fake desoldering wick
  • rookieme
    • Oct 2014
    • 401
    • Greece
    I'd like to inform the forum that lately when I try to buy desoldering wick from China [either via ebay or aliexpress] I'm receiving fakes that are not made from copper.
    If you are having trouble when you are using your wick and it doesn't conducts heat maybe you get fooled too.
    A simple test is with a magnet.
    Copper doesn't get stuck at a magnet but these shity ones do get magnetized.
    Also they are tougher than copper and cannot get chopped easily and can harm your tools.
    Luckily so far I'm getting my money back at these cases after opening a dispute.
    The affected brand is gootwick and so I'll try other brand to see the results.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: fake desoldering wick
    Why don't you buy some genuine Chemtronics braid from RS ?
    http://gr.rsdelivers.com/productlist...ily=11992&tag=
    • rookieme
      • Oct 2014
      • 401
      • Greece
      Nice one but it seems overpriced!
      Seems to be the best quallity according its price though.
      • diif
        • Feb 2014
        • 6978
        • England
        Compared to fake Gootwick, yes it will seem a little pricey.
        The first time you use it though, you will realise it's cheap.
          • 31277
          spirig wick is good.
            +10, it is better to use good stuff instead of damaging the board with cheaply made stuff.
            • petehall347
              • Jan 2015
              • 4448
              try adding flux
              • lti
                • May 2011
                • 2557
                try adding flux
                That won't help if the wick is made of copper-colored steel.
                • rookieme
                  • Oct 2014
                  • 401
                  • Greece
                  That is for sure, I have tested adding flux and rising temperature with bad results only.
                  The fact is that this situation happened after summer as before I could buy cheep wick and worked well as it was copper.
                  • llonen
                    • Sep 2014
                    • 495
                    • hampshire
                    Cant say I have had any problems with Goatwick I obtained a couple from Uk sellers then imported a quantity from China, both seem to perform the same and both are copper as far as I can tell. That said I rarely use the stuff anyhow and quite a lot of the work I do it would not work with anyway, through hole plated with heavy ground-planes etc, as though with most soldering processes adding good quality flux helps. That said for what I charge for rework and repair the Chemtronics braid seems more than reasonable, might try some.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5085
                      • New Zealand
                      I have never tried the stuff from eBay. Now that you mention this, I doubt I will.
                      I have never actually tried the expensive Goot ones. Jaycar's cheap wick has worked well enough for me so far that I didn't see the point.
                      -David VanHorn
                        • 31277
                        a friend used to make his own,
                        stripping old tv antenna cable and running it through a pot of flux & ipa!!
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          Have used Goot Wick in the past and it was decent, but have moved to using Chemtronics exclusively for a good while now. It ain't cheap, but the weave is a lot tighter than Goot Wick so you use less for the same job.
                          A working TV? How boring!
                          • llonen
                            • Sep 2014
                            • 495
                            • hampshire
                            Have thus tried the chemtronics stuff for a while now and don't seem to notice any significant difference other than perhaps the weave, I too used to make my own de-soldering wick
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              For me I've only ever used (successfully) Chemwick and MG Chemicals. The former seems to be a hair better but both do the job well. Cheap crap, I've used on occasion and I will say, it is indeed shit, even when they do use real copper.
                              sigpic
                              (Insert witty quote here)
                              • dellxps15
                                • Feb 2014
                                • 1598
                                • italy
                                i use goot wick that buy from china. when i ask for them, i got a price list like this:
                                1$ for a fake, 1.5$ for a good fake, 2.7$ for a genuine japan.
                                i went always for the original and they are really good. i use the cp2015 2mm wide and ddesolder very good when applied the proper amount of flux.
                                before that, i got chemtronics from a local shop. got them for 2.5€, but now they havent them annymore and got some very very bad quality ones, so i still keep getting lots of that goot wick from china on each bga ic order i make.
                                • lax luthier
                                  • Mar 2018
                                  • 19
                                  I don't know if it's fake, but I bought ten rolls of "Solder-Wick" branded braid from All Electronics, which did not work. Could be stale?
                                  Then one day recently I had an idea to soak it in acetone to remove the old flux, which it did. But also rendered was some nasty green stuff (copper oxide?)
                                  After flushing the wick thoroughly it became nice and shiny as well as much more flexible and open-weaved. Now when dipped in some Kester liguid rosin flux it works perfectly.
                                  Regards, "lax"
                                  Why don't you mine your own Bismuth,
                                  Mine your own Bismuth
                                  So you won't be mining mine?
                                    • 31277
                                    the "nasty green stuff" may have been the old flux.
                                    • lax luthier
                                      • Mar 2018
                                      • 19
                                      I don't think so, the flux turned the solvent an amber color, pretty typical for rosin flux.
                                      Well the good news is the treatment was successful. Could well be a remedy for
                                      some of the other braid product cited earlier.
                                      Regards, - L -
                                        • 31277
                                        plain rosin wont work with lead-free solder very well.
                                          03-31-2024, 02:12 PM
                                        • estabilito
                                          Tips geting oxidized when using wick
                                          by estabilito
                                          Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                                          i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                                          Temperature: 350-365celsius
                                          station: jbc cd-2bqe
                                          Wick: edsyn
                                          flux: warton hf rework jelly
                                          Do you have any tips?...
                                          04-12-2025, 11:55 AM
                                        • hans_meier
                                          HP EliteBook 840 G6 how to dump without desoldering
                                          by hans_meier
                                          I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
                                          01-04-2025, 04:11 PM
                                        • paparazzo79
                                          Fake magsafe 2 charger
                                          by paparazzo79
                                          Hi guys.I bought Macbook Pro mid 2014 15 inch model which did not came with charger.
                                          I got new charger but judging by the specs seems it is fake one.Sadly I live in Bosnia and genuine charger is rare to find.
                                          what to do?Should I use the fake one?
                                          Will it damage the macbook?...
                                          10-02-2024, 08:18 AM
                                        • armini
                                          18VDC PSU completely dead - ZD-915 desoldering station
                                          by armini
                                          Hi everyone!
                                          Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                          Due to a lack of time, I set it aside and didn't look at it.
                                          Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                          According to replies in 18VDC PSU has dropped to...
                                          04-25-2023, 07:49 AM
