How can I test coil whether it is really broken or not?
This topic has been answered.
  • chth96
    • Nov 2022
    • 118
    • indonesia
    I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
    I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
    Click image for larger version  Name:	is-it-possbile-to-replace-171-7962a-x1-psu-with-171-7874a-v0-fpbctyvxojjc1-ezgif.com-webp-to-jpg-converter.jpg Views:	0 Size:	2.30 MB ID:	3219795
    I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
    Click image for larger version  Name:	is-it-possbile-to-replace-171-7962a-x1-psu-with-171-7874a-v0-5gozf1wxojjc1-ezgif.com-webp-to-jpg-converter.jpg Views:	0 Size:	1.05 MB ID:	3219796
    I want to replace this round black fuse and unidentified coil if it got broken.
    But How can I test coil whether it is really broken or not?
    and Is it possible to replace this round black fuse with normal glass fuse?
    Any reply would be appreciated.
  • Answer selected by chth96 at 02-21-2024, 04:48 AM.
    stj
    • 31316
    the coil is fine,
    the cap is obviously 200v rated and dead
    dreamcast right?
    it looks familiar
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      I suggest you start by changing the bloated capacitor first. The way i see it the coil is fine ..
        • 31316
        the coil is fine,
        dreamcast right?
        it looks familiar
        • chth96
          • Nov 2022
          • 118
          • indonesia
          Thank very much for all of reply.
          Yes. it is psu unit of dreamcast us version(HKT-3020) , and it was dead by connecting it to 220v outlet.
          If coil is fine,I will replace fuse as well as bulging capacitor(200v 100uf KMG).But Is it okay to test this psu board without connecting to dreamcast mainboard?
          (it would be similar to PC power supply Isolated Test)
            • 31316
            you probably need a load on the 3.3v line,
            and i hope you know the 2pin connector is for a power switch - so it wont work without the switch or a jump wire
            • chth96
              • Nov 2022
              • 118
              • indonesia
              I will connect only power cord and power switch to psu unit and will push power button in order to measuring voltage for all of six pin connector.
              I really hope that it would be no harm to psu unit, when I test this psu without any load.
                • 31316
                it wont harm it, but some psu's wont run stable unless you connect something to the output - like a resistor or lamp
                • chth96
                  • Nov 2022
                  • 118
                  • indonesia
                  Thank you very much for your reply.
                  in fact,It is becoming harder to get dreamcast mainboard in my nation.
                  So I really want to reduce likelihood of mainboard breakdown if there is something wrong in psu.
                  • chth96
                    How Can I test PWM DM0365R?
                    by chth96
                    Hello
                    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                    06-18-2025, 04:14 PM
                  • bauto601
                    KDM 480W PSU upgrade succes! (opinions?)
                    by bauto601
                    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                    A "nice" YoungYear unit? - Badcaps
                    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                    12-26-2023, 03:05 PM
                  • khelane
                    test active pfc power with lamp test
                    by khelane
                    Hello
                    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                    Is there a way...
                    06-03-2025, 01:00 AM
                  • chronic519
                    Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                    by chronic519
                    Hello.
                    GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                    Found issue with a RAM block
                    Replaced, green lines gone.
                    Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                    Used a good card to test and same results low errors 32+.
                    I am just search for some form of command to do a full test on the GPU.
                    I just ran the mats command with my good GPU and passed after roughly 40 min.
                    The repaired one, ran...
                    05-20-2025, 07:56 PM
                  • chth96
                    Is it possible bridging tiny broken trace
                    by chth96
                    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                    cutting tiny trace.
                    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                    12-03-2022, 11:32 PM
