18VDC PSU has dropped to 10v - ZD-915 desoldering station
  • phreak97
    • Oct 2017
    • 10
    My ZD915 desoldering station lost fan speed, pump speed, and peak heating ability yeaterday. Today I did some investigation and discovered the 18v psu is only outputting 10v. Now, I know the basic idea of how a switching pau works but not well enough to quickly diagnose the faulty component. I know the transistor controls the pwm via the opto-isolator, and how the pwm drives the transformer, but I haven't the faintest idea what part is likely to cause the output to almost halve.
    Any ideas what I should check?
    Here's a photo of the pcb: https://drive.google.com/file/d/12Bm...w?usp=drivesdk
    • 31262
    Re: 18VDC PSU has dropped to 10v - ZD-915 desoldering station
    most likely possible suspects,
    bad caps causing ripple/spikes,
    bad opto isolator
    bad voltage reference - probably marked "431"
    • R_J
      • Jun 2012
      • 9610
      Does E3 look slightly bulged on the top? I would also replace that small electrolytic in the primary circuit
      • redwire
        • Dec 2010
        • 3912
        ZD-1565 V2 same psu was discussed here: ZD-915 Desoldering Station when on the blink
          • Jul 2011
          • 6070
          I have 6 of these unit
          Try this first hook up two 12 volt MR16 50 watt bulbs or (two 1157 automotive light ) in series and see if the power supply is shutting down and restarting
          I had one of them that the mosfet had issues with it and was pulling the power supply down
          This is reason for having you check the power supply by it self do not run this power supply with out the heat sink installed you will fry the switching power supply regulator ic chip if you do with a load on it
          If it is do the following
          The first you need to do is is replace the switching regulator ic chip this is the ic chip that has 5 or 6 pins to it and replace of the capacitors on this board ( I have had to change a few of them before on these units
          Look at the switching power supply regulator ic chip it hard to tell in that picture if it has a crack at the top of it or not
          as mentioned earlier about the optic sensor ic chip and the voltage reference ic chip it would not hurt to maybe replace that as well or at least check it to make sure it is working correctly or not
          The next thing is if you have a lab power supply power the temperature controller board with ( only 12 volts not 18 volts that it normally works at ) with out the Desoldiering Gun hook to the controller board and measure the current of the board it should not be more than 30 or 40 milliamperes if it higher than check the surface mount capacitors on that board for any of them are getting real warm it has happened to me before
          Also check the fan controller board and see if it has resistors in it or has an ic chip in it there are two versions of this unit the earlier version and the later version
          One note about this switching power supply it claims to able to put out 15 amps me personally it would be lucky on a good day to put out maybe 10 amp with out straining
            • Jul 2011
            • 6070
            If you are thinking about running this off of another 18 volt switching power supply
            PLEASE read this post first
            You can however you need to supply it with + 5 volts and - 5 volts for temperature controller to work right ( this switching power supply does some weird things ) that if you try to run it off of pure 18 volts dc power supply you will have problems if use the setup for the heater controller mosfet and the pump controller mosfet
            You can however use a PWM power supply controller and a 3D heater bed controller which has to be modified to work off 3 volts not 12 volts for the optic sensor and use one for each of the heater element and the vacuum pump
            • phreak97
              • Oct 2017
              • 10
              Thanks! I'll do those things and post back. The fan box has two resistors inside and the fan is labelled 24v
              • phreak97
                • Oct 2017
                • 10
                Ok it’s working now but i’m not super confident that it’s actually fixed. I reflowed the vref chip, pwm chip, and mosfets, then put it back onto the heat sink with some breakout wires to put a load on it. It worked fine straight away. I did hear a buzzing sound from the transformer for a short while though which was odd..
                  • 31262
                  maybe it needs soldering or the windings/core are loose.
                  • phreak97
                    • Oct 2017
                    • 10
                    Yeah maybe I'll reflow that too then just see how it goes
                      • Jul 2011
                      • 6070
                      I have a question for you when you use this Desoldiering Gun unit how many hours do you have it on in one session
                      Because when I use mine it might be on for hours
                      • petehall347
                        • Jan 2015
                        • 4447
                        • United Kingdom
                        wondering why the soldering gave up so soon ? lead free i guess .
                        • phreak97
                          • Oct 2017
                          • 10
                          Usually an hour or so at a time, sometimes more, sometimes less.
                          The solder failed because it's badly soldered in the first place
                            • Jul 2011
                            • 6070
                            It probably would not hurt to resolder all of solder joints on the power supply board just for good measure yeah I know it a pain in the a** but you might not have any more problems with for a while
                            • phreak97
                              • Oct 2017
                              • 10
                              Probably not a terrible idea
                                • 31262
                                lead-free is stronger,
                                these units vibrate when the pump is on, and the soldering may not be great to begin with.
                                my experience with chinese boards, SMD are great but throughhole can be questionable.
                                probably because SMD boards are machine-assembled and not stuffed & soldered by lines of bored women.
                                • phreak97
                                  • Oct 2017
                                  • 10
                                  Stronger yes but more susceptible to cracking with repeated expansion and contraction.
                                    • 31262
                                    there is no expansion and contraction in these - they are fan cooled.
                                    • phreak97
                                      • Oct 2017
                                      • 10
                                      These are just built poorly.
                                      • phreak97
                                        • Oct 2017
                                        • 10
                                        Ok as it is now it works after maybe 10-20 seconds of flashing error/heat and beeping at about 4Hz, seems to be overloading, shutting off, coming back on. Doesn't do it with the gun unplugged. It's making a high pitched noise for a while too, the psu is still not happy. Annoyingly I reassembled it. Do you know the part numbers of the chips and mosfets? If theyre cheap enough I might just shotgun the lot and be done with it. All caps had low esr.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • armini
                                          18VDC PSU completely dead - ZD-915 desoldering station
                                          by armini
                                          Hi everyone!
                                          Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                          Due to a lack of time, I set it aside and didn't look at it.
                                          Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                          According to replies in 18VDC PSU has dropped to...
                                          04-25-2023, 07:49 AM
                                          HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 02:20 PM
                                          MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:20 AM
