What part is this coil from a MacBook A2681 ?
This topic has been answered.
  • waterchill
    • Sep 2021
    • 33
    Hi everyone
    I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
    So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
    IAny ideas? It is from a MacBook A2681
    Thank you
  • Answer selected by waterchill at 08-08-2024, 03:52 AM.
    mon2
    • Dec 2019
    • 14713
    https://canada.newark.com/tdk/mmz060...hs/dp/30AJ5232
    Ferrite bead that applies a resistance at 100 MHz. Much like an electronic resistor that is passive till the part reaches 100Mhz and then applies the noted resistance. IMHO, useless if 10ohms, should be higher resistance to filter out noise but use what they have in place already.
    • mon2
      • Dec 2019
      • 14713
      • waterchill
        • Sep 2021
        • 33
        Thank you very much sir!
        • mferna14
          MacBook Air A2681 battery problem after Screen Replacement
          by mferna14
          Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
          12-06-2024, 08:10 PM
        • Jamey021
          Yep...I broke it MOAR after fixing it. a2681 MacBook Air
          by Jamey021
          So, what are the odds I shorted the M2 CPU? I got in an a2681 MacBook Air. Liquid damage. Ordered from China and replaced a chip (APL109D 343S00555) cleaned corosion and ultrasonic..The whole 9 yards.
          Last night I put it all together and it came on beautifully. 20V- Apple Logo. I celebrated and knocked the LCD connector loose right away while holding the laptop. Now, it wont boot and it cycles on the volt meter.
          Cycle 20v - .02a then volt meter goes off, then it comes on and rinse and repeat. Classic sign of a MacBook short. I looked at the board with my thermal camera and I can...
          01-22-2025, 05:22 AM
        • boyseth
          Troubleshooting guide for Macbook m2 A2681 - No power issue
          by boyseth
          hello mates,, need help im a new tech here.. any tips or idea on important testpoint in repairing a no power Macbook m2 A2681? Thank you in advance..
          08-14-2025, 01:28 AM
        • Dylan Jones
          MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
          by Dylan Jones
          I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
          I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
          06-28-2025, 05:07 PM
        • princepal
          MacBook Air A2681 M2 for repair
          by princepal
          today I received MacBook Air A2681 M2 for repair. The MacBook is working have a startup sound and charging sound but no video on the screen I checked the backlight voltage which is 0V then I checked the backlight ic enable there is 0V on anyone please help me.
          04-30-2024, 04:18 AM
