How to unsolder transistor
  • Rockguy
    • Jan 2015
    • 71
    Hi everyone, I am going to unsolder a transistor from a tv board. It's a 5N2307. Its the exact one in this thread. Same tv. https://www.badcaps.net/forum/showth...ght=TH-42PZ77U
    I have soldering irons. Weller WES51 and a 100 watt solder gun. I don't have a hot air station but, I would get one if it's the way to get this done. I'm a hobbyist so it would probably come in handy later anyway.
    If you can give me a complete idiots description, I'd appreciate it.
    • 31094
    Re: How to unsolder transistor
    use the wes to heat each leg, and lift the leg a bit with a needle when the solder melts.
    then clean the solder off with braid or a pump.
    once the legs are free the wes can be used on the tab to melt the main joint and you lift the part off with longnose pliers.
    keep the 100w destroyer in it's box.
    • selldoor
      Slow Learner
      • 7870
      Weather in illinois looks as good as here!! - Sometimes helps to work in a warm rom and to gently preheat the board with a hairdryer - reduces the heat from the iron dissipating into the board/heatsinks.
      • mariushm
        • May 2011
        • 3799
        Put the 100w iron away, it's too powerful for this.
        Put the other iron on the tab of that mosfet and warm it up a bit, then add solder on top of the tab. Add some solder on each leg of the mosfet as well.
        Now keep applying the iron top on top of each metal part for a few seconds or until you see the solder liquid and move to next (warm up solder on tab, move to each pin, repeat, the idea is to warm up everything).
        When everything is warm enough, just from the gentle sideways pressure of your iron tip, the mosfet should slide away from the location and then you can pick it up .
        • Rockguy
          • Jan 2015
          • 71
          Thank you. That's what I did. Looks like I need some repair now though
          Any suggestions?
          • Rockguy
            • Jan 2015
            • 71
            Good idea. Wish I'd waited for replies before doing this. I've got it in the house. 72 degrees in here.
              I cut the legs off (no need to keep the legs since it is bad part any way) first then add solder and flux to the tab to remove the main body.
              • Rockguy
                • Jan 2015
                • 71
                Thank you mariushm. On the non tab side, there is no visible solder other than the legs which as you know, stick away from the body of the component itself. All I see is green board. Anyhow, I wasn't sure I'd get any replies so I gave it a go before getting this. You see the results
                • Rockguy
                  • Jan 2015
                  • 71
                  Love your sig links budm. Added you to my contacts so I can read them at a later date.
                  • selldoor
                    Slow Learner
                    • 7870
                    [QUOTE=Rockguy;525366]You see the results[/QUOTE
                    Oh no we dont!
                    • Rockguy
                      • Jan 2015
                      • 71
                      [QUOTE=selldoor;525369]
                      Oh no we dont!
                      It's above and now here too
                      • mariushm
                        • May 2011
                        • 3799
                        Good.
                        If you don't have liquid flux, add a tiny bit of solder to that square and move it around to spread it evenly and mix with the solder that's still in that area. Then, remove the solder using solder sucker or solder wick.
                        When you install the new mosfet, ideally you'd put a drop of liquid flux on the mosfet tab and the copper pad and apply a bit of solder on the copper on the pcb. Then, put the mosfet and heat up the tab of the mosfet which in turn will melt the solder under the chip and the chip will be soldered onto the pcb.
                        The legs are much easier, you just heat up the leg and introduce solder where leg touches the small copper pad. Ideally you should also use liquid flux there, but if you have a good solder with flux inside it, then you're good to go.
                        • Rockguy
                          • Jan 2015
                          • 71
                          Good.
                          Remove the solder? Is that all that is missing from this board is old solder or, did I pull up part of the board too? I'm too much of a novice right now to know. My previous soldering has been either through hole or, no board, just wires themselves. I have paste flux. I could order liquid. My solder is Kester rosin core 60/40
                            • 31094
                            it looks to me like you ripped the copper pad apart!
                            • canadaboy25
                              What is normal?
                              • May 2013
                              • 509
                              Yup that's ripped apart. A little part of one of my pads came up (miniscule piece, not that big) and that's what it looked like underneath.
                              canadaboy25
                              -Sometimes the light at the end of a tunnel is an on-coming train
                              • Rockguy
                                • Jan 2015
                                • 71
                                So I'm thinking that if I flow solder in there, it won't stick.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  I think you'll be fine. Trace those connections then verify with your meter they are still good then flow some solder on the large pad and see what you've got.
                                  • Rockguy
                                    • Jan 2015
                                    • 71
                                    Isn't the area underneath the transistor itself just a copper pad used for cooling and hold down?
                                    That's what I was gathering from Tom66
                                      • 31094
                                      no, it's a 3rd connection.
                                      • SteveNielsen
                                        Retired Tech
                                        • 2327
                                        It is all three, it is one of the transistor connections, a heat sink, and how it is mounted to the board. The only thing I'd be concerned about is sufficient heat transfer since more than half the copper is gone.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • corrize
                                          Best way to solder LVDS connector for beginner (and qfn) ?
                                          by corrize
                                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                          See the test :
                                          https://youtu.be/bNAzC-EvqHs?t=1767
                                          With hot air from bellow the board, that's...
                                          03-09-2023, 02:57 AM
                                        • myth77
                                          UV solder mask - high temp resistent, recomendation?
                                          by myth77
                                          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                          Is there any solder mask...
                                          03-28-2022, 04:04 AM
                                        • petemanuk
                                          BGA solder balls not connecting - help pls
                                          by petemanuk
                                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                          11-16-2022, 05:21 AM
                                        • sircastor
                                          Solder not reflowing - what am I doing wrong?
                                          by sircastor
                                          I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                                          For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                                          03-03-2024, 02:44 AM
