Miele km5951
  • mblguy
    • Nov 2016
    • 14
    • Netherlands
    Re: Miele km5951
    Okey guys, i managed to keep the cooker. my parents bought a new one but i still really want to fix it because i believe it should be quite simple and not as expensive as a new one (1200 euro's). After i write this i am going to put it back together and test if it is one single cooker that is broken or if it is the whole system. until i have result. here are the pictures you guys asked for:
    The front left board
    The front right board
    The controller board (for the buttons)
    The total picture with the cover removed
    • diif
      • Feb 2014
      • 6978
      • England
      Re: Miele km5951
      Have you checked the bridge rectifiers and IGBT transistors for shorts ?
      They are the components at the bottom in photos 1 and 2.
      • mblguy
        • Nov 2016
        • 14
        • Netherlands
        Re: Miele km5951
        Hmm the rectifiers van be easily checked but how Do i check igbt's?
          • 31250
          Re: Miele km5951
          same way - look for shorts between the pins.
          • mblguy
            • Nov 2016
            • 14
            • Netherlands
            Re: Miele km5951
            Okey guys, today i checked some things.
            At first, all the hubs make short circuit so it is not only one cooker.
            Then i took the multimeter and checked the igbt's and rectifiers. I noted that the bottom left igbt and the rectifier from the bottom right board are both doing weird things. The igbt is completely shorted out and the rectifier does not rectify accordingly. I hope this clarifies some thing for you guys.
            Thanks for the help so far. I really appreciate it and like that we already got so far.
              Re: Miele km5951
              Remove and retest the suspected devices that were tested shorted in the circuit.
              • mblguy
                • Nov 2016
                • 14
                • Netherlands
                #27
                Re: Miele km5951
                Hey guys sorry it has been so long. I tried removing the units but my soldering kit was too weak. It didn't melt nicely so i had to get a better one. Now i managed to get the solders away nicely but i have to get the units out of that heatsink. they are reaally tight. How can i bend open the limbs of the heatsink so i can remove the units without crushing the whole board?
                hope there is some sneaky trick i did not know about.
                nice evening to you all.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  Re: Miele km5951
                  They look to be held on with three metal clips. Remove the clips and the IGBTs should just be resting on the heatsinks
                  • mblguy
                    • Nov 2016
                    • 14
                    • Netherlands
                    #29
                    Re: Miele km5951
                    Yeah i see, but there seems to be a lot of stress on them, so i am scared to break them or the components.
                      Re: Miele km5951
                      Remove the whole assembly out and you should be able to slide the clips out, they fit into the groove of the heatsink. Do not bend the clips' fingers too much, it will lose its tension.
                        • Jul 2011
                        • 6070
                        Re: Miele km5951
                        You may need to heat the pins of the IGBT and put a little pressure on that pin that you are heating until that pin moves then go to the next pin just do not put to much pressure on any one place
                        You may need to repeat this a couple of times before the ITGT module comes free
                        One very important thing to keep in mind do not get in a hurry when you do this you can make a real mess of the board if you do
                        If you have a heat gun station that has temperature control and air flow control put the smallest tip that you have blow the heat on that pin ( do not use to much air flow) and do things that have above with one difference move the pin until around unit the board solder cool down where pin dose not stick to the board
                        One note do not leave the heat gun tip in one place or you will burn the board and lift the pin right off the board
                        • chth96
                          How can I test coil whether it is really broken or not?
                          by chth96
                          I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
                          I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
                          I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
                          I want to replace this round black fuse and unidentified coil if it got broken.
                          02-20-2024, 01:07 AM
                        • waterchill
                          What part is this coil from a MacBook A2681 ?
                          by waterchill
                          Hi everyone
                          I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
                          So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
                          IAny ideas? It is from a MacBook A2681
                          Thank you...
                          08-08-2024, 01:46 AM
                        • Gjackson
                          ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                          by Gjackson
                          Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                          01-13-2024, 10:34 AM
                        • chth96
                          How Can I identify IFT coil?
                          by chth96
                          I have a CD unit which is came from saturn game console.
                          It always perceived Any retail CD or CD-R as Audio-CD.
                          Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
                          I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
                          I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
                          Is there any way to identify its frequency in order...
                          11-11-2022, 05:31 AM
                        • lerom
                          PowerEdge R740 coil resistance
                          by lerom
                          can anyone measure the resistance on coil L12 3.3V (near USB, EMMC chip) and coil L46 1V near CPU1 ?
                          thanks....
                          03-23-2025, 02:21 AM
