Voltage on heatsink
  • fatcat
    • Nov 2014
    • 45
    Voltage on heatsink
    I have this old receiver with an atsc tuner that I am using for OTA channels. It's always been a bit finicky. I was checking out the power supply and accidentally touched a heatsink that has a rectifier or something attached, and I got zapped. I checked with a meter and the heatsink has 117vac on it. Could this be normal or is it weird?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: Voltage on heatsink
    Well, good thing you were able to walk away from it...touching any live SMPS can be deadly. Anyway, if it's normally covered by some plastic so that you can't touch it, then it's fairly common - one of the heatsinks tend to be hooked to the line input, after being rectified and filtered. Not all of them are like this but it's fairly common.
      That is why I always suggested to at the very least plug the TV into GFCI outlet if you do not have Isolation transformer.
        • 31277
        but would a gfci trip if the leak was after a full-bridge rectifier??
        the fantom drain is sourced from both poles!
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          It's a good question stj.
          I've been shocked exactly like described:
          By touching the metal chassis that was grounded and simultaneously the primary side heatsink that was live.
          I later measured 160VDC on the heatsink.
          It's by far the worst shock I've ever had. (Meaning it carried allot of current & wasn't just static buildup or anything like that).
          The outlet was however not GFCI protected due to running from a UPS.
          So I had to do some tests now: finding PSU's that have live heatsinks was not a problem!
          One had only AC present of about 30v, I did not test it.
          Another had 160VDC and 130VAC, it tripped the GFCI instantly when I tried starting it up with the primary heatsink connected to ground through a 10Ω resistor.
          A third one also had 160VDC and about 130VAC, in any case it seems pulsed DC, just like would be expected.
          However on the last PSU I did not connect up the resistor first, but did a more "real world" test where the PSU was running and then I connected the resistor.
          It tripped the GFCI instantly but the sparks from the resistor where really impressive!
          This tells me one thing: even if the GFCI can trip we still have large bulk capacitors that store allot of energy:
          Of course the GFCI can't protect us from that since there is still a return path to ground available...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            I think it still should trip, current is still leaking towards ground instead of the other pole.
            Worth an experiment? Not too hard to concoct one... (No, shouldn't do it ElectroBoom style. )
            Ah looks like Per Hansson did do the experiment. That 10 ohm resistor is a bit too low however, it should trip with much less current; 10 ohms is getting close to where it would trip a regular circuit breaker (not quite, but getting there...)
            GFCI should trip with milliamps of current, a 10K ohm resistor should trip it I think....
            • Sparkey55
              • Jan 2010
              • 1523
              A properly working GFCI outlet should trip at less than 2 milliamps.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Yea, looking through my junk bin i found a 17k resistor, it does not trip it. (~10mA)
                Around 7.5k does trip it though (~20mA) but then I got tired of wiring resistors in series
                Anyway the experiment was to see how much power I'd see, sparks flying signify that we are dealing with allot of energy. (10Ω is afterall 16A at 160VDC).
                The higher current I pull through the GFCI the quicker it should trip.
                My theory was as I said that the bulk filtering capacitor provides that energy even after the GFCI has tripped.
                However I just tested that: the bulk filtering capacitors are charged to 330VDC, they quickly dropped to 160VDC when tripping but then stayed there.
                So I next tried connecting the 10Ω resistor to the live heatsink but the voltage did not drop any faster at all.
                So it seems indeed that a GFCI is a very good protection even after a bridge rectifier
                (On second thought this might be due to the APFC circuit, a PSU without APFC might not behave the same way, i.e. it might shock you...)
                Most common GFCI are rated for 30mA, the one I used was too.
                • Sparkey55
                  • Jan 2010
                  • 1523
                  It only takes 1 milliamp to stop the heart.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    Well the energy stored in the capacitor is limited, once it's discharged, the person getting electrocuted should be "released". The main danger is the danger coming from the mains that will keep a continuous flow going.
                    30mA is huge, should be much less than that for home wall sockets. 10mA is enough to cause problems in humans as it is - enough for a person to lose control of muscles.
                      • 31277
                      standard rcd's in the u.k. are 30ma
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        In the USA, the home wall GFCIs that were meant to protect against electrocution should trip with only 4 to 6mA according to . This does jive with the 10mA AC number that will disable a human from pulling oneself away from the shock source, but not enough to be a nuisance trip while driving non-resistive loads that may be coupled to ground.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          A standard PC power supply leaks a couple mA through the Y safety capacitors.
