What is a mechanical solder sucker?
    • 31009
    Re: What is a mechanical solder sucker?
    no, you didnt damage anything.
    your tip needs a clean using some wire wool probably, then put some solder on it at a REASONABLE temperature.
    what iron is it?
    • johnnyh55
      • Oct 2015
      • 44
      what iron is it?
      It's a Hakko FX888D. So you can clean the tip with wire wool? I know in the manual it says never use a file on the tip but I guess wool is ok?
      Also every solder tutorial I look at show a component pad on the PCB that is easily noticeable, is it normal that I don't really see a pad on the motherboard, I guess it's there but really small?
        • 31009
        888D has wire-wool in the iron-stand
        • johnnyh55
          • Oct 2015
          • 44
          That's true, lol. So I just rub the tip in the wool, or do you think I'll need to remove the wool from the stand and give the tip a good brushing in the wool by squeezing the wool with one hand and turning the iron with the other?
            • 31009
            it works just fine in the stand - that's why it's there.
            infact i only use wool - none of that wet sponge shit.
            • johnnyh55
              • Oct 2015
              • 44
              So I turned down the temp to 572 but it wasn't melting the solder on the board so I turned it up to 662 and now it seems ok. How do you pickup solder on the board when there is not enough to be picked up by a solder sucker?
              • SteveNielsen
                Retired Tech
                • 2327
                Use solder wick. See post #25.
                • johnnyh55
                  • Oct 2015
                  • 44
                  I tried it but its not wicking for some reason.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #49
                    I use a K type tip. Extra flux helps a lot.
                    • johnnyh55
                      • Oct 2015
                      • 44
                      I bought a flux pen but do I apply the flux to the solder to be wicked up or to the wick itself? I tried both but they dont seem to work
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #51
                        Send us a photo of tip and the braid. applying the flux to the braid should be enough. A small amount of solder on the tip will help to wet the wick.
                        • dj_ricoh
                          • 2073
                          #52
                          if the wick does not suck, cut only a small part and hold it with a tweezer.
                          in some cases the tip from the iron its to small and it can`t heat up the cooper wick and it does NOT suck.
                          that`s why i use 3 irons . 0.2mm 1mm and one extra i don`t know the size its so big.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #53
                            Ensure it's good wick, i used to struggle with it until i bought some Chemtronics, it's already fluxed i believe.
                            • johnnyh55
                              • Oct 2015
                              • 44
                              The tip i am using came with the hakko and it's a 1.6mm chisel tip, is that too big? It's the T18-D16 1.6D.
                              • Uniballer
                                • Jul 2013
                                • 334
                                In my experience, that one is a little too small to move enough heat to get good results with motherboards. I mainly use a 3.2mm chisel tip for that (T18-D32). Personal preference and technique do come into play with tip choice, though.
                                  • 31009
                                  you will never get stuff from a motherboard with 1.6
                                  • ChaosLegionnaire
                                    HC Overclocker
                                    • Jul 2012
                                    • 3264
                                    • Singapore
                                    #57
                                    So is my tip no good anymore? Should I buy another one, or it's still good, I just need to re-tin and it should be ok?
                                    if the tip is darkened and wont wet/adhere to the solder, it then becomes very hard to melt the solder and retin it again. another way u can also try instead of a wire wool is to use a tip refresher to burn away the darkened oxide layer and it also instantly retins the tip at the same time. this method seems easier for newbies. for wiping with a wire wool, u need to quickly retin the tip again or else it will become darkened again and u end up having to wipe it again and it becomes an endless loop.
                                    however, be warned that those tip refreshers use a weak acid and is corrosive to pcbs. after dipping the tip in the refresher, make sure u wipe the tip on a wet sponge repeatedly to get rid of the acid and wash and rinse the sponge off and then wipe the tip on the freshly cleaned sponge again to remove all traces of the acid to avoid dmging boards.
                                      • 31009
                                      worth saying at this point, there are many fluxes for different jobs.
                                      some dont like high temperatures,
                                      some dont like lead-free solder,
                                      some will eat your stuff like blood from an alien!
                                      i really need to make a post soon about solders and fluxes for people.
                                      the right solder and the right flux - both in it and seperate, make a whole world of difference.
                                      specially with a decent iron like the 888D
                                      • johnnyh55
                                        • Oct 2015
                                        • 44
                                        Ok so I took a picture of everything I am using right now. I also bought a 3.2mm chisel tip today, it seemed to help but I still can't pick up all the solder that i need to pick up. I tried both wick's to no avail. I also noticed sometimes when I tin the tip, the solder that was added to the tip gets transferred to the board and I end up with excess solder, is there something i'm doing wrong?
                                        I know the super wick says for lead free solder but I don't know what kind of solder was originally used on the board, the nextech one doesn't meantion lead free but wether I used one or the other, it doesn't make a difference.
                                          • 31009
                                          well the flux is o.k.
                                          the mg braid is good, but probably not for this type of work.
                                          the nexxtech junk is a mystery.
                                          personally i would be using a pump - i'v never got braid to work on something large like that.
                                          • corrize
                                            Best way to solder LVDS connector for beginner (and qfn) ?
                                            by corrize
                                            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                            See the test :
                                            https://youtu.be/bNAzC-EvqHs?t=1767
                                            With hot air from bellow the board, that's...
                                            03-09-2023, 02:57 AM
                                          • myth77
                                            UV solder mask - high temp resistent, recomendation?
                                            by myth77
                                            Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                            Is there any solder mask...
                                            03-28-2022, 04:04 AM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
                                          • petemanuk
                                            BGA solder balls not connecting - help pls
                                            by petemanuk
                                            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                            11-16-2022, 05:21 AM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
