replaced all except the one under the display. My soldering is not that good. Display works and wife is happy.
Thanks again.Leave a comment:
Yeah, mine looks just like that. Except that the resistor looks like it may have burned out. The solder spot on the board looked like it got hot. Probably after the holidays I'll experiment with some parts. Right now we're doing too much baking and holiday food prep to put the oven out of commission if I blow up the board while playing with it.
KenLeave a comment:
There was another one a while back in this thread that was a reconditioned part and had a resistor in line with the capacitor. Does it look like this?
https://www.badcaps.net/forum/showpo...&postcount=126
It is probably fine to just go back with a 68uf capacitor in the C3 position.Leave a comment:
My board, 71003424R, has a resistor in series with a 35v 220uf capacitor in the C3 position. Can these be replaced with a 68f 35v capacitor? Why is the resistor in the circuit? Thanks for your help!
KenLeave a comment:
You might have another part in the vicinity that looks exactly like that in the pic, but with two wires coning out of one end.
What connections are you referring to? Get a pic of those connections so we can see what is going on.Leave a comment:
Can you see it in the oven's parts list or diagram?
http://www.google.com/search?q=site%...22wall+oven%22Leave a comment:
Are there any numbers on it? Can you show it from another angle?Leave a comment:
Thanks for this info and can you tell me what this UL stamped part is for? I found stuck to the top of the oven opening and it is magnetized and the connections have rusted.
Welcome to the badcaps forums!
I guess I should have put all of that information in my original post. So after one more peek inside the oven, here are the specs and part numbers to order from Digikey. All part numbers listed are for Panasonic FC series capacitors. FM series part number shown in parenthesis where the FC series cap is out of stock at the time of this post.
On the clock module:
C1 & C4 470uF 35v P10301-ND (or the FM series: P12400-ND)
C3 68uF 35v P10292-ND
C7 22uF 50v P10318-ND
On my oven I also replaced the two caps on the power supply/relay board as a precaution. They were as follows:
3300uf 16v P10260-ND [filter cap] (or the FM series: P12373-ND)
47uf 50v P10321-ND [the only other cap on the board]
Of course the power supply/relay board could vary if you have a different model oven (gas for example).
Please update this thread if this information is useful and you are able to repair your clock module.Leave a comment:
Disregard. Fixed it dead. Going to buy new range.
http://cuug.ab.ca/kmcclary/WHIRLPOOL_RIP.JPGLast edited by KeithMcC; 09-18-2015, 01:15 PM.Leave a comment:
This is a Whirlpool
The LED display is OK, but the beeper has been getting weaker for months. Recently the up arrow button (by the beeper) stopped working (and beeping), and a few days later the oven light and clock buttons (down arrow still working).
Of course I don't know if the beeper and button issues are related.
There are three 220Ufx35V and two 1000Ufx6.3V. The 220s measured OK capacitance in-circuit. The 1000s didn't, but one measured OK out of circuit (replaced it from my junk box - didn't help).
Does this sound like a capacitor issue? (I know I should just replace them all, but I will have to have them shipped.)Leave a comment:
Just wanted to say thanks to Bluto and this site! Just successfully replaced the bad capacitor for my dimmed out oven clock. I have never soldered anything in my life or, sorry to say, even knew what a capacitor was but dammed if I was going to buy a new board without trying. Read the post, watched the video, bought all the equipment and voila!
Aint the internet great....Leave a comment:
If the board is anywhere near heat, just replace all the caps. If they arent cooked yet, they will be soon. Caps are cheap.
I did this for my oven this year. Oven was only a few years old too.Leave a comment:
Check the capacitor on pins 2 and 3 of ST7.Leave a comment:
Jenn-Air JDS9865BDP Range
Display became very dim about one week ago. It's very dim as you must have lights out or hand over display to tell it even works. Reading forums I learned that C3 capacitor is likely the cause but my model is newer different. I planned to replace the capacitor anyway but was unable to find a 57u rated 250V locally. I went to a TV repair store to see if they stocked them and they put a quick tester on them (while still on circuit board) and they said “that's not the problem”…. I had him put the same tester on C3, C6 and C7 which all tested good for what that's worth. So now I don't know if it's a waste of time to still replace them or if this is a different problem. Advice?Leave a comment:
Thanks .... just repaired my Jenn-Air SVE47600WC using the info in this forum. I had plenty of experience with soldering components so it was a breeze. My solder sucker makes removal simple. Those without experience should keep in mind not to use too much heat as it will damage the traces on the board.Leave a comment:
by asuwish824I recently purchased a Jenn Air Wall Oven model number jjs2730ws00. It functions properly except that the lcd display is rather dim. No adjustment in the settings seems to improve or even change the dimming/brightness of the display. My hope is I can repair the current display instead of purchasing a new or used unit to replace. I prefer to fix at the lowest point for the joy of the repair. Also throwing out what would otherwise be a perfectly good part just because perhaps a capacitor or other small part is bad seems obviously wasteful. Any guidance would be appreciated.
PS It... -
by Fsufan1391Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
by Joe24Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
I've been over the board looking for... -
by bpjlHello,
When starting the SEF 551.10 reflow oven, the following problem occurs:
It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer... -
One day my microwave oven stopped heating.
It would turn on and rotate the plate but no heat.
I removed the cover and checked components with digital multimeter.
Found that the high voltage fuse was blown.
This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
I replaced fuse and tried to heat up a glass of water.
Strange noise... - Loading...