                          It would be very annoying with GFCI outlets rated at 4 to 6mA, due to the following:
                          Leakage current in power supplies may occur due to the EMC filters, which utilizes Y capacitors between the live and neutral conductors. This causes some leakage current to flow from the neutral or the live conductor to the power supply casing which is normally connected to the earth ground.
                          Most power supply manufacturers specify this current which should always be lower than 3.5 mA as per the IEC-60950-1 regulations. This ensures that the current is very low and cannot harm the person who touches or comes into contact with the power supply case. A power supply with a good earth ground reduces the leakage current significantly by providing a low resistance path to the ground.
                          Source: https://www.sunpower-uk.com/glossary...akage-current/
                          So in effect a GFCI rated for just 4mA could only take one single PSU that is at the upper end of the leakage current spec.
                          I think the 30mA rating was chosen just to keep nuisance tripping as low as possible.
                          Because the worst would be if people start ripping out the GFCI devices because they trip needlessly.
                          The one I used for my tests is sold as 136-57-301 at Elfa.
                          That said they have a handful rated for 10mA, but over a hundred rated for 30mA, that should tell you what's normal in Europe at least
                          Actually I wanted one rated for 10mA because I use it when repairing power supplies to protect me if I do something stupid with my oscilloscope.
                          But they are not available here...
                          This is also interesting, from an ABB PDF on GFCI devices: https://cdn.badcaps-static.com/pdfs/...c4df9e9f52.pdf
                          How many fluorescent bulbs and computers can be
                          connected simultaneously if a 30mA APR type RCD is
                          installed?
                          APR RCDs are characterized by their high resistance to line
                          overvoltages from atmospheric origin, grid interference and
                          leakage currents. One of the main factors concerning the
                          origin of leakage currents is the connection of numerous
                          computers and fluorescent bulbs with electronic ballast at
                          the same time. APR RCDs, thanks to their anti-interference
                          characteristics, reduce the risks of unwanted tripping,
                          significantly improving operational continuity for numerous
                          applications (offices, supermarkets, datacentres, schools etc.).
                          The most critical aspect for dimensioning lines supplying
                          fluorescent lights or computers is undoubtedly the interference
                          these devices emit. Today it is impossible to give exact
                          indications on how many bulbs and computers may be
                          connected, as this is variable and depends on the connected
                          load. Despite this, we can try, as we have done in the table
                          below, to give a general indication which can help facilitate
                          dimensioning of these lines.
                          Code:
                          RCD type	N. of electronic ballasts	N. of workstations
                          						(computers / printers)
                          Standard	20				2
                          A-APR Type	50				5
                            I always use GFCI when working on the TV EVERY TIME, no fault tripping yet and if it does I will find out why because there is leakage current limit for monitor/TV. Look at service manual sometime.
                            BTW, here is the TV allowable leakage current.
                            I wonder how may repair shop bother to do safety test, it only take one law suit to wipe out your business. Most shops just do not care.
                            https://www.evaluationengineering.co...safety-testing
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8706
                              In the US there is also the 30mA spec GFCI that was not focused for end user personal protection but rather for reducing nuisance trips. However, 30mA is deadly.
                              I've only seen some nuisance trips on my GFCIs... only very rarely. A small handful of my outlets are GFCI protected despite not in a water area (i.e., outdoors, garage, kitchen, bathroom) and I've been using them with SMPS and have not seen trips. In fact the most often trip method I've seen is actually pressing the test button by mistake while plugging in a device ...
                              I still use my isolation transformer regardless if there's a GFCI there or not
                              • Fernon@Repair
                                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                by Fernon@Repair
                                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                VCCIO voltage ok
                                VCCSA Voltage OK
                                VCCPLL Voltage OK
                                Ram Voltage ok
                                RamVTT OK
                                VPP 2.5 OK
                                But No Core Voltage
                                and i want to this vrm ic datasheet or pinout (ISL69269)
                                anyone have this ic pinout voltages?...
                                06-25-2025, 07:19 AM
                                Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                by sam_sam_sam
                                I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                Now...
                                06-09-2024, 10:57 AM
                              • electron_jj
                                Panasonic TH-L42D25A checking the PSU output voltage
                                by electron_jj
                                Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                08-29-2021, 08:13 AM
                                ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                Based on Intersil's Robust Ripple Regulator...
                                11-05-2024, 03:24 PM
                              • ruletero
                                Acer a515-43 low battery charge voltage
                                by ruletero
                                Hi
                                Acer A515-43
                                LA-H801P
                                Fail: Does not charge battery, has low voltaje on connector.
                                Laptop didn't want to turn on, only charge led blinked.
                                I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                10-24-2022, 02:31 PM
