Open Neutral you say? A story of carnage at Gooontrons house.
  • lax luthier
    • Mar 2018
    • 19
    Re: Open Neutral you say? A story of carnage at Gooontrons house.
    I know this is an older thread, but... So how about not connecting or disconnecting the RV power cord unless the supply circuit has been turned off?
    Why don't you mine your own Bismuth,
    Mine your own Bismuth
    So you won't be mining mine?
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Not sure what you mean by that. Its a direct run between the meter and the socket. No fusing or disconnect.
      Follow the white rabbit.
      • Sparkey55
        • Jan 2010
        • 1523
        I fully understand what he means. Their should never be a unconnectable live circuit between the power source and the building power entrance. Power source> Service head> Meter (disconnect)> Service panel (main breakers)> then individual line circuit breakers. In that order. Any thing else is illegal.
        • R_J
          • Jun 2012
          • 9623
          That might be illegal in the usa but not everywhere, in Canada the service comes into the meter and goes straight to the panel main breaker totally legal
          • Sparkey55
            • Jan 2010
            • 1523
            Exactly as I stated above. The electrical meter is the switch ( disconnect point by phyiscally pulling it out of the circuit). That action of pulling the meter prevents you from receiving power.
            In Goontrons case Rv"s would have (or should have) a metal switch box with a lockable throw switch to connect power to his service entrance RV or trailer.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #26
              Negative.
              Service header > Meter(pan) > underground run > service pedestal that consists of a single range/RV socket > Run into the house > Busbars of the breaker panel.
              That plug IS the customer-side disconnect.
                • 31281
                interesting fact,
                in europe we have connectors 63A or higher that have an extra pin that is shorter,
                this pin loops back in the plug from another pin and controls a big contactor in the socket housing.
                so if you try to pull the plug it will break the power before the contacts seperate to prevent an arc.
                • lax luthier
                  • Mar 2018
                  • 19
                  The configuration you describe is improper in any location in the world. I think you have demonstrated the reason for this requirement: The damage that your equipment suffered. Please have it corrected.
                  This is the section of the Canadian Electrical code which addresses not connecting live (ungrounded) conductors directly to the buss bars immediately following the load side of an electrical service meter:
                  https://www.electricalindustry.ca/la...i-instalment-8
                  December 6, 2015
                  William (Bill) Burr
                  The CE Code is a comprehensive document. Sometimes it can seem quite daunting to quickly find the information you need. This series of articles provides a guide to help users find their way through this critical document. This is not intended to replace the notes in Appendix B or the explanations of individual requirements contained in the CEC Handbook, but will hopefully provide some help in navigating the code.
                  Section 14 is a general section of the Code and the Scope applies to all electrical circuits and apparatus installed in accordance with the requirements of the Code unless amended or modified by other sections. As with other sections of the Code, the Appendix B notes contain much valuable information on the use of the rules in Section 14.
                  Section 14 is divided into three main parts covering general requirements, protective devices, and control devices.
                  In the General requirements part:
                  • Rule 14-010 specifies that protective and control devices are required to be provided for electrical apparatus and ungrounded conductors. It provides the most fundamental requirement in the Code: to install control devices in order to manually disconnect all ungrounded conductors of a circuit or to automatically open the circuit if a current in a circuit reaches a value that will produce dangerous temperatures or in the event of a ground fault. The rule is needed to prevent damage or injury due to overloads, short circuits or ground faults, and also hazards caused by a low or no voltage situation. Protective devices include fuses and circuit breakers while control devices include switches as well as circuit breakers.Note that a fuse is not a control device and must be used in conjunction with a switch where control is required.
                  I hope you will find it to be helpful.
                    • 31281
                    regardless of "codes", it's pretty standard at both camping grounds and docks/marina's to just have a posts with a meter followed by a multipole breaker and then the socket.
                    the rest of it (distribution panel etc.) is expected to be in the boat/truck etc on the other end of the cable.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      #30
                      I don't even have the breaker
                        • 31281
                        that's not good, in theory you could blow the meter up - it has to have a current limit before something burns!
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          #32
                          Indeed i could. Im just waiting for the day when the plug/socket fails and the whole run burns up.
                            • 31281
                            LOL
                            maybe trip over it on the 4th next month!
                              master hoarder
                              • May 2008
                              • 12175
                              #34
                              "Don't overload your electric meter"
                              https://www.youtube.com/watch?v=ut5DXxK1dvk
                              • SolomonMan
                                Antenna...
                                by SolomonMan
                                All,
                                I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
                                There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
                                Since we moved in, 8 years ago,...
                                10-05-2023, 02:37 PM
                                High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
                                I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
                                This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
                                If it cycling on and off constantly then it is the bulb itself that is the issue
                                06-03-2023, 05:24 PM
                              • nobbnobb1
                                Upgrading Whole Home Surge Protector MOVs (Eaton CHSPT2SURGE)
                                by nobbnobb1
                                I have a whole home surge protector (Eaton CHSPT2SURGE). This is the lower end model as compared to the CHSPT2ULTRA. When I took it apart, I noticed it's basically the same PCB as the higher end model, just missing the extra MOVs for higher capacity. Coincidentally, I have a pack of brand new Bourns 20D241K MOVs laying around:
                                https://www.digikey.ca/en/products/d...0D241K/2799098
                                The only thing I noticed is that these Bourns MOVs are not thermally protected with a fuse. I'm wondering if it's safe to just simply install these extra MOVs for extra capacity,...
                                06-04-2025, 08:40 AM
                              • SluggerB
                                Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                by SluggerB
                                Yes it's a 17 year old Panasonic plasma!
                                I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                06-04-2025, 07:02 PM
                              • xTomtom
                                Treadmill hit with power surge
                                by xTomtom
                                Recently I acquired a treadmill that was hit by a power surge (I assume). On the control board, there was a varistor that was blown apart and two traces that were partially blown out. I replaced the varistor (to my knowledge it is a matching one) and wired back where the traces were with some 22 awg solid copper wire. When I went to power it on, still nothing. On a quick inspection with my meter, I was getting incoming voltage on the AC in terminal.
                                The board is a MC2100LS-30 treadmill controller.
                                Visibly, there are no other problems....
                                05-09-2023, 08:06 PM
