Re: Dim Clock LCD on Jenn-Air wall oven
30 minutes of reading, and 30 minutes to repair….thanks to this forum I just saved a couple hundred bucks. I was so close to ordering the new board before I stumbled across this topic. Thanks everyone. Now I can justify that new iPhone.
Congratulations on the repair. As for the remaining issues, make sure all your connectors are seated properly. In regards to the fan running all the time, that has been discussed in this thread: https://www.badcaps.net/forum/showthread.php?t=15001
There is no solution yet.
Thanks to this forum my own Jenn-Air is working fine. I ordered enough caps to fix my daughter's dim display as well. We replaced 2 caps (same brand, etc as the C4) and now everything works except that the fan runs constantly and timer 1 doesn't work. Timer 1 is no big deal but the fan is a problem. I can't find the circuit info on her stove to see what might be affecting the fan. Any suggestions?
Originally posted by Cougar View PostI'm not sure if replacing the other caps also will fix your particular problem since you say the clock part works ok. It wouldn't cost you much to replace all of them and see what happens. If it doesn't work you should be able to replace the board for around 240 dollars.
You might also try cleaning the ribbon cable connections to see if that helps. Pushing down on the end taps of the connector is supposed to release the cable.
Originally posted by ncredbird View PostI purchased my Jenn Air downdraft used as a replacement for a non working stove when we did some kitchen remodeling 3 years ago. It has functioned flawlessly until recently when the display went dark but is still functional. I just ordered parts listed above and am hopeful that I can get this baby fixed as the replacement board alone would cost me more than I paid for the stove itself. Just a side note here, I am a 60 year old woman whose only soldering experience has been with stained glass but I am going to give it a shot anyway. Will post back with results.Thank you, Thank you, Thank you.
Originally posted by Cougar View PostHe did do that and even cleaned the connections; unfortunately that isn't the trouble. We got close to fixing it. He may now end up replacing the unit since it is getting fairly old.
Originally posted by ben7 View PostMake sure the connector that connects the keypad to the circuit board is fully seated.Last edited by Cougar; 08-23-2012, 10:59 AM.
Originally posted by Cougar View PostWell, replacing capacitor C3 fixed the display problem but now the front panel control buttons aren't working for some reason.
Originally posted by waynetk View PostHi, I'm having problems with the portion my Jenn-Air oven display (Mdl WM27460W). The "clock" side of the display seems good but the side that shows the oven temp, etc. is not showing anything. Weill replacing the capacitors solve this problem? Thanks.
You might also try cleaning the ribbon cable connections to see if that helps. Pushing down on the end taps of the connector is supposed to release the cable.Last edited by Cougar; 08-19-2012, 06:03 PM.
A friend of mine asked me to help him with his Jenn-Air oven display. Apparently the display went out on his range but everything works as it should except for the display. This is the third time the trouble has happened and he has replaced the board twice with a cost of over 200 dollars for each repair. After searching the net a little for some info on the PC board I came across this site and signed up. We will try replacing capacitor C3 and see what happens. After reading the posts here it seems that will fix him up ok. I will send in a update with the results after a new cap is installed. Thanks for the help here fellas.
I am sure it is possible that there is something else afoot.... But as you said yourself, the oven works fine, all controls are functional, just a dimmed out display. This matches the symptoms that my oven had and just about everyone else that posted in this thread. I don't think anyone here claims to be an whirlpool-based oven expert, so I don't think you are going to get an alternative explanation for this issue on this forum. If you are worried about this second replacement, why not gamble $ to replace the capacitor on your original clock? You really don't have anything to lose. If it works you can send the replacements back to this shady sounding company and get the $$$ that you spent on it back.
Yes I have, but as I say I already have another replacement board in hand from the company I bought the first one from; I was just hesitant to install it for fear the actual problem was on some power supply board earlier in-line and it would just pop this one as well... at this point I'd just as soon replace the whole thing and be done. The first one I got from them was suspicious to start with, it wasn't in a box and it felt a bit greasy, so I wondered if it had come out of a used range somewhere. When I mentioned that on the phone the woman said, no, we would never d that and all our parts come new in the box. I told her this one hadn't and that it failed, she said I'll send another right out, she did and this one indeed was in a box and new. So I'll give it a shot.
Originally posted by jmcbrg View PostI also have the dimming LCD problem, Jenn Air SVD48600W model. Mine continued to get worse and worse, just like everybody else's but before seeing this forum I ordered a replacement clock module. I replaced it, it worked for about a week then that one went completely dim. The place where I bought the module sent me a replacement at no cost, but before I put it in I wanted to see if anyone knows of any other reason this could be happening. I realize the module they sent could have been faulty (it looked for all the world like a used piece; even felt a bit greasy as though it had come out of a different range rather than new). All the functions still work fine, controls the stove, everything beeps as it should, but the clock is dimmed out completely. Is there an additional board that I should be investigating?
--Jeff
@davnjax:
If the caps aren't bulged its still a good idea to replace them, they can go bad without bulging!
--Jeff
I had the local appliance repair company try to "fix" the oven. He has a good reputation and has been great on other things. He called Jenn Air when he was working on the oven because it would not register the temp increase he was trying to enter. Jenn Air tech said it needs a new board. I had installed a new thermostat and element prior to that service call but it made no change in the oven temp so I think we can rule out a bad element. The oven is in my vacation rental, when I get an open day I'll open the cover and check for bulged capacitors, etc so your comment to open it up and have a look is a point well taken. Thanks!!
Originally posted by davnjax View PostThanks to this forum my oven now has a display, etc. This was wonderful. Now I'm wondering how I could figure out if there is a bad capacitor in my other jenn air oven. I can't adjust the temp on that oven. That oven doesn't get as hot as it should. There are steps to input and bump the temp by 5 degree increments but they don't work. Jenn Air says I need a new control board so for now I'm setting the temp 20 degrees higher than I want to circumvent that problem.
Open it up and have a look inside
