Battery reverse rejuvenation
  • capwizard
    • Jun 2016
    • 1991
    I use Epsom salt try to rejuvenate, no water, for Razor E100 electric scooter, 12 volts 4.5AH, totally dead, battery.
    I filled it with Epson solution and I tried to charge it up with 247.4 volt DC voltage still nothing happened so I changed the polarity of the battery then it works up to 5A charging current.
    My question is can the battery be used as reverse voltage, I mean black terminal is +12v and red terminal is ground?
  • capwizard
    • Jun 2016
    • 1991
    Re: Battery reverse rejuvenation
    https://www.batterystuff.com/blog/ba...-polarity.html
    I think, I better change it back! ASAP, but if I did not reverse the polarity, the battery won't take the change!
    Isn't possible, if you want to charge of a dead battery, first is to reverse the polarity?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8710
      Yes, lead acid batteries can be charged in reverse due to its mostly symmetric design.
      Don't sweat it though. The battery is already ruined.
      • capwizard
        • Jun 2016
        • 1991
        it is a lead-acid battery why we put Epsom salt (alkaline) inside the battery? Shouldn't we put acid solution inside the battery? After we neutralizing the battery's electrolysis fluid?
        I found the answer
        Lead Acid Battery Desulfation Using Epsom Salt
        Can you put new acid in an old battery?
        Most new batteries are maintenance-free, so you can't mess with the components inside. Older battery designs lose water in the electrolytea mixture of about one part sulfuric acid and two parts waterfrom evaporation. ... Charging the battery reverses the chemical reaction and restores the plates' chemistry.
        The Super Secret Workings of a Lead Acid Battery Explained
        https://www.batterystuff.com/kb/arti...d-battery.html
        Charging is a process that reverses the electrochemical reaction. It converts the electrical energy of the charger into chemical energy. Remember, a battery does not store electricity; it stores the chemical energy necessary to produce electricity.
        A battery charger reverses the current flow, providing that the charger has a greater voltage than the battery. The charger creates an excess of electrons at the negative plates, and the positive hydrogen ions are attracted to them. The hydrogen reacts with the lead sulfate to form sulfuric acid and lead, and when most of the sulfate is gone, hydrogen rises from the negative plates. The oxygen in the water reacts with the lead sulfate on the positive plates to turn them once again into lead dioxide, and oxygen bubbles rise from the positive plates when the reaction is almost complete.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8710
          You should just put sulfuric acid in it. Just a few drops will do. No point in putting Epsom salts in it, though Epsom salts should be slightly acidic anyway (not basic).
            https://batteryuniversity.com/learn/article/additives
            • capwizard
              • Jun 2016
              • 1991
              Using Epsom Salt (Magnesium Sulfate) to Desulfate a Lead Acid Battery that has a dead cell.
              Table of contents:
              Part 1: Initial addition of the chemicals http://youtu.be/vqfaziZE1XM
              Part 2: Adding Solution to Dead Interstate Megatron battery http://youtu.be/lFEnErs68XM
              Part 3: First Tests after Charging http://youtu.be/W_vpvjRIsHU
              Part 4: After Overnight Full Charge + Demoing Capacitive Desulfating Charger http://youtu.be/OF6obbSSUws
              Part 5: Using one of our custom built Capacitive Chargers to Pulse Desulfate Further. http://youtu.be/IlKaz3iv168
              Part 6: Interstate Battery after 1 week on Desulfating Charger + Solution http://youtu.be/WCAG2oJffvY
              How to build a Desulfating Capacitive Battery Charger, Complete with Diagram Start to Finish
              https://www.youtube.com/watch?v=N6NluEvBAUU
              • capwizard
                • Jun 2016
                • 1991
                There is a way to do 100% rejuvenate any old Lead acid Battery...........
                Lead acid Battery making process complete step by step.|start your own battery making business
                https://www.youtube.com/watch?v=N0eE_5GZZiE
                How to make Deep Cycle Batteries
                https://www.youtube.com/watch?v=3Sg-u0_7d1g
                What he did was exactly what I was going to do. and this is also not working....
                WILL NEW ELECTROLYTE BATTERY ACID RESTORE A CAR BATTERY.
                https://www.youtube.com/watch?v=qcn6uoQnekI
                  • 31286
                  i'm surprised you have not made your own battery yet.
                  btw, if your going to get the crystals & shit off the plates using chemicals or electronic pulses, you should probably flush it out afterwards and then fill it with fresh acid.
                  • Jesse James
                    • Sep 2018
                    • 95
                    Wow some great info thanks
                    • redwire
                      • 3912
                      Lead acid batteries can fail due to sulphation or the plates corroding.
                      If the plates are shot and you give it the sulphation treatment, it will just make lots of hydrogen and waste your time.
                      I have never been successful reversing sulphation, electron microscope pics show the lead sulphate crystals are non-conducting and stuck in the pores of the plates. Very hard to dislodge or dissolve.
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • mkdj
                        ASUS X571 no power : battery issue?
                        by mkdj
                        Mark and model: ASUS X571
                        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                        Tests already made:
                        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                        - I have removed...
                        07-14-2025, 09:16 AM
                      • Kervin Mathumbu
                        Asus E410 only works on battery after reverse polarity
                        by Kervin Mathumbu
                        Hi everyone. Fixed my AC and despite trying to be extra careful, I reversed polarity and got a notable pop sound. Now the PC will only work on battery. Windows still shows the battery as charging but the count actually goes down until empty (I have two of the same laptops).
                        I have board R3.0 so the schematics on another thread here do not match mine. I have tested the BQ charge IC and my pin 1, 2 and 3 have 3.35v each - instead of 18v or 19v. Could this be a bad BQ IC or capacitor? Any thoughtful advise sould be greatly appreciated.
                        Mobo shows no visible sign of a fried...
                        07-15-2024, 11:26 AM
                      • techfreak9356
                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                        by techfreak9356
                        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                        09-14-2023, 11:10 PM
                      • Dev Goose
                        Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                        by Dev Goose
                        Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                        What Happened
                        The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                        12-13-2024, 03:13 AM
